(Topic ID: 46689)
Another STTNG problem
By PinPeet
11 years ago
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 11 years ago by LTG
#1 11 years ago
Thanks for helping out. This is the problem.
Fuse f105 blows in the game when the right flipper button triggers. Also it then fires a ball from the right popper into the launcher and then the machine.
Cause:
I soldered on the coil and left the machines power on, some weeks ago. Painfull mistake. A pinsider concluded that I shortened something via the tip. I resoldered today a brand new coil and and replaced a new fuse for F105.
Check the video what happens.
In the coil test the right upper flipper does not blow the coil, but it launches the ball from the popper into the gun. When I look closely to the F105 fuse, I see the line inside actually move when the upper flipper test is running. But it stays in working order and the fuse does not burn.
I restarted the game and as soon as I hit the right flipper the fuse f105 blows again. The ball pops again to the canon. The machine works again normal when I change the fuse untill I blow it hitting the right flipper.
What to do?
I did another check someone suggested. I soldered the two outer wires of the coil and left the black one in the middle. Turned the machine on an played a game. Hit the right flipper did not cause the F105 to blow.
Thanks again for your kind assistance!
#2 11 years ago
Quoted from PinPeet:
I'd get the right wires in the right spots - and then check the coil, it's diodes, and transistors on the flitronics board to see what you all damaged.
#3 11 years ago
Thanks LTG, I will check the fliptronics board. Please check the video of the problem in the coil test, I added it today.
The wires are as in the picture. I tried several new coils so that and it's diodes must be okay as well.
Can you explain what and how to check the fliptronics board? Which setting on the Multi Meter, etc?
Can I change the board with my The Shadow for example. Or is this a high risk?
#4 11 years ago
bump, thanks!
#5 11 years ago
Check transistor legs on diode setting. Check them all to learn and look for one or two that are different.
If you have the coil wired right and diodes on it are good, then you can try the fliptronics board from Shadow.
$ 29.90
Pleasanton, CA
$ 27.99
Lee's Parts
$ 9.99
$ 1.00
Pinball Alley
$ 19.95
Mitchell Lighting
$ 85.00
$ 599.00
Juz PINBALL Mods
YouBentMyWookie
7,000
San Diego, CA
Pinball Invasion
$ 29.00
Filament Printing
$ 22.50
$ 49.99
$ 25.99
Lee's Parts
$ 259.99
$ 63.95
6,000
West Chester, PA
$ 64.99
$ 9.95
$ 250.00
Professor Pinball
$ 399.00
$ 15.95
Mitchell Lighting
7,500 (OBO)
Elizabethtown, KY
This page was printed from https://pinside.com/pinball/forum/topic/another-sttng-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
