Quoted from Betelgeuse:Did you add another color changing strip to the back? That was something I was toying with. I may just wait for your kit instead of messing with it myself.
The strip in back is a purple. It makes the characters glow.
Quoted from benheck:LED's are like low-fat cookies - use enough of them and it still adds up.
We tracked down the GI issue to a not-big-enough 5 volt trace going across the board to the GI ports. This is likely a by-product of the GI being one of the last things added to that design.
We have to use up the existing supply of boards before we can fix the Gerber files. In the meantime, Chuck is running an additional 5 volt line from the PSU to the GI, with an extra in-line fuse. This achieves the same result.
From what I can tell, 5v is not enough juice to run high quality 6.5v pinball leds. It is fine for the ablaze bulbs you guys chose and also fine for the 4 F'ing bright ablaze leds. The issue with the GI here in my opinion is that the ablaze leds used absolutely suck. And better lights cannot be installed because the power of 5v won't drive them. In either case, the add on kit I made lights up the entire game just like it did for WoZ and it does stuff you cannot do with just GI bulbs.
