Quoted from Gooch:So got Houdini in the house a couple of days ago, absolutely love it! But, started having resets every game for some reason last night. Try to put a second player game on and machine would go dark and reset. Try to play through a single player game, maybe make it to the third ball, and then goes dar. Kicks a ball out into the shooter lane and resets. Anybody experienced this? Rosh or Barry, any ideas?
Im not Barry or Josh...but try reseating or make sure all your hdmi cables are plugged in and not loose from shipping. Double check backbox and under playfield left side.
Quoted from Malibu-SS:Having a problem with the ball trough.Takes multiple trys to get the ball out....have tried many different coil strengths.no difference.Looked at the assembly and everything looks good and nothing is loose,any ideas?
Check the spring on coil into shooter lane. They can get bent and off to one side causing it to jam a little and not react correctly. Another theory, ive seen a loose nut or bolt get down there and block exit. Eject all 6 balls and inspect with flashlight and magnet extender.
