Quoted from VividPsychosis:Hey rosh, hope you had a nice Halloween. I had a few questions about the game I hope you could help answer. 1. Do the lights inside the chains near the mid/bottom portion of the playfield represent anything related to the gameplay or your journey through the game, or are they just for aesthetics? 2. What is the function of the second catapult? Lastly, and related to a different topic, the shop on your website appears to not be functioning correctly. I attempted to purchase a Houdini shirt, but no size option was available and after it showed 1 in the cart, when I went to check out it just says nothing is in the cart...
1) those lights track your progress on the 5 movies, 5 jail escapes (hurry ups) and 5 secret missions (combos). Each of those will have a magician mode if you can complete all five (well, for movies you just need to start all 5). They appear in a faint version of the color associated with that aspect of the game and then turn full on when you have completed one of those items. There is a lock at end of each segment that will then light when you have complete/started the five, indicating that next 'start' of the associate feature will give you the magician mode. There are also bonus points tied to the number of chain links completed. There are also settings to enable extra balls, and to set how many links are needed, for each of the those segments. For an average player, you might choose to enable those to increase your ability to get to the Master Magician Mode. Pretty sure those will default to 'off'.
2) The second catapult is used to throw the ball back to the right inlane. It actually is used very rarely, since it is only used in a couple of modes or if you somehow you get to the lower catapult when the lock is not lit, in which case the ball will not go through the trunk to the subway, but will go through and be diverted to the upper catapult and then get sent back. Be nice to use it more, but, I did not want to have too many things require making the left inner loop shot.
3) We are working on a new website. Send an email to [email protected] and someone will get back to you on and provide assistance.
