(Topic ID: 1237)
Ammo Tumblers
By SealClubber
11 years ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 11 years ago by HHaase
    #1 11 years ago
    I am borrowing my buddy's ammo tumbler but he doesn't have any of the polishing media. Should I use corn, walnut or something else for the metal parts. I read it somewhere but don't remember which.
    #2 11 years ago
    Either are fine, they just give different final finishes. Walnut is a touch more aggressive, corncob gives a touch more shine, both are excellent choices.
    Just make sure to get real tumbling media if you use corncob, cutting corners and getting stuff with different grit size can be hit or miss. Supposedly you can get walnut shells for real cheap from pet places.
    -Hans
    #3 11 years ago
    I guess I will go for Corncob. Thanks. I will get the media at a gun store so it should be fine.
    #4 11 years ago
    You can buy walnut or corncob media at major pet stores much cheaper than a gun store. To increase the polish level add a little liquid car wax to the media. If you friend has a media separator you may want to borrow it too. I used to spend a lot more time reloading than I do playing pinball.
    #5 11 years ago
    Just make sure if you get the corncob at a pet store to get the very fine grain stuff, if they have it. Usually it's just too big, and won't get into tight areas as well.
    I'm going to give a couple other things a try in my own, I've heard that using silica sand works well, and I have a lot of glass bead to try too.
    -Hans
    #6 11 years ago
    Thanks for the replies. I ended up buying the corncob at Sportsman's Warehouse. I didn't read the pet store post in time.
    #7 11 years ago
    No worries really. Some pet stuff is great, some isn't. Having that initial "sample" to look for in the future really helps, as now you know what grain size you're looking for.
    -Hans
