(Topic ID: 183206)
American Pinball Houdini thread
By lllvjr
5 years ago
  • 13,980 posts
  • 718 Pinsiders participating
  • Latest reply 2 days ago by mikepmcs
  • Topic is favorited by 197 Pinsiders
40 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 13,980 posts in this topic. You are on page 269 of 280.
#13401 7 months ago
I had my playfield apart to work on the stage and I had removed the rear catapult guide and right ramp to make things easier. I have this piece that I cant find a home for. I believe it goes at the top of the playfield center left but cant seem to figure it out. I was going to put it together right away but it took 7 weeks to get back home and work on it. Any help would be appreciated.
#13402 7 months ago
Can you reload the download ? Maybe it's corrupted.
#13403 7 months ago
Quoted from Bankshot:
I looked all over and cannot see that guide. It may be under a plastic. Hope someone else knows.
#13404 7 months ago
Tada!
Left side of the stage is just to the right of this. I was working on mine at the time I snapped this photo. If assembled, the wireform would be there too (the one that sends the ball to the catapult).
#13405 7 months ago
Quoted from K9Marshal:
Houdini left flipper staying up and now ejecting balls non stop - never had this issue prior to new code download - any ideas???
what do you mean the flipper is staying up? Does it go up when the game is turned on? Or does it stay up when flipped? When it is up, what happens if you power down?
Do ball start kicking out at start up or when you start a game?
You can see me the logs and I can see if they shed light on what is going on.
#13406 7 months ago
Quoted from mbwalker:
Tada!
Left side of the stage is just to the right of this. I was working on mine at the time I snapped this photo. If assembled, the wireform would be there too (the one that sends the ball to the catapult .
Thanks for the help, really appreciate it!!!
#13407 7 months ago
Quoted from rosh:
Basically when you start a game the balls keep feeding into the trough and when your flip up it stays up for a couple of seconds and then drops down
#13408 7 months ago
You can always try to re-install the update to see if the corrects things, but that flipper things sounds more mechanical than software. Either the flipper switch or a spring or a mis-aligned plunger.
The balls coming out, seems like an issue with the trough switches (missing 12v). Remove the balls from the trough, go into test->switch and put the balls back in and see if they register correctly. If not, check the connectors to the trough.
#13409 7 months ago
Ok, can't seem to find this... Got the shaker kit. Where does it plug in? Related, got the knocker, but no knocks happen.
I can't seem to find install instructions anywhere, and didn't get them in the box.
#13410 7 months ago
Quoted from goatdan:
http://s4.american-pinball.com/img/support/2019-9/Knocker-Installation.pdf
http://s4.american-pinball.com/img/support/2018-6/Shaker.pdf
#13411 7 months ago
Make sure there are 2 fuses in the little accessories board on the side of the cabinet..
Mine came with no fuses and I had to order them.
#13412 7 months ago
I finally got around to installing the current update of the API website.
The installation went perfectly this time, no redoing it a couple times, no drama.
No changes needed on any of the settings!
Trunk catapult works 100% in seance and the elephant mode. Scoop ejects work 100%, no extra balls or wierd lockups or sound issues so far.
The game seems to have more stable power. This is better even than after installing the cap kit.
The game seems smoother and quicker with sprightly power.
Its a blast to play!
Nice job on the update
#13413 7 months ago
Thanks for the updates, just what I needed... Now just need some fuses!
#13414 7 months ago
I think they were 5 x 20 4 amp slow blow
No one had them here in Reno, So I ordered a bunch from a bulk guy on Amazon, as well as some other sizes for other games.
#13415 7 months ago
Quoted from pinballinreno:
Did you check Ace Hardware? They seem to have more odd sized fuses than anyone else in my area.
#13416 7 months ago
So …. Question….
If I buy a NIB Houdini I need to buy an additional power pack for the flippers?
#13417 7 months ago
Quoted from Beez:
So …. Question….
Everything should be included on the current builds.
No upgrades needed.
#13418 7 months ago
Quoted from Beez:
So …. Question….
Yes, rosh said that new production units have all the power updates built in. The "flipper performance" module and is actually a large energy storage capacitor that mounts very close to the flippers. It's a small board mounted to the underside of the playfield, with a two-wire connector IN, and another two-wire connector OUT. Flippers need lots of energy for the first few milliseconds, and the capacitor makes that stored energy available very close to the coils, eliminating 4-5 feet of wire between the coil and the power supply. (The longer wiring to the power supply as originally shipped by API acts like a resistor at high current used by flipper coild which causes a non-trivial loss in the energy needed by the flipper coils).
Yes, new units have the power updates built in at the factory.
#13419 7 months ago
Quoted from bobukcat:
The pandemic closed my local ace hadware, and the hybrid Ace Harwares dont have the same stock.
Its a mail order world in Reno, always has been I guess.
Wild west, shootouts etc...
#13420 7 months ago
I miss Reno, haven't been there in a LONG time but used to go 4-6 times a year for work, quick drive up to the ski resorts when open too.
#13421 7 months ago
I think its time for an API black friday sale announcement!
I need more magic glass!
#13422 7 months ago
I finally confirmed it with it happening a third time. I got the seven letters to spell HOUDINI. The master magician mode starts, and of course I can’t successfully complete it, and I get timed out. Before the latest code you would just continue on if you had more balls up your sleeve. Now, after the latest code update the game finishes at the conclusion of master magician mode, regardless if you have more balls to play or not.
