Quoted from pinballinreno:Sorta.
Just adjust both flippers down about 1/8" from the factory setting, which was not inline with the guides.
The goodie bag has an alignment plastic to check your work if needed.
This. Loosen the grip enough so you can move the flipper around by hand (with some force, you don't want it super loose). Use the alignment plastic to line up the flippers accordingly. Remove the alignment plastic. Now with your hand, just slightly tip the flippers down. 1/8" or so, as pinballinreno said. Now tighten those suckers up!
BAM! Instant milk can shots. Ok, not really, but generally the shots do make more sense this way
The Milk can is HARD, but it is not impossible. I had a good friend who is a MUCH MUCH better player than I come over, and he said (Roger Sharpe style) "I bet you can't hit that milk can shot". Lo and behold, I got it, first try. For the life of me I can't remember if I'd dropped the flippers yet. I think so.
