(Topic ID: 183206)
American Pinball Houdini thread
By lllvjr
2 years ago
  • 9,980 posts
  • 572 Pinsiders participating
  • Latest reply 10 hours ago by pinballinreno
  • Topic is favorited by 150 Pinsiders
There have been 1,328 images uploaded to this topic. (View topic image gallery).
33 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 9980 posts in this topic. You are on page 79 of 200.
#3901 1 year ago
Quoted from pinden007:
What became of the ppl mentioning they have never received a tilt warning? You can add me to that list. Is that some that can be tested to see if it's working? I know when you have the door open the game does not play so I couldn't easily test it that way.
Was working on something else today and got a tilt warning, so I know it works, but clearly there is something going on where it is not always registering. I will be looking into it further.
If you pull out the 'interconnect' switch inside the cabinet, you can play with the door open, but that switch disables high power for a a reason.
Quoted from vireland:
if you made the extra ball only happen if you made the double ring shot?
Definitely like this idea, betting a bunch of guys here would be hating on your if I did that, but could be a good difficulty option. Turning down the amount of time is also a way to make it tougher, since as was said, you would have little to no room for error. Also reducing the number of cards you can throw makes it harder -- both of which are options currently.
#3902 1 year ago
I mean, it would take away my guaranteed extra ball per game, but maybe if you made the extra ball only happen if you made the double ring shot? After hitting 3 rings, the front ring changes to "EXTRA" and the back ring changes to "BALL" and you have to make the double ring shot to collect? It would certainly make it less of a guaranteed collect like it is now.
Please don't. I suck at this video mode as it is.
#3903 1 year ago
As I charge up the card, at what level should I release to hit the large and small targets? How much lead time do you give when releasing the card?
#3904 1 year ago
Quoted from konjurer:
the meter has 1 or 2 bars it will only be high enough for the big hoop, 3 and 4 bars it is both, 5 or 6 just small, once it goes Red your throw will be high.
So, you need to learn the timing for when to start the press and when to release it. If you focus on always releasing on one of the 'both' bars, then you can start to figure out when to start the press for 'each' level, meaning a hoop moves faster each time you make it (speed changes when it starts its next trip across the screen).
#3905 1 year ago
Just for fun. The 6 ball conundrum.
#3906 1 year ago
ericpinballfan that is a beautiful picture.
#3907 1 year ago
Quoted from rosh:
Yeah, part of me would be bummed losing my "easy" extra ball, but as it is now, it's so easy it's kind of cheap.
I like the double ring shot for extra ball more than time adjustments because making a double ring shot takes a LOT of skill (or a MASSIVE amount of luck - one time) whereas the time and card reduction is just kind of cheap. Might be cool to have a chain bonus for not missing a shot. 1, 2, 4, 8, 16, 32x, etc instead of each shot simply and continuously being worth more than the last that hit. If you miss a shot, it goes back to 1x for the next one and starts building again. If you can hit them all and the extra ball double shot it could make the mode both challenging and VERY rewarding.
You could also make an "EASY" and "HARD" choice at the beginning, like it does for the straightjacket escape. Hard obviously has higher base and multiplied points.
-1
#3908 1 year ago
Quoted from adamross:
Practice makes perfect. Once you "get" it, it will be mindlessly easy, and that's not really fun.
#3909 1 year ago
Quick report ... My tilt warnings work!
#3910 1 year ago
Quoted from rosh:
Hey guys, been a little busy last few days with some great stuff going on here AP, and maybe I'll be able to share some stuff soon. Did a quick glance through the posts to see what questions have come up, but suspect I've missed some, so if this posts misses not something, please repost.
High Score resetting . There is no command currently to just reset high scores (or to set your own). Clearing audits (via service menu -> Utilities), will reset the hight scores to the default (current audits will move to the middle column when viewing stats). It is on the list to add a command for this, but not the highest priority. As a reminder, all of that service menu and utility stuff had to be created since this is our first machine, and I am only one guy, so I pick and choose what I consider to be the most important items, but I will get to it. But certainly okay to raise issues and wants here so I can get a sense of which missing things people actually miss.
Rejects -- As someone suggested, flipper strength probably too high. Take down one notch and see if it improves, then take down another notch and see how it plays. On my machine I rarely get airballs and rejects, key is to find that sweet spot where the strength is strong enough to make the ramp, but not overly hot where you get rejects and airballs. You may find that having the left flipper one notch higher than the right makes sense. There will always be some level of rejects since the ball can get into the stage at angles and positions where it is just not going to stick.
1) you can turn off the match. I'd have to look more deeply to see if I can enable the start button to work during Match.
2) Non-game items only come up on 2 and 5th visits. I will be looking at what might work for a flipper escape on the magic hat, but it is somewhat more complex then going it for modes.
