(Topic ID: 209706)
[Announcement] PinSound reveals the PinSound +
By PinSound
2 years ago
  • 129 posts
  • 56 Pinsiders participating
  • Latest reply 20 days ago by Mr_Tantrum
  • Topic is favorited by 40 Pinsiders
    There are 129 posts in this topic. You are on page 2 of 3.
    #51 1 year ago
    Hey Nicolas & Timothee. Congrats on the new board release and continual improvement on the product. Looking forward to stopping by your booth at TPF on Saturday to say high. Hard to believe a year has passed since I originally purchased my PinSound for Getaway, along with all the orchestrations I've created for it. BTW, I was doing some YouTubing a few weeks back and noticed that someone customized the virtual pinball version of Getaway to use one of my PinSound mixes - cool!
    Wish I had more pins, and I would contribute more as I know that this is one of the things holding the PinSound back from even greater success than what it has had. I don't know the answer to this, but if you think of a way to utilize the community for orchestrations I am happy to contribute however I can.
    #52 1 year ago
    Quoted from Mr_Tantrum:
    Can virtual pinball/pinmame be leveraged as a tool for this?
    #53 1 year ago
    Quoted from Rdoyle1978:
    Not sure which mix is the 'enhanced' mix ( did you see that term used somewhere?) but Granner's DCS mix is available for use with both boards. There are several other mixes available as well. The available Granner mix is all the original stuff Granner had done which was finished. There are a couple music tracks that were pulled from the music as-released because they weren't done on the DCS mix
    #54 1 year ago
    Quoted from Reznnate:
    I personally don't have experience with VP, but I'm assuming so based on what I've seen on YouTube. Check this dude out since he applied one of my PinSound orchestrations with custom voice overs and he also added my custom designed Donut Heaven decal in the styling of Krispy Kreme. Was hoping for at least a shout out, but oh well.
    #55 1 year ago
    vpinmame can use PinSound soundtracks. There used to be 2 ways to do it, one without using PinSound Studio, and one with. Apparently they've changed the number scheme of the folder names, so now you have to use it with PinSound Studio running in the background. There are still issues with the Data East sound engine in PinSound Studio 0.9, but they are supposed to be resolved in 1.0. I'm in a bit of a holding pattern because of this as the card doesn't always act the same as the software playback because of this and it makes composing and testing soundtracks a bit of a PITA. Also the card will behave differently unless you have a config file that tells it that its a Data East.
    It's a great way to check out new orchestrations though, I've got a few running on my pincab. You don't have to mess with the virtual table settings, you have to change vpinmame settings to look for pinsound.
    #56 1 year ago
    any in stock anywhere? if not then when and where?
    #57 1 year ago
    If anyone's gotten a + board, can you PM me? I have a question on it - to compare mine with yours.
    #58 1 year ago
    Anybody with a Pinsound plus running the board in a IJ? Please pm me I need some data and assistance. Thanks!
    #59 1 year ago
    I'm trying to join Pinside community http://pinsound-community.org/forum/index.php?/files
    After several attempts, I'm not getting a confirmation email or a response from the contact administrators page. Am I missing something? Is there anywhere else to download files for T2, TZ and IJ?
    #60 1 year ago
    Help. What is wrong here? New pin sound board and have color LCD. Sound and download worked fine. I got no dmd. So on a Wpc 95 install does it use 2 extended ribbon cables or 1? My kit only has one but there are 2 sets of instructions that show 1 used and both for Wpc 95. Confusing. Pic of working Wpc install please
    #61 1 year ago
    Does this board have a switch to change between mono / stereo audio?e
    #62 1 year ago
    We figured it out. So frustrated I didn't look for the obvious. Ribbon cable not seated all the way. Fail. Now working
    #63 1 year ago
    Anyone here perhaps have a copy of the .psrec file for Doctor Who that they might share?
    Installed a PinSound+ board that I picked up at TPF in mine and while it sounds really cool the levels between the music/sfx and voices is WAY off (can barely hear the voices if anything else is playing) in all of the alternate mixes so would like to do some adjusting through the 'studio' app but the .psrec file for Doctor Who is not in the distribution set. Seems odd since a bunch of others are...
    Does not appear anywhere in the PinSound forums or download areas either that I can locate.
