(Topic ID: 183206)
American Pinball Houdini thread
By lllvjr
7 years ago
  • 14,818 posts
  • 755 Pinsiders participating
  • Latest reply 13 days ago by bobukcat
  • Topic is favorited by 204 Pinsiders
41 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 14,818 posts in this topic. You are on page 59 of 297.
#2901 6 years ago
Deceptive angle and lazy camera work on my part for not taking the glass off but there is a ton of space between the ball and the plastic. There are three switches hanging from above that look like they are supposed to count three balls but the ball won’t pass by and the ball search doesn’t kick it out.
#2902 6 years ago
Quoted from pinballinreno:
Is there something on the ramp stopping the ball?
Look closely, it is stuck under the edge of the plastic under the ramp. See my yellow arrow.
#2903 6 years ago
Quoted from Ericc123:
So new question. I’ve had a ball get stuck against this stop several times now. I’m not sure how it’s getting there but when it does the stop and the far left pop bumper just keep going off but the ball doesn’t shake lose. I have to stop the game every time to take the glass off to get the ball out. Any ideas?
This happens on the one here sometimes when a fast ball hits the plastic post, then bounces back, then rolls forward too slowly to trigger the switches (there are three above the ball lane). It used to do it a lot more, but I adjusted the switch leaf so they broke easier even if the ball rolled slowly. You want it so the switch barely breaks when the ball passes under it. The one in your pic is hanging a little too low and needs to be bent up a bit.
#2904 6 years ago
Looks like it is hanging up on the switch, you might need to very gently adjust it so it can roll under them. Then go into switch test to be sure it registers when ball is touching post . You might want to first check the game is at proper pitch.
Good idea to put three balls in there and move them side to side to be sure all three register in switch test
#2905 6 years ago
Quoted from PinMonk:
Excellent. I missed the switch in the picture.
#2906 6 years ago
Quoted from LTG:
Don't feel bad. I missed it, too, on the Houdini here. When we first got it and were having problems with the locks there, I didn't know there were three suspended switches on TOP and was having a hard time figuring out how to approach the problem. Once I "discovered" the switches, it made it a snap to get it all working right.
#2907 6 years ago
The ball looks like should be resting on the post not stopped behind it so that when the post lowers it releases the ball?
Is the pitch ok?
Does that ramp need more pitch?
Pretty sure thats where the roll over lock switches are? I recall there were issues with the ball hanging up or not registering in the beginning but I believe they worked that out. Check the switches.
Edit. Sorry replied from phone before seeing Josh already answer.
#2908 6 years ago
I had exact same issue with mine, ball bounces off of post and I believe that the switch when not aligned causes the issue
My fix was to slightly bend roller arm on switch #2 (the middle one) so that it acts like a one way. Ball goes in and past first two switches hits post and last switch, but with switch arm bent down it keeps ball at post.
To be clear my switch isnt all the way down on playfield but just enough to knock the ball back. It will actually allow the ball to go back this way with minimal effort rolling it back up the path
Hope this helps everyone!
#2909 6 years ago
For anyone who has plugged in an external sub, can you please tell me (or show a photo) where exactly it plugs into? Thanks in advance!
#2910 6 years ago
Quoted from adamross:
Edited as incorrect info was posted
#2911 6 years ago
Topper pic - really like how it fits the theme, color and art style
#2912 6 years ago
Quoted from MT45:
Lower left side of Lepy amp (see red colored RCA connector in image).
There is a left and right output so a red AND white RCA connector if you are not familiar (apologies if you are)
I ran the cable behind the monitor, down the main wire chaseway, then out the bottom vented screen (just remove left 4 screws, run cable, protect it with small piece of foam tape, then reinstall vent screen screws)
Awesome. Much appreciate it!!
#2913 6 years ago
Quoted from MT45:
I thought the rca's were inputs, not outputs on the amp. I ran mine off the wire outputs like it says to do in the manual.
https://www.parts-express.com/pedocs/manuals/310-308--lp-168ha-manual.pdf
#2914 6 years ago
Quoted from foxtj24:
This is correct the lower speaker jacks that are red and black on the mounting plate side of the unit are for the subwoofer the upper speaker Jacks are for your speakers the RCA jacks are for your aux inputs.
It's hard to see since the labeling is right near the wall of the cabinet but they are labeled sub.
#2915 6 years ago
Hmmm . My apologies then. I am however getting output from these jacks and the sub is working - strange ... as you are correct they are clearly labeled as inputs.
I removed my original post on the subject
15
#2916 6 years ago
Slo-mo shot of the catapult shot ...
