After installing a light in the scoop with the power off, I inadvertently caused a short after the install. (Remember to replace the screws in the scoop before powering on and lowering the PF next time).
Two things happened.
1. Scoop lost power. - fuse discovered blown and replaced. Scoop is now working normally.
2. Scoop GI (one purple covered dome 555) is out. All other lights seem to be working. Can Anyone suggest to me what to test? I don't see any fuses? Is it a transistor? I traced the wire (purple/black) to what I think is the lower right connector on the board.
