Reporting back for duty....
1. Added the following:
- knocker
- shaker
- side art
- Cliffies
2. Adjustments:
- adjusted 3 switch ball lock. Just had to bend a little. At first, I pushed whole unit towards the pop bumpers and that restricted the pops. Move back and just bent individual switches to get right contact.
- Seance scoop. After playing with power and getting no change, I just used 3 thin washers on one side and now it works 100%. So, rather than bending the scoop, you might want to try using different number of washers to adjust.
3. Complaints:
- Sound seems to be a bit muffled. Not sure I can adjust or if installing a better sub would help.
- I have updated power supply, but like others, the flippers don't seem "snappy" like Stern games. My Willy Wonka also has relatively weak flippers, but not as bad as Houdini
Overall, I'm very pleased and this pin will be staying a long time. I'm leaving room for one more pin.....Jersey Jack...
