Quoted from danczaz:Thanks for the input. I returned the board and just bought a 19-1 board as suggested above and that plays like it should. It was a CRT monitor but Im not sure what type it is.
I was looking to get possibly Double Dragon 2 and Double Dragon 3. Is there a switcher or something you would recommend so I could mount all 4 boards inside and easily switch between games?
Thanks,
Dan
I have not used anything more than a double switcher in my smash tv cab to play total carnage.
They make several types. Up to 6 boards. They also make input switchers if your playing games with weirdly mapped controls (primal rage uses the start button as an action button).
Some of the switchers can get expensive. Some will power all the boards at the same time. Those will require a beefier power supply. If your not having to move inputs, maybe go with a game elf and a double switcher to play your double dragon.
I have mounted 4 boards on the side of the cabinet and manually switched the harness in a dynamo Hs1. But if you have the taito drawer cab, you don’t have much choice unless you nock out the divider.
