Now live, in stock, and shipping from Pinball Life...
www.PinballLife.com
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
www.PinballLife.com
Rob Anthony
Pinball Classics
Ultimately my goal is no more batteries on boards, ever. I've been asked a couple of times for stickers for games that use other brands of NVRAM. I think it's a good idea to help keep boards battery free.
So, free stickers for all!! Available to anyone that wants them, NO BATTERIES NEEDED! stickers. Doesn't matter where you got your NVRAM. Just send a self-addressed, stamped envelope, how many you'd like, and the type of NVRAM, to the address on my site, and I'll send you however many you need.
The non-anyPin version of course won't say anyPin on it.
Rob Anthony
Pinball Classics
Any of the versions of anyPin will work in all of your games (except Metallica, it's not needed), except the 5101 version.
BttF and SW will be socketed from the factory, quick install. The Williams games didn't have their RAM socketed from the factory, but could have been done their life. You'll need to check the RAM in those, U8 in the WPC, and U25 in the System 11 games.
Rob Anthony
Pinball Classics
Quoted from Borygard:
Rob Anthony
Pinball Classics
Great, thanks! So can I order the DMD+ which I believe is the least expensive option? Thanks again
Yes, anyPin DMD+ will work in all of those. Shoot a photo of U25 in the F14, or send me the numbers on the chip and I'll set up anyPin for that game before it ships.
Rob Anthony
Pinball Classics
Any of the versions of anyPin will work in all of your games (except Metallica, it's not needed), ...
Rob Anthony
Pinball Classics
I'm curious.. why is not needed? Is that on any new-ish Sterns?
New/sam stern games use a coin style battery. Those batteries have longer life and are less likely/don't leak.
Quoted from Rickwh:
Exactly. I can likely swap the RAM on a SAM board with NVRAM for anyone interested, but really don't see the need.
Rob Anthony
Pinball Classics
@Rob:
Is there something to observe in a Rottendog WPC98 CPU Board (Part Number MPU089). In U8 there is a U62256ADC07LLG1. I have no experience with the RD-CPU-Boards. Are there jumpers to be changed?
Quoted from german-pinball:
@Rob:
The Rottendog MPU089 uses a socketed RAM at U8 and needs nothing more than to install the anyPin. The 62256 at U8 comes out, anyPin set as 6264 goes in, done.
Rob Anthony
Pinball Classics
Quoted from Nevus:
Rob, can you install whatever part is needed in my MM and Banzai Run at the TPF? I'll have them there and it would be way easier if you help.
Follow up post
I purchased this for my MM and Banzai Run at the Texas Pinball Festival. Rob installed them for no charge and they worked perfectly. This is a great product!
Thanks guys!! Great to see batteries being eliminated!
Rob Anthony
Pinball Classics
Just a reminder for anyone going to an upcoming show I'll be set up at. If you bring a game to the show for others to enjoy on free play, I'll install your anyPin for free. Just bring me the CPU from the game and your anyPin and I'll give it back to you with a new socket and anyPin installed so no batteries are even needed again.
Also, I'm offering any anyPin install special at shows. Bring me your boards and your anyPin, and I'll install a socket for the anyPin for only $15. This special is good on any version of anyPin, not just the anyPin DMD+.
Rob Anthony
Pinball Classics
Installed my first AnypinDMD+ today in a Cyclone (System 11b) - Figured I'd document it. Maybe give somebody else on the fence enough courage to do their pins, and do away with evil batteries.
Even though the batteries in the game now are good - at some point, something leaked on it a bit and the connector is corroded. It hadn't crawled down the leg to get to anything else yet though. At least, not that I could tell anywhere.
Since that thing is infected, it's got to go. I don't have a big enough tip for my Hakko 808 to do the legs on that mother, so I snipped them and then just heated each one to remove.
Since I'm putting it in a System 11, there was a little prep work to the any pin. It came set for 6264, so I had to desolder that jumper and connect the one for 6116. Then I had to add the 2 - 10k resistors to the bottom. I only had through hole resistors, but they worked fine and weren't too much of a pain. Hardest part was bending the legs to line up nice.
