Quoted from cottonm4:My Beatles launch ramp arrived this afternoon. Like any kid with a new toy I have been trying it out for fitment and action.
1) It is a little tricky to get lined up perfectly to make a good launch. I have pretty much got it lined up and the shooting is OK.
2) Permanent attachment is with two factory screw holes. I may have to drill one more hole for a full 3-point lockdown.
3) I have made a temporary ball guide from some polycarbonate to play around with and try for a good ball trajectory.
Observations:
If I pull the shooter rod all the back the ball snaps the glass. However, a more gentler skill shot pull makes for a nice smooth launch with no glass contact.
For shooter lane action I give a big thumbs up. But I'm still working on it.
For action of coming around in a clockwise loop, I also give a thumbs up. But a good ball guide is going to take some work.
What I have going right now with a 2-3 hours install and experiment time is looking good. Even where I am at so far I do not have to deal with a flap gate which is great.
Quoted from cottonm4:It's going to work. I got my metal ball guide built this afternoon. I have some fine tuning and clean up to do, but the guide will let you bang the upper right flipper for a clockwise orbit shot.
It is going to work !!
I finally finished my Beatles ramp for the shooter lane. As mentioned sometime back, this set up does not help with getting any more loop shots. So the time and money spent for that reason was a bust. However, as a preference for using the flap gate or going with this shooter set up, I do not miss the flap gate. It is not 100% perfect. Every once in a while I get a crappy shot but 9 times out of 10 I get nice smooth shots from the shooter lane.
I had to make 2 deflectors to keep the ball from jumping up and going over the arch plastic. Deflector #1 is an aluminum strip that travels from the rail and arcs around on top of the arch plastic. Deflector #2 ( does not show up in the pics) is a piece of plastic that is located on top of the drop target plastic. This plastic deflector is the first contact the ball has as it leaves the shooter ramp. The ball brushes it lightly on launch and does not crash into the play field glass. I am very satisfied the way it has turned out.
I also modified my strip of aluminum that replaced the flap gate. My prototype extended from the loop and went all the way down to just above the upper right flipper. This eliminated the two post and the rubber that located above the flipper. I have shortened the strip and replaced to two posts and rubber ring.
To do this I had to:
1) Make an undercut in the rail for proper location of the ramp. You can see the white wood in the rail where I did some grinding.
2) I had to drill two holes to locate the ramp.
3) I had to drill one hole to attach the flap gate replacement strip. The upper part of this strip is just pinched between the rail and the loop ball guide.
4) I drilled one new hole to relocate the outside edge of the spinner. With the factory install of the flap gate, the spinner sort of sat at an angle inside the loop lane. With the flap gate removed I was able to move the outside spinner post farther up the play field. The spinner performance is still the same and it is still a bitch to target but I think it looks better.
I also used some of this nice hand-formable aluminum strip to make a new deflector for lower left hand drop targets.
My plan is to bring Seawich to TPF. If you are going, then check out my shooter setup. It is not going to knock you out but I think you will appreciate it.
