Thanks for the reply , seems like when ball enters stage , mode start or not, assuming mode stage is activated when red main stage insert is lit, the ball is not detected and after a few goes into find ball mode and the ball is released. Calibration came back at -19. I did try it several times in a row just now and out of 5 , 3 where -17 to -19 and 2 times it didn’t seem like it went through calibration and came up 64. I swapped the wire location of where the curtain and captive ball servos connect to the node board and captive ball still worked under curtain test but curtain still did not work under captive ball test. . All tests of captive ball connected correctly seem fine.
Thanks for any help
Quoted from rosh:sounds like multiple issues. So it detects the ball in the stage, starts the mode, but does not release it, but then ball search does release it? If it does release it, then the second servo is working, so not sure why it would not drop it as it should at mode start, as that has nothing to do with the curtain.
If a ball goes into the stage when it is not lit for a mode what happens? Does it drop it right away or does that also require a ball search?
When you calibrate the stage, what value does it spit back?
