@PPS--Thank you for bringing new pinball overlays to market. Before they were not being made (for various reasons). Now in the near future those that want them, can buy them.
This is a good thing.
Best regards,
Tom
Best regards,
Tom
Herb Silvers did a pretty good job on the KISS and others mylar's that he did - considering the technology he had available at the time. If the oldtimer's would speak up, there were a few makers a decade or so ago - some good, some not so good. I don't think any were licensed.
I 've seen a High Speed that was spot on, and a High Speed that had cloudy inserts and was terrible. I'll reserve judgement until I've seen one done with the original graphics from Rick or "most" of the licensed vendors (reputation means everything).
Quoted from vid1900:Yes, this is the best idea and certainly worth $200.
Just print them on the back of thin plexi.
No sanding.
No leveling inserts (unless very proud).
No wrinkling under posts.
100% reversible.
No clearcoating under decal.
No clearcoating over decal.
I remember several years ago there were overlays made for Bally Eight Bally Deluxe like this. They were like sheets of clear acrylic plastic about the thickness of Formica that had all the artwork and even the wood grain printed on the reverse side. When applied they required no clear coat. You simply glued them on top of the old playfield. I never played a machine with one installed but they looked cool. I imagine the game play was faster than it originally was.
Quoted from kennyp2112:I'll let you know how it goes
Where did you get the FG overlay?
Those type of overlays (FG above) are pretty problemmatic and are 'first generation' overlays, and are the result of a printer that cannot print white. You have to cut around the inserts and either use what was there or piece in insert decals. The overlays we would provide are transparent so include the insert artwork as well as white where it needs to be as well.
rick
Quoted from PPS:Those type of overlays (FG above) are pretty problemmatic and are 'first generation' overlays, and are the result of a printer that cannot print white. You have to cut around the inserts and either use what was there or piece in insert decals. The overlays we would provide are transparent so include the insert artwork as well as white where it needs to be as well.
rick
Sounds like the way to go.
That way you just strip the top of your Playfield, sand it back, and away you go.
Nice and easy.
rd.
yes, piecing in the inserts will cause ridges and that can be a problem with the clearcoat, etc. so it's better to have the mylar so there are no ridges, as ridges cause issues with clearcoat ...
Quoted from PPS:you guys would eat your own children if you could! lol
I asked my children and they don't feel this is a good idea.
Now back to eating people trying to make pinball parts to fix our games.
Quoted from rotordave:Please make me a Rolling Stones one. Please.
rd.
possible, but need to get someone from rolling stones to be ok with it.
I recall that Elektra had a very thin piece of plexiglass that covered the middle (main) playfield. Is it not feasible to have some type of overlay created that is then covered by a perfectly cutout piece of plexiglass?
Quoted from BallyPinWiz:I recall that Elektra had a very thin piece of plexiglass that covered the middle (main) playfield. Is it not feasible to have some type of overlay created that is then covered by a perfectly cutout piece of plexiglass?
Rick made it clear that he does this for a living and isn't welcoming of discussion.
Quoted from PPS:possible, but need to get someone from Rolling Stones to be ok with it.
I'll shoot Mick a text message now and ask him nicely.
Or you could just make me one and I can "trial fit" it for you to see how it looks.
rd.
Quoted from Wolfmarsh:Rick made it clear that he does this for a living and isn't welcoming of discussion.
no, you can feel free to discuss amongst yourselves ... not a problem.
I can't even line up the screen protector on my iphone, there is no way I would even attempt trying to install a giant playfield decal/sticker.
Wolfmarsh and Vid have the right idea with somehow printing on the back of a playfield protector that you can just lay on the playfield. Make it easy.
Overlay going on almost 3 years. Had minor lifting near a few posts that were glued down again. I'm no expert but things can be done even better today! Just not my area for production. I hope Rick takes this to a higher level doing it himself, or with a similar producer on demand. Anything that can improve the overall looks of old pinball games is great to keep the history alive.
