(Topic ID: 183206)
American Pinball Houdini thread
By lllvjr
  • 12,182 posts
  • 649 Pinsiders participating
  • Latest reply 26 minutes ago by 27dnast
  • Topic is favorited by 162 Pinsiders
There have been 1,599 images uploaded to this topic. (View topic image gallery).
34 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 12182 posts in this topic. You are on page 82 of 244.
#4051 2 years ago
Quoted from rosh:
Here is a little secret, when you shoot stage alley or key lane, the pops are disabled for around 100 milliseconds or until the first hit of skirt, then they go live, this makes those shots through the pops a touch easier as nip of the edge of one skirt does not hose you.
I suggesting opening a ticket and Barry can work with you to see if something else needs to be adjusted relative to the trajectory of the ball.
Wow with out knowing that is hard to pickup.
#4052 2 years ago
Quoted from rosh:
That’s great thinking Rosh! My particular issue was on the outside of the pops so just a quick leaf adjustment and we were back in business
#4053 2 years ago
Got Magic Glass today. I have 5 Invisiglass in other pins. The MG is slightly better under my lights. The MG is flawless in appearance.
Played today and had an issue with the scoop. It usually works OK. It tried to put ball out 4 times then stopped. Had to reboot. Coil was set on 7, tried on 8(NG) and is now on 9. No other pins were on. Everything else is working great!
Houdini plays like my Williams pins and I like that. It is my favorite at this moment.
#4054 2 years ago
Quoted from rogerdodger:
Hi Guys:
I have played a few games on Houdini and am really trying to love it but I am 'on the fence' about buying one. I love the theme, art, LCD and toys but the gameplay didn't grab me. Having said that, I didn't know the rules, so was just shooting the balls around.
There seems to be quite a number coming up for sale or trade, with very low plays, here and in other pinball groups.
In hindsight, would all or most of you buy Houdini again, after owning it for a while?
No flames, please. Just helpful, honest, opinions will help me decide.
Thanks so much.
Roger
Hi Guys:
Thanks so much to all who responded.
I will shortly be ordering a Houdini, thanks to all your great reviews.
Roger
#4055 2 years ago
Quoted from Joe_Blasi:
That's what we want, to help them player without it looking like something odd is going on.
Quoted from Rdoyle1978:
Early on we were not happy with what we are getting as far as it making in through consistently, but after the tweaks were made between prototype and production it did not seem to be as much of an issue and we tried it without it for a bit, and it seemed like you could more consistently make the shots, but I decided to put it back in, to give the player a little more help. The Stage Alley shot to start modes with 2X scoring is pretty important.
Quoted from drummermike:
What version of code are you on?
#4056 2 years ago
Had Seance on with one letter left to hit (E). Return from Beyond lit. Ball drained on the left and I was expecting Return from Beyond, but got ball over instead. We're on the current software.
#4057 2 years ago
Quoted from rosh:
18-5-4
#4058 2 years ago
Quoted from vireland:
When it hit the left outlane it was still thinking you were in MB since it had not yet processed the center drain. And obviously if in MB it would not give return
The lamp should be off at that point, so I need to look at that.
#4059 2 years ago
One other issue I am seeing fairly consistently is the catapult shot detection - I hit the inner right loop shot, the VUK kicks it up, it rolls through the wire form and lands in the milk can catapult - then the game just sits there. And sits there.. and .. then ball search and the catapult then tries the throw. No dimming of the lights, just bam! Throw.
Anyone else have this? I have checked the switch and it works fine with my finger and the ball -
#4060 2 years ago
Sounds like the switch is intermittent. Try dropping the ball in while in switch test mode to test it in a more "real world" way.
#4061 2 years ago
I have not seen that behavior.
#4062 2 years ago
Have done this; that’s what I meant by testing ok with the ball. I can not get the switch to NOT_ register so if it’s intermittent I am having trouble replicating the
experience
#4063 2 years ago
Nope. We have three on the same circuit and Houdini's catapult/VUK shots are rock solid. At least a 98% completion rate.
Sounds like you may have borderline low house power or an older house with older wiring. Have you put a meter on your wall outlets when multiple pins are on and plugged into the same circuit?
Actually, the opposite. I’ve got 600A service and 10kW of solar... which might actually be a factor. When the sun is out the voltage in the house goes up a few volts. It’s likely I set the catapult etc during the day, and at night with another pin on the same circuit is probably a 8-10V change. I’ll go measure it.
#4064 2 years ago
Quoted from andrewket:
Actually, the opposite. I’ve got 600A service and 10kW of solar... which might actually be a factor. When the sun is out the voltage on the house goes up a few volts. It’s likely I set the catapult etc during the day, and at night with another pin on the same circuit is probably a 8-10V change. I’ll go measure it.
