what do i look for and what are some common problems?
Check the fuse for the ring magnet..f20..4a sb...if you have a regular lotr, its fine to put in a 5amp sb instead..
2nd thing to check if the fuse is not blown is that the spinner switch is not working. When the spinner is spinning it signals for the magnet to activate. If the switch is not working for the spinner the signal to turn on the magnet is not sent.
thankyou for the tips. i will check it out tonight and post what i find.. thanks again to all for the help.i love pinside.
opened up the back box. its the fuse. i can not find a slo blo fuse anywhere in the okie podunk town i live in. i tried a standard 5 amp fuse and it blew when i powered up. anyone know where i can find the right fuse locally?
Do you want me to send you one if the Radio Shack doesn't have them?
Sometimes Home Depot has them as well in the audio/video aisle.
Fry's Electronics usually has them too...
I think the MDL-5 fuses at home depot are the same as the slo- blo.
They call it time- delay instead of slo-blo
cool,and thanks to all. radio shack and home depot are both close. 5 minutes away so i will check tomorrow. thanks to all for the help.
Here is probably what you want from Radio Shack:
http://www.radioshack.com/product/index.jsp?productId=2102750
After you put the fuse in, hopefully it will not blow right away. If it does blow right away, then you most likely need a new transistor on the circuit board.
Good luck.
Quoted from DCFAN:Here is probably what you want from Radio Shack:
i checked the site and they have it in stock at my local store.thanks.
Quoted from DCFAN:After you put the fuse in, hopefully it will not blow right away. If it does blow right away, then you most likely need a new transistor on the circuit board.
Good luck.
thanks for the tip. hopefully its just the fuse.if not at least i know where to go with it.
It most likely is the fuse. Mine poped after two days out of the box. Replaced it as stated above and never a problem again. Others seem to have had similar results.The play field switch in the VUK also failed pretty quickly and stock up on the Belrog hit switches.
i went to radio shack and got the 5a slo blo fuses. got home and put one in. had the wife power up while i watched the fuse. it lasted about 1 minute before it blew.
Just had this issue with my flipper transistor. New fuse also immediately blew. Do a continuity test on the ring magnet transistor. I'm guessing you'll find it has failed.
replacing the transistor on your board involves soldering and a circuit board. If you know what you're doing, great! If not, you'll need to find/pay someone else to do it. I wouldn't recommend learning how to solder on a perfectly good board
Don't feel bad mrgone. I just had my first potentially big problem with my LOTR this afternoon. The ball went into the tower VUK and then it started doing a ding, ding, ding noise and suddenly the DMD said there was an operator error. Just a hunch, but I have a feeling either a fuse blew or the transistor failed (or both) for the VUK. The ball is just sitting in the VUK hole below the tower and does not try to kick it out.
I will have to wait a week to work it out. I have too many other things to do until then.
Quoted from Snailman:Just had this issue with my flipper transistor. New fuse also immediately blew. Do a continuity test on the ring magnet transistor. I'm guessing you'll find it has failed.
thats good advice. i have a local op/friend who has done board work for me before.
he does good work at a fair price. fwiw,im so grateful pinside is here.thanks to all for your help and support.
thanks,pinmike. the info is very helpful.i emailed my op friend and should hear back in a day or so.
Quoted from mrgone:thanks,pinmike. the info is very helpful.i emailed my op friend and should hear back in a day or so.
Hi mate,interested to know how you got on as i have what sounds to be same thing??
Quoted from dangermouse007:mrgone said:thanks,pinmike. the info is very helpful.i emailed my op friend and should hear back in a day or so.
There's plenty of advise in this thread. Did you complete it all?
op friend has been backed up with work. im still waiting on him for board repair. as soon as i get that done i will post results.
Quoted from DCFAN:Don't feel bad mrgone. I just had my first potentially big problem with my LOTR this afternoon. The ball went into the tower VUK and then it started doing a ding, ding, ding noise and suddenly the DMD said there was an operator error. Just a hunch, but I have a feeling either a fuse blew or the transistor failed (or both) for the VUK. The ball is just sitting in the VUK hole below the tower and does not try to kick it out.
Don't want to hijack your thread, but since the thread bubbled back up and you are still waiting to fix, I thought I would update my problem from a few posts up.
My problem was that the Orthanc tower VUK had one wire broken off at the solder. I simply soldered it back and that fixed the problem.
im putting together an order of parts from pinball life. what transistor does lotr use for the ring magnet? i cant find it anywhere in the manual. granted,im on my 4th margarita.
i have got to stop ordering parts when im drinking. anyway,thanks for helping out.
Quoted from mrgone:what transistor does lotr use for the ring magnet?
Here you go Sir...This is the one and is more durable.Q6 is the Transistor location on the driver board.
http://www.pinballlife.com/index.php?p=product&id=190&parent=0
update,i decided to try and replace the bad transistor myself. i watched a how to video on youtube.result,success! hey, it works. cool! my 1st try at soldering on a board and it worked. it was really fairly easy. to remove the solder i used the vacuum type desolder thing.
now if i can just get the left flipper back on line it will be 100%
I know this is an older thread...but I am a noob and this thread helped me immensely. My magnet stopped working as well. I would have never even thought about checking the fuse...but checked it...and sure enough it was blown. Didn't even need the manual to find its location as it was stated above. Put new fuse in...played three games and it works great now! I love pinside!! Thanks guys!
This page was printed from https://pinside.com/pinball/forum/topic/another-noob-questionmagnet-on-lotr-not-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