You spray it with a solution, line it up, and squeegee the water out - it can be slightly adjusted until it dries. I think the KISS I did took about 15 minutes, and that's because it didn't line up properly and I had to find the place where it was least noticeable.
The biggest pain in sanding everything off of the playfield and leveling the inserts.
Quoted from ktrain315:I can't even line up the screen protector on my iphone, there is no way I would even attempt trying to install a giant playfield decal/sticker.
We would like to keep some lists of which overlays people are interested in and will have a PPS Forum topic on where we can keep track of interest levels for the 40 or so different titles. Will update pinside when they are available.
I never thought I'd see the day, big cheers to Rick for making this happen.
Many people prefer overlays not only for restoring on a budget, but some of us just want to take the top layer off, sand, clear, install overlay, clear, rebuild. Many of us are scared to remove the bottom layer where all the wiring, switches, and lamps are mounted to. I also like that you're printing on clear mylar (no cutting around inserts), that will make it much easier to apply.
I'm sure this will making storing them much easier than blank playfields too.
Since you're getting into the film printing process business, I'd be curious if there are any plans on reproducing out of print backglass translites as well?
Man this sure answers an old thread I started awhile back. https://pinside.com/pinball/forum/topic/pf-overlay-why-not
I sure hope the quality is there to keep everyone here from having a REAL gripe. Seems like a good thing for the hobby, Thanks PPS!
Can a Firepower overlay be done since CPR already made reproduction playfields and they are nowhere to be found?
Quoted from PPS:The mylar will be digitally printed (these are high end $75K+ digital UV solvent printers that can print up to ~1500 dpi, and white, and clear) on mylar - the mylar would be typical 2-3mil adhesive backed mylar. The mylar will be 'die' (cutter) cut for holes, outlanes, etc. The digital print will be higher resolution than silkscreened and will also be registered well (as opposed to silkscreening). So long as the colors fall within the colors the printer can print, they will very nice (we won't do or will have big caveats for playfields which have neon,etc - can come close but never spot on).
rick
So to clarify, it sounds like the printer is a CMYK(W) printer, and can't do 'spot' colors?
(Not a problem, just asking, as that would be one reason why some colors couldn't be done - because CMYK can't reproduce them.)
Neon colors like orange don't really get made correctly by combining other colors together.
You need to have "neon orange" as a spot color.
Quoted from vid1900:Neon colors like orange don't really get made correctly by combining other colors together.
Yup, exactly what I was asking, if it was a CMYK(W) printer or not.. Thanks for clarifying.
yes CMYK+, spot colors would need to be screened on an overlay, which I guess could be done, just expensive setup.
Sounds like a wonderful idea. My Transporter the Resuce's playfiled is beat to sh!t. Can't even read half the inserts. This sounds perfect, as it will be a cold day in hell if that playfield ever gets remade
Ill buy it!
I can see two viable methods for this.
The more labor intensive but better looking way would be to be printed on clear mylar (or other substrate) with White then spot colors then CMYK and clearcoat sprayed after application. This would present the best looking final product but is the most labor intensive. Maybe offer it two ways, one with ink side up for clearcoating afterwards and another with another clear Mylar on the top of the ink so that clearcoating is unnecessary.
The other easy method would be to reverse print this on the underside of the acrlyic playfield protectors. This would possibly be installed without needing to sand the original playfield at all. Just remove most of the top components and install. This is more novice friendly, requires the least amount of time, and would preserve what is still on the playfield for any future owners that might want to restore the pf with paints by hand.
My preference is new playfields but lacking that I would be for the first method, Thinnest top printed mylar with no top coating so that I can clearcoat over it.
Quoted from PPS:yes CMYK+, spot colors would need to be screened on an overlay, which I guess could be done, just expensive setup.
Can you get in touch with me please Rick?
I'm probably the only one here who would be interested in a Hyperball overlay, though I'm uncertain how it would be done. I believe it is some sort of giant piece of polycarbonate or some similar material glued over wood. Very interested in this and a plastic set (well, that's basically the whole playfield, isn't it?).