    Thanks;
    #64 1 year ago
    Quoted from ArcadeTechNerd:
    Thanks;
    You can make your own. Add a config file to the USB stick and it will start recording your games.
    https://www.pinsound.org/configuration/
    #65 1 year ago
    I can't wait for these to come back in stock. Been on back order 3 weeks for almost 2 months. Though I just looked and it's actually down to 10 days.
    #66 1 year ago
    Quoted from cabuford:
    Yes, was aware of that but also that unless you hit every mode, sub-mode, and possible combo in the game you will not get a complete capture of all of the possible events which is what I was hoping to avoid.
    But if that is what it comes down to...
    #67 1 year ago
    Take the glass off - it only takes a few minutes. Be careful of the mini-playfield!! It WILL chop your finger off
    #68 1 year ago
    I found it easier to make my own, because I could take the glass of, create the sequence of events I wanted, and then work on that specific section in PinStudio. Make a few files for different scenarios.
    Also if you want to just get the voices louder, you can use the duck and gain features to change entire folders of sounds (you probably already know this).
    #69 1 year ago
    Can anyone give me some advice? I've just bought Pinsound Speakers to go with my Judge Dredd pin with Pinsound board (original model), Stereo 2.1 cable and all. I've done a few custom mixes (music only, but sounds sooooo much better!) but since no one has done a full enhanced sound mix how do you go about re-recording custom voice and SFX? I have DAW's and Audacity but I am not a voice artist and do not have the ability to re-create sound effects with stock library effects.
    I've tried approaching some Pinsiders to possibly help me on this end (i.e. do an enhanced sound mix for JD) but no one wants to bite.
    What to do? (First world problems I know)!
    #70 1 year ago
    Quoted from JediPimp:
    Get the original game mix from the Pinsound Community. Go to Youtube and download the Dredd Soundtrack, clips from the movie, etc. You can then replace whatever you want in the callouts. I would worry about SFX last. You can do a "pseudo-stereo" effect on music or SFX (or voice, if you want, although I wouldn't) using an Audacity plugin. Good luck.
    #71 1 year ago
    Thanks Rdoyle1978 you've given me something to strive for.
    #72 1 year ago
    I will say, that before I leave this hobby I am going to put up a killer mix for TFTC and goldeneye unless someone else does it before me. The board is just too expensive for me at this time.
    #73 1 year ago
    The only thing I don't like about using movie footage for voice and sfx sound bytes is that it's hard to find clear samples. They're usually mixed in with background sound effects and music and can sound messy.
    #74 1 year ago
    You should try extracting the centre/dialogue channel audio from the movie/DVD/Blu-ray. That gives you some pretty good results. And you can enhance with some EQ and a bit of room reverb etc. Works great.
    And YouTube Is a great resource for sound FX.
    #75 1 year ago
    Does the new pinsound board have a stereo switch? Can't seem to find one...
    #76 1 year ago
    Just installed pinsound+ in CFTBL. PP speakers and PP upgraded sub. Wools file set.
    This is a dramatic improvement and I would recomend this to any CFTBL owner.
    Anyone hear rumors about when the shaker add on will be available?
    #77 1 year ago
    Quoted from burningman:
    They aren’t rumours - they’ve been official on this for 2 YEARS. It’s more like vapourware
    #78 1 year ago
    Man, want to down vote the news, not the messenger.
    #79 1 year ago
    Oops yeah that’s what I was trying to do
    #80 1 year ago
    Quoted from Coyote:
    Are these relaly effin' necessary? I mean, can we save $50 by not having them? How many people play with the backbox open to admire them? And now, admire them *with color*!
    I do. Seriously. They are way cool. LOL
    Chris
    #82 1 year ago
    What’s new or fixed in the update?
    #83 1 year ago
    Quoted from FlippyD:
    No change log was listed
    #84 1 year ago
    Quoted from docquest:
    First person to update their pinsound in a LOTR and confirm here that whitestar mix-switching is fixed, wins an upvote.
    #85 1 year ago
    Hopefully they fixed the delay that was occurring on some of the mixes for certain games (IJTPA comes to mind)
    #86 1 year ago
    Anyone have issues with the update?
    After the update my USB doesnt seem to work. When I turn on the game, the pinsound board says I have a USB error and tells me to reboot the game. It keeps doing it each time I reboot.
