(Topic ID: 271790)
Any recommendations on removing this paper label for reuse?
By BlackCatBone
    #1 3 years ago
    I've got a banged up counter that I plan to replace in this 1956 Bally game. I'd like to remove the "High Score" paper label and transfer it to the new counter. Does anyone have a suggestion for getting the paper label off in one reusable piece? It's held on by whatever adhesive Bally was using in the 1950s. I know I can print a new label but I'd prefer to save the original. Thanks.
    #2 3 years ago
    This sort of stuff?
    Just soak the hell out of it and go slow so not to tear the label.
    https://www.bunnings.com.au/un-du-118ml-adhesive-remover_p1560577
    "Un-Du instantly neutralises all self-sticking adhesives and then quickly evaporates, enabling you to re-use the sticker, stamp, label or tape."
    #3 3 years ago
    Thanks for the recommendation. I'd never heard of this product, so now Un-Du is on my radar. I was going to order a can when I thought I'd try one more thing: heat. I removed the meter plate (or housing) with the "High Score" sticker, then used my heat gun on the *reverse* side of the metal plate. After about 15 minutes I was able to lift one corner of the label and use that to pull the label off against the slight resistance of the gummy adhesive. The paper stock Bally used was heavy enough that I didn't sense I was risking tearing the label. The label came off without any discoloration.
    This page was printed from https://pinside.com/pinball/forum/topic/any-recommendations-on-removing-this-paper-label-for-reuse and we tried optimising it for printing. Some page elements may have been deliberately hidden.
