Anyone have a picture of the back of the monster slide plastic? I have the plastic and two cut wires. Not sure what socket/socket bracket goes on the back and can't find a good picture.
Thanks in advance!
Thanks in advance!
If you are talking about the ramp behind the board then...
No picture but the two parts of the ramp slide together (one overlaps the other) and then there is a screw that goes through both pieces into a L-bracket that is mounted to the board.
Or maybe the attached pic it what you needed. My wires could be wrong since I had that problem but not sure if this pic was before of after I fixed them.
The board missing or damaged? If it was damaged I would just jump out the traces and if its missing you could make one with a breadboard.
This is the only place I've seen one available Mystic.
http://www.pinball.co/Products/17082-c-13375.aspx
Marco has this one but, I don't know if you'd want it since it isn't the original.
http://www.marcospecialties.com/pinball-parts/A-20158
Good luck buddy!
worst case I get one of these bad boys and get to moddin.. $1.25 better than $8.75 if it's not gonna be OEM anyway!
http://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=077-5029-00
I think I may have a line on one though from a pinsider..
Quoted from mystic:I'm convinced the Australians are hoarding all the rare and obsolete parts.
You better beleve it.
Try this site, I have seen the lamp holder that goes in to the PCB, they may have the PCB as well.
http://au.mouser.com/Optoelectronics/Lamps-Holders/Lamp-Holders-Accessories/_/N-wpbs/?No=75
This page was printed from https://pinside.com/pinball/forum/topic/another-elvira-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