Isn't solar supposed to have a regulator to keep the power in a tighter range? 8-10V swing is a LOT.
#4065 2 years ago
The solar inverters must operate at a voltage slightly above the voltage coming in from the grid transformer. That’s how you force the current to flow away from the inverters and use the power from solar first before drawing current from the grid. When I upgraded my service to 600A, the utility also upgraded the transformer. As a result the voltage coming into the house is slightly hot (244-245v). I’ll take some measurements.
#4066 2 years ago
Quoted from rosh:
How long do you have to get he ball from the Stage Ally to the Stage to get 2x scoring for the illusion? Does it have to be a totally clean shot to get 2x? If it gets caught in the pops for a second or 2 you seem to lose the doubler.
#4067 2 years ago
Quoted from Rferullo:
My assumption was always that no other switches could be triggered for it to count but it sounds like you could activate a pop switch along the way as long as it's inside the 100 milliseconds they are disabled.
#4068 2 years ago
SO,as some of you have been reading my attempt to obtain a Houdini from JJ at GEX has not been fun!!My story: 2 weeks ago,JJ called and said my pin with shaker,M glass and art blades was ready! I paid in full next day($7595)! So far,my pin has been on the dock here now for 4 days,and I can;t get through to anyone to get it to my house!!Apparently,nobody gives a F..k that this freight is just sitting there!I have had many pins delivered to my house ,and never been so forgotten!This sucks! There is no explanation sastifactory,just BS stories! Good luck to the rest of you!!
#4069 2 years ago
Quoted from hawkmoon:
I am sorry you are going through this. I will hope it gets resolved soon so you get your game and can enjoy it.
#4070 2 years ago
Needs to be a clean shot, sometimes if it is really quick off the pop you will still get it.
Yeah, that size of a drop is going to affect it. As I think I mentioned we are working on something to potentially help those with inconsitent line voltage power. Hopefully we will have more info on that soon.
Definitely sounds like a flaky switch. Open a ticket and Barry can work with you on a fix or a replacement for it.
Lets take to this to PM and I'll see I can assist.
#4071 2 years ago
So what I have seen is that the switch works fine with your finger and even when you put the ball in the catapult, the switch registers every time....BUT, in reality when the ball leaves the VUK and rolls down the wire ramp to the lower catapult, the ball rolls into the ball cradle, which is different from dropping the ball into it. Your switch lever / actuator needs to be raised up a bit, that's all.
I'm here for you 833-API-HELP
Shaker.pdf
#4072 2 years ago
#4073 2 years ago
Quoted from rosh:
That shot only works about 20% of the time. Usually the ball will hit between the stage and the magic shop. Is there something I should be doing to the rail along the 2x lane?
#4074 2 years ago
Anyone else ever get a 2 ball Trunk Multiball? It happens to me sometimes. Then I might get a 4 ball Seance.
#4075 2 years ago
SOOO,evidently,its the shipper S.A.I.A.has had it on their dock,and they are a big co.and home deliveries don't take priority! JJ again is on top of it! S.A.I.A.SUCKS
#4076 2 years ago
Open all four sides of the box and inspect it thoroughly before you let them go.
You can always tape it back up if they dropped it or screwed it up in shipping.
Too many bad stories about casual and careless shippers in the last few months.
I absolutely hope for the best with your game and with mine coming up.
#4077 2 years ago
Drive over there and be a pain in the ass until they give you a delivery day / time, or even better load it on the truck and follow you home!
#4078 2 years ago
Quoted from pinden007:
The flat rail should be resting right up to the rubber on the exit, if not you can adjust it so it and that you get the right trajectory. Not easy spot to get to it, but you can loosen the screw on the flat rail and make sure it is resting against the rubber. You may have to remove it to adjust the arc slightly and then re-install. If you have issues, call us and Barry can help walk you through it.
#4079 2 years ago
If you don't like modding please don't click on link below If you do check out my Houdini!
-Gold head trim, coin mechs, side cabinet screws, shooter rod, leg bolts, and coin door bolts.
-Gold flipper buttons w/ lit trim
-Start button and coin buttons changed to red
-Red LED Shooter assembly, LED Legs, and underlights.
-Back Alley Creations awesome color matched powder coated coin door.
-Pinstadium lighting
-PDI Glass
-Art Pin Blades
-Target Decals
-Shaker
-Plastic Protectors
-Super Shiney Balls
-Chamber Mod in Back corner
-Planchette Mod
-2 small custom Stand up Houdini Signs
-Houdini Tiltopper coming soon
-Custom Pin-Gulp coming Soon
-Pin-Gulp LED light "Volcano" coming soon
-Curved Houdini Sign for Top back box coming soon
**I always run a separate power supply to run my mods to not affect or burden the factory setup.**
**Mod makers I love you all for your ideas and hard work! Thanks for feeding my Moditis addiction lol
You rock!