Not much of an incentive to collect the seven letters.
Wondering if this has happened to others?
Or has it been changed in the latest code update to conclude the game at the unsuccessful master magician mode?
#13423 7 months ago
Quoted from Freddykaboodle:
There is a setting to allow the game to continue after the master magician mode.
#13424 7 months ago
Ahhh, many thanks.
#13425 7 months ago
I’ve fallen behind - what’s the latest code? Is the beta still being tested ?
#13426 7 months ago
Quoted from Rdoyle1978:
New finished code on the API website,
Its really nice.
#13427 7 months ago
Considering the purchase of a new Houdini … looks to be around 7.5k NIB.
Seems prices have continued to increase but I also see this pin selling for much less on the used market.
My question … I’m not in this hobby to make money - I enjoy playing my games. What do you all think? Are you still totally in love with your pin or do you wish something newer was in your collection in place of your Houdini? Will this game get old in a 5 to 6 pin lineup?
#13428 7 months ago
Quoted from Beez:
I think all pins eventually get old or at least take a back seat. I loved my twilight zone and had it for a long long time. Then I wanted something else. For me and my lineup, Houdini remains a constant go to game. It’s such a deep game, as was TZ, that it continues to bring me back for more. I love the game and see it lasting a long time
#13429 7 months ago
Quoted from zahner:
Fully agree, love this game.
#13430 7 months ago
Do coil settings get reset after the software update? Or are they saved?
#13431 7 months ago
Quoted from 27dnast:
Mine stayed the same
#13432 7 months ago
Quoted from zahner:
Mine did too.
It was a pretty easy update for me.
#13433 7 months ago
No settings get changed during updates, unless noted in release notes.
Even when using “reset defaults”, coil and pricing settings are not touched.
#13434 7 months ago
Anyone know what type of LEDs are used for the cool white GI. (1smd, 2smd, other?) I noticed one of my slingshot LED is a warm white and I want to match the other 3.
Also, I have some Brightbuttons to install, but I noticed the coin return 12vLED that Britemods use for the connection is a warm white bulb. Houdini coin return use cool white, which look odd when you have both next to each other. I searched for a 12v warm white or a cool white 12v matrix connector but I can't find a good solution. Any ideas?
#13435 7 months ago
Quoted from Markharris2000:
When did they start adding this? Within the last year or more recent?
#13436 7 months ago
Quoted from Beez:
If you have an older game like mine, its a huge improvement.
get this:
http://s4.american-pinball.com/img/support/2020-8/Houdini--Coil-Performance-Improvement-Kit.pdf
#13437 7 months ago
Joining the club !!!
Going to be getting a NIB Houdini soon !!!
Can’t wait !!!!!!
#13438 7 months ago
Quoted from Beez:
Can’t wait !!!!!!
Yay!
#13439 7 months ago
Quoted from Bagdad:
Same problem with the CGC games.
#13440 7 months ago
Quoted from wolftownjeff:
Huh, my Houdini has incandescent bulbs in the coin return inserts, came that way from the factory. I always thought that was a little odd but never pay much attention to it.
#13441 7 months ago
Now they come with these, they are cool white. It would be nice if BriteMod kit came with a replacement LED (same as the connector) so it could at least match when your having that kind of issue.
#13442 7 months ago
Quoted from Bagdad:
Houdini's GI are socket style 12V LEDs, they are not smd.
Coin doors originally had 12V bulbs and was later switched to 12V LEDs
The key take away: 12V
#13443 7 months ago
Quoted from rosh:
Mmm, I just removed one of the GI bulb from the return lane and it says 6.3v..?
I just need to find where to order the 12v led for the coin door in warm white now...
#13444 7 months ago
Quoted from Bagdad:
https://www.cometpinball.com/search?q=12+volt
#13445 7 months ago
just incase you missed my post in the black Friday thread.
#13446 7 months ago
Quoted from brenna98:
Im in!
#13447 7 months ago
Quoted from Bagdad:
I just need to find where to order the 12v led for the coin door in warm white now...[quoted image]
Interesting, that's a Cointaker LED and probably this kind: https://cointaker.com/products/44-47-2led but as rosh said all the GI in Houdini is 12VDC (there's no 6.3AC supply in Houdini, only 12VDC, 5VDC and 48VDC). So I'm now very curious what bulbs those actually are, I wouldn't expect a 6.3VAC bulb to last more than a few seconds in a 12VDC circuit but Cointaker (and Comet) list very few 12VDC LEDs at all. Put a DMM on the socket and see what the actual voltage is, the wiring diagrams in the Houdini manual are not very detailed.
#13448 7 months ago
So no 20% off a new LOV?? Dammit!!
#13449 7 months ago
Thanks Dave. Hadn't seen this.
#13450 7 months ago
Quoted from NoQuarters:
You buying toppers now? Great Black Friday deals!
$ 33.25
The MOD Couple
$ 300.00
Maine Home Recreation
$ 599.95
Pin Stadium Pinball Mods
$ 7,245.00
Classic Game Rooms
$ 45.00
$ 48.00
The MOD Couple
Roswell, GA
