Quoted from usandthem:Just pointing out that there is no way, shape, or form that drop downs should be a problem on a 2013 pinball machine. Maybe if Stern implemented LCD's on their pinballs finally and those were troublesome, that might be one thing. But problems with drop downs? It would be like Ford suddenly having trouble with their steering wheels.
You're grossly oversimplifying the situation. The drop target assembly on MET is an all new assembly. Initially, after seeing the underside of one, I figured everything but the plastic targets themselves was new. Now, I'm thinking the targets are new too. It's a much more streamlined assembly than the one used on WOF. Way less materials. Material cost per unit has to be cheaper than the WOF assembly. If they can get the bugs out, it will help keep costs down.
As I've said before, Stern is making a lot of changes lately. They're moving to new boards, LED lighting and trying other new things. Sales were up 30% last year, so they can afford to try new things. Things should settle down soon, but for the near future, any new game you buy from them is taking a slightly bigger chance than you would've buying five years ago.
The good news is that they're making way, way better games these days, once you get the bugs worked out. I'd rather play a MET pro with brickish drops than an IJ4 in perfect working order. Not even close.
