I'm pretty excited about this.. it's a project that I've actually had sitting for over a year now. I've wanted to explore other ways of possibly replacing NVRAM without removing the original RAM chip from the game. Well, here it is... upgrade your game to NVRAM (no batteries!) without unsoldering the existing RAM!!! Just minimal modifications are needed to do this and the modifications can even be done while the board is still in your game if you're comfortable with a soldering iron!
As many of us are aware, Williams System 11 games usually had their RAM chips soldered directly to the board from the factory. To replace the original RAM with NVRAM usually requires the RAM to be cut off, pins desoldered, holes cleared of solder, and a socket soldered back onto the board. That works & is a clean solution, but it's out of reach for some people & there's always the risk of pulling solder pads/traces or otherwise harming your MPU board. I sell 6264 RAM replacements on eBay and normally recommend if your MPU is fully working, leave the RAM soldered in and use a remote battery pack. I wanted to offer another option though.. and I think this will work great for some people.
Installation / Minor Modifications to MPU
This NVRAM adapter board plugs into one of your game EPROM sockets and the game EPROM then plugs into a socket on the adapter board. You then snip a leg on Q40, pull the leg up and solder a wire to it (this is the chip enable signal for the RAM). Next, you solder a wire to U31 pin 8 (this is the read/write signal for the RAM). Then just connect those wires to the adapter board & you're done! No more batteries!
This mod should take less than 5 minutes for people experienced with a soldering iron since there is really no need to pull the MPU board from the machine and there are minimal modifications being made. The original soldered-on RAM does not need to be removed. It will stay disabled. If you sell the machine down the road, you can easily reverse these modifications and re-enable the on-board RAM.. then use the NVRAM adapter in another machine.
Steps can be seen below. Yes there is some soldering involved and you should know what you're doing to attempt this type of mod, but for many people this is far easier and safer than cutting RAM off the board and should be a piece of cake for anyone that is comfortable using a soldering iron.
***PRE-ORDERS & COST***
I'd like to get an idea of how many boards I should have fabricated, so let me know if you're interested by commenting on this thread or sending me a PM! If there's a large enough response, I'll make the PCB order & should then be able to start shipping them in about 2-3 weeks (takes a bit of time for boards to arrive & then will take a few days to assemble).
http://www.pinitech.com/lab/sys11_nvram.php
Cost will be $30.00 shipped. I'll include a replacement transistor for Q40, wires needed for modifications, fully assembled adapter board with NVRAM and instructions. Discounts will be given on 3 or more adapters.
I'm hoping this goes over big because I would really like to see this happen. Please contact me or comment on this thread if you're interested!