PICS link below :
https://www.dropbox.com/sh/dbpro92teal14jm/AACnY3bjQKbdIgVaH1ROAa17a?dl=0
#4081 2 years ago
Quoted from BarryJ:
Thx guys! We are traveling for the holiday but I will check when we return on Monday night
#4082 2 years ago
Quoted from BladeFury:
**Mod makers I love you all for your ideas and hard work! Thanks for feeding my Moditis addiction lol You rock!
All you need to round this out is PinRemote™ under the hood! Administer this beautiful machine with your phone. See the Iron Transfer store on this site if you want to learn more or order.
I'm going for "Mod of the Year" with my invention and the word is getting out.
#4083 2 years ago
Found a sub and box combo in my collection that fits inside the cabinet perfectly. It looks like it doesn't clear the underside of the playfield but it has about 3/4 of space. The sound is so much better now and I can hear things in the music and other sound effects that I never did before. Also installed some of those multicolour LED kits from amazon. Both upgrades cost me a whopping $17.
#4084 2 years ago
Hey! Need help!
I lifted up playfield to Dialed in the left orbit. Perfect.
When I Went to pull down the PF, some wire got stuck on the lockbar. Since then the game is shooting balls in through as soon as I push start.
some wires were disconnected but easy to reconnect.
Can it be a fuse? Im a B/w guy. This game confuse me.
The pic with my finger on it is the one who got stuck and pulled out 2-3 more
#4085 2 years ago
Quoted from ElectricLou:
If you don't have too many balls in the game. I'd get ahold of rosh or Barry here or American Pinball tech support, to be sure you got the wires back in the right spots. And other possibilities.
#4086 2 years ago
Yes, the number of balls during various multiballs isnt always consistent. Also, during ball saves, sometimes i get one ball back after two or more drain. I think there might be some ball management code updates coming. rosh
#4087 2 years ago
Fun Shot I'm learning
#4088 2 years ago
I tell every customer of person in my booth at a show. Easiest way to make the shot!
Pincades
JT
#4089 2 years ago
Quoted from Jamaster10:
Pincades
JT
I also want to point out that the milk can shot is MUCH easier than I thought, after learning to cradle it in the right flipper and gently hitting it at the tip of the flipper. I can make it about 6 tried out of 10 which is great for me; such an unusual shot!
#4090 2 years ago
Now that is a tough shot - I need to practice it more.
#4091 2 years ago
Ive been practicing that lock shot for a month just like you. Im only at maybe 10%. Improved my milkcan considerably over time, maybe 50% succsess.
#4092 2 years ago
Houdini finally in the house!!!!Good pointers on that milk can shot!! Haven't been able to lock in that shot yet!! Mucho fun!!!!
#4093 2 years ago
Congratulations Hawk!
Glad it finally made it. What game number did you get?
#4094 2 years ago
Watching this Netflix show with my son called “Who Was” - it’s a kids-oriented history show with a very silly but (mostly) true biography of whomever... uh, was.
the episode he pops on is about Marie Curie, and Houdini! There’s a ton of scenes also in the game, including the elephant, metamorphosis, straitjacket, and Q!
#4095 2 years ago
Hi
While I’m trying to fix my problem with Josh, is someone would be kind enough to take a picture of their Driver boards (The two big boards that sit back to back un des PF are the driver boards.) I need to double check wiring and board leds.
Thsnks un advance
Lou
#4096 2 years ago
Lou. Think this is what your asking for?
#4097 2 years ago
Top pic is upper board by 3 magnets.
Bottom is lower board furthest away from player.
#4098 2 years ago
So no matter how we try we cannot back hand the lock shot off the right flipper. Checked the level on the machine with the iphone app, Left to right was good, Said to raise the back over 1" to get to 6.5 degrees. Did that. Game now plays faster, more airballs and still no back hand shot.
Any advice?
#4099 2 years ago
Quoted from foxtj24:
Any advice?
You really have to be very quick and. precise - where is it bricking? On the targets?
#4100 2 years ago
Quoted from Ericpinballfan:
Thank you very much. If you still have a minute, can you confirm that you have the same red leds on your boards when Game is in attract mode (see pics).
Only weird thing is some of my wires are not routed as yours (purple/white/black). Mine is coming from the right. Anyway
Can you also take a pic of the board between both flippers?
It really helps!
Thsnks!!
$ 6,995.00
Gulf Coast Pinball, LLC
$ 139.95
$ 349.95
Pin Stadium Pinball Mods