3) Is there a specific place you are seeing this? The timer is typically stopped when the ball is not in play
4) I agreed that it should, I'll have to check that.
5) noted
6) depending on settings Return from Beyond is lit by getting two jackpots during a seance multiball, Escape Death is lit by completing two jail escapes. If you earn the outlane mode via Magic Shop or Skill shot, then the lit outlane moves with each flipper hit. If you then earn either via the normal method, they will be both be lit.
Goal is to shake when lid closes, I've not noticed it being late, but I'll watch for it. So, based feedback I've seen so far, sounds like you guys are pleased with the use of the shaker. Goal is to find the right balance to enhance game play without over doing it or using it ways that don't fit.
Code updates do not in anyway impact settings (other then if new settings are being added). it will not mess with pricing (so operators, please update to the latest code when available), it will not mess with settings, it will not mess with coil strength, it will not mess with stage calibration. Anytime you insert the USB stick it will save off settings and data, and I anticipate in the future there will be support to re-load settings (but not sure I will be adding support to import back in high score data).
Setting aside that Agile is an umbrella term for a variety of methodologies (Scrum, RAD, Extreme, etc.), I use a completely different top secret methodology.
Not sure If I missed any other questions, if so, re-post.
My shaker does as you said, when the lid closes it shakes. I just thought it would have started sooner. Love it in the pops and elephant!
10
#3911 1 year ago
Houdini is in the tank!
ok well his proto type is in the tank - few tweaks and off to paint work.
These should start shipping in late June early July.
#3912 1 year ago
Just noticed Mac King on the art blades. That is REALLY cool guys! Nice!
#3913 1 year ago
Quoted from drummermike:
Maybe it should shake when the ball launches like a cannon?
#3914 1 year ago
Quoted from pinballinreno:
That would be a cool touch!
#3915 1 year ago
Quoted from Yelobird:
Well I guess it would be super difficult to have the shaking occur while waiting for or after the trunk opens to receive the ball.
And much easier to have it start light and end up strong like the cannon was building pressure.
Then maybe have a sound effect for the trunk opening and closing and a boom or a crash when the ball hits or something? This might be hard to time though.
#3916 1 year ago
Weekend bump for my Planchette mod.
Two versions available; "Houdini" or "Oracle", on bottom arch.
See my marketplace ad and thread, or just PM me.
Thanks Eric
#3917 1 year ago
Quoted from Ericpinballfan:
There are no Zs in the machine so I can not fully endorse this mod
#3918 1 year ago
Quoted from rosh:
There is one "Z" now.
#3919 1 year ago
Do theze count?
Leslie and Paul.
#3920 1 year ago
I think I encountered a scoring bug.
I had 2x milkcan PF going and shot the 2x stage and selected Needles. It said my shots were valued an 9,500 each. I shot the ball into the pops and then it drained immediately. I appeared to score about 200k in a matter of seconds.
This happen the other day too but I just didn't know it. I couldn't figure out how my score went from 80k to 500k so quickly.
#3921 1 year ago
flaked on that they were not originally on the team, guess I need to change that or al least put it in a circle with a line through it, like the one 'hidden' in the game.
#3922 1 year ago
when did it say that at the start, or along the way? Hitting it into the pops will often hit the Key Target that will increase the value of each shot. The 2X stage would impact the shot value it displays, but the 2x Milkcan would show that on the shot value, only when it reports back what was scored, which I don't think it displays, but obviously that would increase the point seated. . 9500 certainly seems pretty damn high, would be around 17 hits to a stand-up, since it would start at 1000, with the doubling and then increase by 500 (with the doubling) on each stand-up hit. You could pull the logs and send it to me, if you can narrow down date and time (and confirm clock is right on the machine).
#3923 1 year ago
Quoted from rosh:
It happened over lunch. I've been going home for lunch to play. (see what you've done)
I would be happy to pull logs. How do I do that? Connect USB, go to menu's, dump logs to USB?
I don't remember what the original scoring per was. I hit the pops on the first shot, looked up and saw 9500 per. I don't think I hit any stand ups. I'd say the ball hit the pops no more than 10 times then drained. I wanted desperately to hit that darn spinner after I saw 9500.
Btw, what's the proper way to hook up the Polk sub? I have a feeling the answer may already be in this thread but a search of polk didn't turn up the instructions.
#3924 1 year ago
Barry posted some pictures a few pages back; search for “sub” and “amp”
#3925 1 year ago
open coin door, plug a USB stick (with no game update code on it) into the USB extension cable (in cabinet normally on the right side). Logs will be copied on to it, takes just a couple of seconds, message on screen will tell you when done, just power down, remove USB, power back up.
Send me log.txt and the next two highest numbered logs, those will likely have what we are looking for. josh@american-pinball.com
#3926 1 year ago
Finally busted 2 million last night. Having a blast too!