    This is the same USB I was using before and it worked fine before the update. I tried a new 3.0 16GB USB drive and that has same issue.
    #87 1 year ago
    It might be something with the USB structure - are your files and folders the same on the drive that they were before?
    #88 1 year ago
    More
    Yes
    #89 1 year ago
    And to be sure I put the original zip files from the pinsound site on the USB so it would rebuild the folders andithadthe same problem.
    #90 1 year ago
    You need to reformat your USB drive before transfering the zip file. Same problem here and that is the solution som far.
    1 month later
    #91 1 year ago
    New firmware again v18.8.0 (19 Jul 2018): https://www.pinsound.org/wp-content/uploads/releases/pinsound-update-0188.psrom2
    Seems like the update file is removed after installation, no need to remove flash drive... just reboot.
    #92 1 year ago
    Quoted from zoda:
    FYI this firmware looks to be compatible with both versions
    #93 1 year ago
    Interesting... Today this link gets a "404 - page not found" error.
    Tweak it a bit and the v18.7.0 file can be downloaded. Wonder if a new bug popped up?
    #94 1 year ago
    I think I may have found a couple bugs; playing TZ today I did hear at least twice where I think it played the wrong sound
    #95 1 year ago
    I got a WHOLE bunch of PMs asking about what USB drive to upgrade to -
    For those who don’t know the history of this- there are several outstanding mixes out there for PinSound games - in particular is the amazing Indiana Jones mix by Endprodukt. The mix has a million callouts and CD quality orchestra sound (stereo!). But on a lot of boards, it can exhibit delays in the sounds - e.g. you’ll be playing a game, drain, and THEN the game plays the sound for the last thing you did with that ball that just drained. Frustrating to say the least.
    Well. I am proud to say we’ve identified this particular problem as definitely related to the speed of the USB drive installed to the board. I bought several super-fast usb drives and tested them on IJ and on Twilight zone (which does not typically exhibit delays)
    It worked. No delays after several games, quick plays, long plays, and by a player much better than me.
    Of note is that the stock USB drive that comes with the board is .. pretty much a piece of crap. Get rid of it!
    Here is the link to the killer drive
    SanDisk Extreme CZ80 16GB USB 3.0... amazon.com link »
    #96 1 year ago
    When I bought my board it didn't come with a USB drive so I bought the one from pinsound. How does the ScanDisk Ultrafit 16GB one they sell compare? I like the small form of it.
    #97 1 year ago
    Quoted from shepP:
    I don't have one of those, so I can't compare directly. That is a different drive than the ones the Pinsound 1 shipped with (which was fairly crappy). I believe the Sandisk Ultrafits are USB 3 and are relatively recent, but their -theoretical- top speed is 150 MB/s, and I measured the Cruzer at 190 -
    however, PinSound needs to do what is called a "random read" to work right, and this has to be tested directly on the actual drive to really know. some drives are super fast at doing a basic sequential read (reading values from the disk that are physically placed next to one another on the disk in sequence), and have horrendous random read speeds.
    So it's probably fine, but I can't say for sure. The disk I posted is the second fastest one you can buy right now, so it's pretty good, but by no means the only option. You don't necessarily need "the fastest" drive, you just need one that is fast enough the game doesn't lag. And boot up is faster which is nice.
    #98 1 year ago
    Where can I find the Indiana Jones mix by Endprodukt? Can someone help me out?
    #99 1 year ago
    Quoted from Jimmyhonda:
    PM him, he will send you a link and politely ask for a couple of bucks donation. Give it to him, he put in an incredible amount of work on that mix. I would guess hundreds of hours
    #100 1 year ago
    Quoted from shepP:
    Sandisk Ultrafit is OK, no delay with huge mixes.
    $ 9.99
    $ 209.99
    Filament Printing
    $ 79.95
    $ 139.00
    Sparky Pinball
    $ 69.99
    $ 50.00
    The Pinball Vault
    $ 79.95
    pinballmod
    $ 86.00
    The MOD Couple
    Meph's Mods
    $ 99.99
    $ 79.00
    $ 78.00
    Lighting - Backbox
    $ 48.00
    $ 54.00
    $ 234.99
    $ 26.50
    The MOD Couple
    Various Novelties
    Game Room Info Shop
    Hookedonpinball.com
    $ 399.99
    Top-Notch Target Shields