#2917 6 years ago
Is there an opening to run the speaker wires out of the cabinet or do I need to drill a hole?
#2918 6 years ago
Quoted from konjurer:
There is an opening. Bottom of the cabinet you will see cutouts for venting/cooling. They are covered by a screen.
Simply remove 4 screws from right or left side and that screen is flexible enough to just pull up and allow you to drop your sub cord through
Then, I would add a piece of protective tape (I used a piece of foam tape, but a couple of layers of electrical would work) to the sub cord where the screen touches it.
Then re-install the screws - the screen sort of "pinches" the sub cord in place
#2919 6 years ago
Anyone take a quick picture of the SEANCE VUK switch for me? You will need to get creative with your phone to get it "in there"!
I had mine jam on the armature coming up from the plunger/coil (it's a black plastic armature so when the sharp edge of the switch got "past it" - it really stuck there!
Pull the PF up and gently un-stuck it but I want to make certain the switch is oriented and has the correct bend structure to function normally
Seems like the design is for the armature to be under the switch and actually make contact with it every time it launches from the VUK?
First pic is the armature post stuck/jammed against the switch blade edge - the armature was stuck up so high, the ball was resting against it
The second picture is after my correction/fix
#2920 6 years ago
Quoted from MT45:
Looks good , I'm waiting for Dan at Tilttoppers to finish his ... Coming soon! Big fan of his work.
#2921 6 years ago
Quoted from MT45:
OK - I was nearly 100% certain that the switch blade should NOT be above that armature, so I pulled the switch and bent it like many other VUK switches I've seen. Also got an email back from Barry at API on this Saturday night at almost 9pm to help me trouble shoot it. (these guys ARE AMAZING!)
It was bent incorrectly from getting jammed so violently with the coil armature
Working 100% now!
#2922 6 years ago
Quoted from MT45:
Barry is top notch guy.
This whole AP team are taking this to the next level.
#2923 6 years ago
Quoted from Ericpinballfan:
If you get the chance to see them at a show. Talk to them. They have some really great people working there. I was lucky enough to ride with 3 of them from TPF back to DFW, and spend time chatting and enjoying life.
#2924 6 years ago
Quoted from transprtr4u:
If it looks anything like their LOTR topper,looks like i will be spending some money
15
#2925 6 years ago
Pretty damned excited to join the owner's club, even better because it was a surprise birthday present from my wife! Have to give AP major props for the way they pack this game in the box, very, very well done. Have to adjust a few things here and there but so far I'm very happy other than having to figure out how to hit some of these shots!
#2926 6 years ago
Quoted from bobukcat:
Enjoy!!! Very nice and cool game,Hopefully i will be playing it tomorrow
#2927 6 years ago
Quoted from LTG:
Very cool Lloyd! Sure wish I would have run into you at TPF - always wanted to say hello.
The API guys are truly genuine folks. I was right next door to the API team at TPF for most of the show (at the Pinstadium booth helping Scott and Sindie). Before the show opened I got to hang out with Joe and later Josh, Barry and the rest of the team.
I was extremely impressed at the "we're in it together" attitude they all displayed - especially at the TPF API forum/discussion. They celebrated each other's contribution, recognized the team members back home and had the ownership in the audience as well. Mukesh Vasani took time to speak to me after the API event and made it clear that they were 100% focused on customer satisfaction. He handed me his business card and said to call if I needed anything at all.
With a team like they have assembled - that call will never be necessary but it shows the level of commitment at API from the top down
#2928 6 years ago
Congrats - best birthday present EVER!! (Happy Bday too)
#2929 6 years ago
Quoted from MT45:
I'm sorry we didn't meet. I was right down the row from Houdini camped out at the remakes.
Good Lord willing and the creeks don't rise. CGC will send me again next year.
#2930 6 years ago
Quoted from MT45:
Awesome!
#2931 6 years ago
Quoted from Malibu-SS:
He has some outstanding toppers, the Jurassic Park is amazing, I commissioned him to do the Pinball Magic topper , I'm sure it's going to be a great add on to this game!
#2932 6 years ago
The catapult never gets old, looks incredible in slow motion!
#2933 6 years ago
Congratulations on best Birthday Gift ever!
What number did you get?
#2934 6 years ago
He now owns Game #153
Enjoy
Pincades
JT
#2935 6 years ago
Quoted from Jamaster10:
Wow mine is #39 ... Nice job in getting these units down the line!