Quoted from pinballtec:I'm probably the only one here who would be interested in a Hyperball overlay, though I'm uncertain how it would be done. I believe it is some sort of giant piece of polycarbonate or some similar material glued over wood. Very interested in this and a plastic set (well, that's basically the whole playfield, isn't it?).
The pf isn't glued to the wood it's just held by a few screws and the posts. Mike
We'll need to look at that one - but we can certainly print on polycarb and laser cut as required.
rick
Quoted from PPS:We'll need to look at that one - but we can certainly print on polycarb and laser cut as required.
rick
Thank you for the reply!
Quoted from kbliznick:This would possibly be installed without needing to sand the original playfield at all. Just remove most of the top components and install. This is more novice friendly, requires the least amount of time, and would preserve what is still on the playfield for any future owners that might want to restore the pf with paints by hand.
One of the reasons for sanding the old playfield for a full screened mylar is to remove whatever remains of screening (Text) on top of inserts. It would be very difficult to insure both the new mylar print itself, as well as the alignment once installed would be dead on all over the playfield.
But, with a mylar protecting the playfield, your clear coat does not need to be as nice as it would if it were the final top coat.
Printing Pantone spot colors on a CYMK/process printer will never be 100%. Never. You're taking one ink color(spot) and converting it into separate percentages of four different colors(CYMK/process). You'll see the most variance in your greens and blues. It takes a lot of trial and error, even after a calibration, to get the colors just right. Typically, you end up readjusting the CYMK numbers in the computer before it even prints to get it to output the closest to the spot color you're aiming for.
Quoted from Miguel351:Printing Pantone spot colors on a CYMK/process printer will never be 100%. Never. You're taking one ink color(spot) and converting it into separate percentages of four different colors(CYMK/process). You'll see the most variance in your greens and blues. It takes a lot of trial and error, even after a calibration, to get the colors just right. Typically, you end up readjusting the CYMK numbers in the computer before it even prints to get it to output the closest to the spot color you're aiming for.
We color match to the original color. With the exception of fluoro, metallic, and a few 'very bright' colors, we can usually hit the colors and when we cannot we will note that. We've been color matching pinball artwork for years ...
rick
Quoted from PPS:ES should be in the works, but I need to check with supplier on this ...
rick
Would love to put this on my 2015 Christmas list.
Any chance of commissioning another run of ES backglasses? Kicking myself for not picking one up a couple years ago.
What if you made a sandwich of two acrylic sheets, one with the print under and the other one glued underneath. That way you could protect the print and make it a quick install.
Either way I think it will end up great.
Looking forward to see some pictures of it.
Axl
Quoted from mario_1_up:I see a lot of Hard Body restoration threads in the future.
Or how about BMX re-themes?
-c
or what about a spellbinder overlay?
http://www.ipdb.org/search.pl?any=hyperball&search=Search+Database&searchtype=quick#3727
-c
How about putting a Playfield Protector over the overlay. http://bayareaamusements.com/Merchant2/merchant.mvc?Store_Code=BAA&Screen=PROD&Product_Code=GS-JM-PF-PROTECTOR I use these in my pins all the time.
Much prefer wood to overlay, Alien poker in my opinion would have a very good demand for wood there has been call for a long time for it, I sometimes I wonder wether the old school title's are just pushed aside so the later higher end can be produced and the overlay factor will do.
Quoted from PPS:we have a number of titles of games which are not popular enough to justify wood playfields but can be done reasonably well with Playfield Overlays.
Sorry don't believe that................Quick fix
Quoted from shlockdoc:Rick can you please please allow Stu to move forward with the diner mirrored back glass please.
Crickets, Stu? Rick?
This page was printed from https://pinside.com/pinball/forum/topic/ann-playfield-overlays-using-original-wms-art-cleared-by-wms-for-pps/page/3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