#3927 1 year ago
We are pleased to announce that the grand raffle prize at the 2018 Northwest Pinball & Arcade Show, June 8th-10th at the Tacoma Convention Center in Washington State, will be a brand new Houdini!
#3928 1 year ago
Quoted from nwpinball:
Finally a chance for me to own one!!
#3929 1 year ago
Quoted from BarryJ:
If you win, send it to ltg ! He needs to rip it apart and tell us what secrets are inside.
#3930 1 year ago
Sooooo.....
Engineering wasn't to happy with my last skill shot fix! Who would think hammering next to the playfield would be an issue!?
Now to introduce the new and improved skill shot fix, guaranteed to let you hit all 3 targets "if you have the skill" or something like that.
Call me if you need help 833-API-HELP
**You will need one 3/16" post rubber, which you should already have lying around**
B
Skill Shot Fix.pdf
#3931 1 year ago
Or just ask me, Barry the average
#3932 1 year ago
Quoted from BarryJ:
You should have put that pad down first.
#3933 1 year ago
Quoted from BarryJ:
Sooooo.....
B
Nice fix!
Will all the games now on the line (mine, next week I hope) have this adjustment?
Its simple and elegant
#3934 1 year ago
Nice fix!
Started last week making this adjustment on the QC line.
#3935 1 year ago
Cool, my game shipped from chi town yesterday so this should have it implemented already? Cant wait to get it. Delivery Monday!
#3936 1 year ago
Quoted from BarryJ:
Sooooo.....
B
Thanks for the update, Barry! What does the kit include? Is it just the post rubber?
#3937 1 year ago
Checked the logs you sent, saw five different times you had needle illusion running, but I did see that in the last one that the key standup was registering a dozen or more times after a single hit, so looks like that switch needs to be adjusted. That would explain how your point value got so high. Check it in switch test and then see if the gap is too close.
Does look like there is a potential bug where the spinner is awarding two hits instead of one on each spin (possibly it is just trying to play the sound twice), so I need to look into that. If that is the case, after the next release needles scoring may drop down. In at least a couple of the needle illusions you played you were shooting the heck out of the spinner.
Quoted from Rdoyle1978:
yup, only thing you need is the rubber, as you are going remove a rubber that goes around two posts and use a new one for the one post and leave it off the other.
Quoted from Pinstein:
Alwas possible the game had been built earlier before the fix, since they don't necessarily ship out in the order they are built, since our shipping areas is pretty crowded, and they move games around as needed to get stuff in and out. You will be able to tell by looking at the instructions above and comparing it to your machine.
#3938 1 year ago
Don't think he was offering a kit simply a .07 solution assuming most people with a pinball machine have a spare 3/16 rubber?
#3939 1 year ago
Quoted from BarryJ:
Sooooo.....
B
Bravo team API. A rather simple yet elegant solution! Way better than arming the troops with hammers. lol I love simple...
#3940 1 year ago
Quoted from BarryJ:
Excellent, but this would have been easier...
#3941 1 year ago
I love how they are listening and on top of things. Just great!
#3942 1 year ago
There's a kit with an item # listed in the instructions
#3943 1 year ago
The kit is just the one rubber
#3944 1 year ago
Quoted from rosh:
I'm with you, I was just clarifying why I mentioned a kit
#3945 1 year ago
It's these quick replies , updates and concern for customer satisfaction that makes me proud to support American Pinball!
Looking forward to what the future has to offer!
#3946 1 year ago
Quoted from transprtr4u:
Not to mention that they actually built and *delivered* a fully working game. Not a box of lights. Not a couple of demo games, empty promises and full payment plans. Game is built, game is delivered, game is paid for.
#3947 1 year ago
Hadn't looked at the thread in about 5 weeks.
Really glad to see that production has now ramped up considerably, and niggles are slowly being eliminated.
This could be a slow burner.
I may have missed posts pertaining to the matter, but I assume shipments to EU / rest of world are still being held off until they're totally satisfied with how machines are shipping?
#3948 1 year ago
So got Houdini in the house a couple of days ago, absolutely love it! But, started having resets every game for some reason last night. Try to put a second player game on and machine would go dark and reset. Try to play through a single player game, maybe make it to the third ball, and then goes dar. Kicks a ball out into the shooter lane and resets. Anybody experienced this? Rosh or Barry, any ideas?
#3949 1 year ago
Having a problem with the ball trough.Takes multiple trys to get the ball out....have tried many different coil strengths.no difference.Looked at the assembly and everything looks good and nothing is loose,any ideas?
#3950 1 year ago
Finally cracked a million
Mods for your pinballs
$ 50.00
$ 6,995.00
Nitro Pinball Shop
