Quoted from PinJim:Nice write up, thanks! I have the LP-168 amp and my game has the sub installed in the cabinet. I’m just trying to give it a little bit more bass.
The line converter is interesting. I might try one for Houdini and for my WPC games. On my WPC games, I modified the sound boards so that they have a low level output, but sometimes I get hum from the sub, even when the games are powered off. Annoying.
Thanks! I can still get some hum if I crank up the levels a bit, just might be some 60Hz due to the wires running near the power cords. Mostly because I get carried away w/the bass at times. But the adapter does have a ground that you can connect to the pin's chassis ground (i.e. the braid) - that might help.
I believe the adapter is basically just a step-down audio transformer and a few associated components + volume control. That would resolve the balanced to unbalanced issue (if present). Not rocket science. Even if it's not needed, no harm and it provides some isolation between the ext sub and the pin. I contacted the manufacture and the adapter presents a 16 ohms load. So high enough it shouldn't be an issue if it's attached to a speaker, but low enough that if you didn't have a speaker connector, it still presents a minimal load for an amp.
Since you have a new Houdini w/a woofer, you can just clip it across the woofer. The adapter is stereo, but I just use one channel.
Holler if you have any questions! If you order, you might want to order some small alligator clips so you can attach to the speaker.
Here's a picture of one of mine (in a Dialed In). I use the removable Commando strips to attached to the cabinet bottom.
And here's the mixer I use (got it cheap). I have 6 pins running into this mixer, with the output driving the active subs.