Since I'm using it as a 6116, I removed the extra 4 pins from the socket while I was at it. Just cut the socket strip and used the hakko desolder gun to get them loose.
Then On to the board! The victim:
Note how it sits back in the board away from the marked #1 pin - don't be fooled!
The desolder gun makes removing junk from boards SO easy. Really glad I picked that thing up from the pinside group buy thread.
Nice and tidy. Also empty.
Soldered in the new one as cleanly as my inexperienced self could.
Great Success!
Just one more thing to do ...
i bought my R&B at PATZ, and before i even loaded it up, i had one of these installed. Great product.
You're awesome man!
Rob Anthony
Pinball Classics
I just installed 8 of them in all my B/W machines, they are great!
After doing all of these, I just put one in my Stern without looking and used the same orientation...
Stupid me, on whitestar they are upside down...gave a nice puf of smoke
Quoted from lyzanxia:
...whitestar they are upside down...gave a nice puf of smoke...
They are guaranteed for life. Send it back to the address on my site for a replacement.
Rob Anthony
Pinball Classics
Thank you kindly for the offer, but I am in Europe and the shipment would be more than it's worth
Great product at a great price, I love it!
Great product Rob! Just installed it to my Simpsons Pinball Party. Works great and yeah, the notch faces down on that board layout.
Sidenote: Rob was super nice in person when I bought it from him at Pin-A-Go-Go.
Quoted from pinbob:
^^^^ Well said! ^^^^ Rob's the best! He's been over a number of times when passing through after PAGG. Finally have all my pins NVRAM'd out, Great product and a terrific guy too!!
Quoted from shimoda:
Just dropped one into my Rottendog MPU089 in Funhouse, took about 20 seconds. Glad to get batteries out of yet another machine!
Yeah, Rottendog boards are easy-as-pie, the RAM is always socketed.
Rob Anthony
Pinball Classics
Rob has great customer service! He got my rollergames fixed up nice and it's playing great. I will be switch all of my games to the anypin as I go through them. Can't wait to get my firepower back and working!
Game Plan games used different RAM for settings than any other manufacturer. So unfortunately anyPin NVRAM Battery Eliminators don't currently support Game Plan games.
A solution is being worked on though, so hopefully soon we can announce support for Game Plan games.
Rob Anthony
Pinball Classics
It really should be noted more clearly on the lockwhenlit website where to install the RAM and what orientation it should be when installing. I had a super hard time finding this tiny bit of information on what orientation to install the Anypin DMD+ on a Stern Whitestar.
Both issues you state are clearly addressed on the lockwhenlit website. There are links to installation location and type of NVRAM used on the website (Stern WhiteStar(U212)[6264] for example) as well as configuration/installation instructions.
Even if you don't read his links, you match the orientation of the chip you are replacing. Even if you've removed the old chip and it's gone, you can use the surrounding chips and/or PCB screen to determine proper orientation.
Sorry jkyeakley for the delayed reply. I've taken a PinSide sabbatical over the last couple of months.
I currently have no plans to be at the Cleveland Show.
My current show schedule for this year can be found here...
https://pinside.com/pinball/forum/topic/borygards-2017-show-schedule#post-3412822
Rob Anthony
Pinball Classics
How hard is this to do on scared stiff? Is chip socketed? A little nervous trying this on a friends pin
Quoted from billsfanmd:
Williams stuff is not socketed. It's a soldering job.
Needs to be soldered. If you have not done it before dont practice on your friends game if you want to stay friends.
Quoted from fiberdude120:
Thx. That's what I figured
Which chip am I replacing
Interesting looking RAM there, never saw one with a groove running the length of the RAM, without any standard notch. But I'm not working with 100s of WPC machines or MPUs, so maybe it's normalish?
Quoted from acebathound:
Yes. I see that 62256 in many WPC95 boards and even pulled out one of the Sharkey's Shootout.
It's a Fujitsu thing.
Those are some tiny, tiny solder pads and traces. Even with sniping all the legs and unsoldering one pin at a time it's still walking on egg shells. I've done 3 WPC boards and that way and still pulled two pads. If your running to hot it will melt the adhesive right off the pad. Have him send it out.