#2936 6 years ago
Delaware Pinball will be streaming Houdini at 2pm est. This will be our first time ever touching the game.
https://m.twitch.tv/delawarepinball
#2937 6 years ago
Enjoy
Pincades
JT
Yep, serial number 1153, thanks again Jesse. The playfield in this game is the nicest I have ever seen in a production game, it's nicer than my WOZRR and WAY nicer looking than the one in the HUO GOTG Pro I bought recently. The clear coat is extremely smooth and looks fantastic. So far the only issues I'm having is the loop shot through the pops usually doesn't make it to the theater, it triggers one of the pops instead and the left outer loop is not smooth. Haven't dug into it yet to see what kind of adjustment may be possible for the first problem but I think the switches are just too stiff in the left loop so that should be simple. So far the trunk catapult is perfect since initial adjustment. Hard game, but a lot of fun!
#2938 6 years ago
I agree, this game is stunning and the build quality is amazing. I think all the talk of the shots being too tight is blown way out of proportion. It really is a special pin and you can tell a lot of love went into it.
#2939 6 years ago
Can't stop photographing this beauty.
Here are some cabinet shots ...
#2940 6 years ago
Went to my favorite downtown Pinball location (Lyman’s Tavern in DC) and Houdini is down... looks like a problem with the pop bumper. I has a sad...
A8EE99B0-3218-47F3-BAE2-9D22C1500906 (resized).jpegA8EE99B0-3218-47F3-BAE2-9D22C1500906 (resized).jpeg
#2941 6 years ago
That would have had to have been one heck of an air ball.
#2942 6 years ago
"Ladies and gentleman! Houdini breaks loose!"
#2943 6 years ago
Quoted from Rdoyle1978:
Looks like someone found the secret stage mode the 'exploding lock trick'. I'll assume they are reaching out to our service department for assistance.
#2944 6 years ago
Quoted from rosh:
Maybe related to that, I just had a problem where one of the screws dropped out of front lock. I attempted to screw it back in, but the hole is stripped. Could be a weak area in the design.
#2945 6 years ago
I played it for the first time this last weekend at VUK in Bethesda and had a blast. 10 straight games and man this was a challenging game... frustrating yet satisfying as well. My best score was 224k which I was happy with considering the high score was 600+k. I''ll be playing more of Houdini for sure whenever I'm out. My only complaint was out of the 6+ shots catapulting into the box only one of them made it. Hopefully this doesn't become a common problem. Great job AP!
#2946 6 years ago
Quoted from rosh:
I don’t think the pop broke, it looks like it was removed. Lyman’s is staffed by people who KNOW what they are doing, so I assume they have already reached out. The bartender who is apparently not involved in fixing the games told me “something broke on The Board.” Silly me, I assume he means there was a burnout in the backbox! Then I saw the removed pop.. LOL
#2947 6 years ago
Anyone else experiencing random Multiballs when there shouldn't be one? It's happened to me twice so far and then the game seems to kinda lose track of where balls are for a while. I'm also experiencing randomly weak flippers, usually the right one but sometimes the left as well. It usually only happens for a single flip but I had a really good Trunk MB going in the Elephant mode and the right flipper got REALLY weak for about 10 seconds then snapped back to life. It would be a really good way of messing with you even further if this was intended behavior at times but I don't think it is.
#2948 6 years ago
Went to an arcade last weekend and Houdini was the one pinball machine out of order. I was so excited to play it. Planning on going again soon though and hopefully they have it ready to go.
#2949 6 years ago
Quoted from tmntrule999:
New game, new parts - takes longer to diagnose the problem I’m sure. The one st my location should be up and runnng again fast
#2950 6 years ago
New code that will be released shortly (a few a owners are testing it now), that should clean up some of the oddness. Of course sometimes people think they are incorrect multiballs, when the are actually legit. Regardless, after the code update if you are still having issues we can investigate further.
$ 7,295.00
Maine Home Recreation
5,400 (Firm)
Silver Spring, MD
Precision Pinball prod.
$ 7,395.00
PMP Amusements
Pinball Invasion
$ 685.00
5,800
Albuquerque, NM
Rubber/Silicone
$ 7,995.00
5,800 (OBO)
Festus, MO
$ 7,995.00
Classic Game Rooms
$ 28.50
The MOD Couple
$ 7,499.99
Pinball Pro
6,500 (OBO)
Fitchburg, WI
$ 45.00
Playfield - Plastics
Mod Magic!
$ 48.00
The MOD Couple
$ 33.25
The MOD Couple
Mod Magic!
$ 7,395.00
Classic Game Rooms
$ 69.95
Hookedonpinball.com
This page was printed from https://pinside.com/pinball/forum/topic/american-pinball-houdini-thread/page/59 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
