(Topic ID: 183206)
American Pinball Houdini thread
By lllvjr
2 years ago
  • 9,753 posts
  • 561 Pinsiders participating
  • Latest reply 13 hours ago by zahner
  • Topic is favorited by 146 Pinsiders
There have been 1,318 images uploaded to this topic. (View topic image gallery).
33 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 9753 posts in this topic. You are on page 194 of 196.
#9651 30 days ago
Im on my second curtain decal and its already showing wear... anyone else seeing this?
#9652 30 days ago
Quoted from HarryReimer:
How long have you had the game? How many plays? Just curious.
BTW, did you have to buy the entire sticker set, or did they sell that one separately?
#9653 30 days ago
I got the curtain separately. Maybe I have 100 games on it since I replaced the curtain. Its just "scuffed" now but it seems like its not going to last long again.
#9654 30 days ago
Curious are your pinballs knicked up, in need of replacement?
#9655 30 days ago
I put new ones in when I replace decals.
#9656 30 days ago
Interesting. I wonder if the door is scraping when retracting or deformed by impacts and the degradation to the decal is a secondary issue rather than just the result of ball impacts. Mine has about 700 and looks like almost new. I’m really happy to hear that API will supply the single decal.
#9657 30 days ago
Quoted from zahner:
Mine looks fine with about 1450 plays on it, I have the spare they included in the goody bad but at this rate it's going to be a long time before I need it, or so it appears anyway. I took this pic with the glass on and a 2X zoom, it looks even better to the naked eye.
#9658 30 days ago
Quoted from bobukcat:
Mine looks fine with about 1450 plays on it, I have the spare they included in the goody bad but at this rate it's going to be a long time before I need it, or so it appears anyway. I took this pic with the glass on and a 2X zoom, it looks even better to the naked eye.[quoted image]
That's what mine looks like after almost 2000 plays. I really didn't think it would last as long as it has given its location on the playfield.
#9659 30 days ago
It must be the retracting thats doing the most damage.. Thats about how mine looks. I guess Ill order a couple of decals and throw them in the coinbox.
#9660 28 days ago
Today played Houdini for the first time on the dutch dpo expo 2019.
also Octoberfest.
Both machines where very crowded.
Wow what a great games.
Both full of action.
Whole family's were playing and waiting for there turn on octoberfest.
#9661 28 days ago
My left flipper coil started to rapid fire when I hold the button in. I checked the EOS switch and it was closed. But after prying it apart, got the same problem. I swapped the left coil with the right flipper coil, and the problem shifted to the right flipper. So, using Holmes-type deductive reasoning, I named the coil as the culprit and ordered two new coils from API. I am so glad for the solderless connections on these. Do new machines from other companies come with the lugless coils?
#9662 28 days ago
Quoted from PhantomO:
See the thin wires from the coil winding to the lugs ? Dig around them. Most likely one is cracked or broken. Easy fix.
#9663 28 days ago
Quoted from LTG:
Easy if I could solder worth a damn. That's a good call, though, because one of the EOS mounting screws had fallen out, which may have put strain on the wiring.
#9664 28 days ago
Youtube - how to solder - lots of short videos, how to heat joint and flow solder.
!0 minutes of practice and you'll be a pro.
#9665 28 days ago
Quoted from LTG:
#9666 27 days ago
It's probably just a one-off fluke since as of now it only happened once, but yesterday I changed some settings, played a game, was on ball 3, went in the magic shop, got the animations (rabbit out of a hat then 2x milkcan) and then the game ended as if ball 3 drained. It didn't crash, just got end of ball stats, then game over since it was #3. Happen to anyone before?
#9667 27 days ago
Quoted from VALIS666:
Yes, once in awhile.
#9668 27 days ago
Was just having a great game, my best ever, and first time reaching Master Magician mode but didn't complete it, so game over (that's how it should be, right?). Had two balls left. I guess I'll make it harder to get to MM in the future. I want to keep going when I'm on!
#9669 27 days ago
Quoted from LTG:
I will dig into these because now I have to solder a coik for the LOTR sword lock. Why do these all break at the same time?
#9670 26 days ago
You should come check out the Western Mass Pinball Club in Palmer. Not terribly far from you, and lots of knowledgeable people who could probably help with minor soldering stuff if you can transport the broken stuff there. We are always looking for more people to swing by and check the place out.
You may even meet other people from out your way that could help you in house.
#9671 26 days ago
Because they know you'll have to learn something to fix them good.
If it was an easy fix, they know not to break.
#9672 26 days ago
Has anyone successfully installed the scoop Cliffy?
I appear to be missing something in that it doesn’t seem to fit, to big. Any advice and suggestions welcomed.
#9673 26 days ago
Quoted from Pizzaman13:
Yep - a few of us here installed. If I recall correctly, a PIA since it needs to slide under the the metal rail. And you need to take off a fair amount of stuff to install. I think Pinballinreno has pictures in this thread somewhere. Worth the trouble tho. Is it really a Cliffy, or a knock-off?
#9674 25 days ago
It’s real so I know it should fit. Perhaps I just haven’t removed enough for it to be clear to me but optically, it just looks out of proportion.
I’ll do a little research deeper in the thread to see if I can find the reference. Thanks
#9675 25 days ago
It fits and was rather easy, the shooter lane protector is a little more involved and involves loosening the wood rail on the right.
#9676 25 days ago
It seems that often when I get Milkcan Multiplier via skill shoot or magic shop it stays lit for only a little bit and not the whole ball. Is this common?
#9677 25 days ago
Quoted from Platypus:
Yes, its timed
#9678 25 days ago
I installed it and it was a bit of work. Take off the scoop, the post behind the scoop, removed the VUK [rather, left it a' dangling] and loosen the rail to the left of the scoop enough to get the protector under without scraping the PF. I hear that some of the 2nd generation scoop protectors were cut in a way that avoided going under the metal rail, although I'm not sure if that is fact of lore. All in all, the scoop protector [which is the most critical in my opinion since I've already seen a few Houdini's with scoop damage] took about 45 minutes.
#9679 25 days ago
Thanks for the detailed Cliffy response. I’ll give it another try with a little more patience.
#9680 25 days ago
I took a picture of mine to try to remember the metal rail part. I'm pretty sure mine was the 2nd gen to help with the metal rail on the right. The metal rail on the left is what gave me some heartburn. I loosened up the rail, but being metal, it wouldn't flex much. I and I didn't want to take it entirely out since that seemed like a big deal. I was able to get it under it, but be careful not to nick the PF.
A little tip: When taking off the plastics, the plastic is notched for the rail - meaning you don't have to take the screws all the way out. The VUK zahner mentioned wasn't a big deal, but get something to hang it from inorder to not stress the wires when it's hanging.
#9681 24 days ago
This all seems so complicated. It’s a HUO machine. Do you think it is necessary to do/worth the effort?
I bought the Cliffy. I sunk the cost but worried I’ll screw up a perfectly calibrated , nicely playing machine for a piece that might be overkill.
#9682 24 days ago
About 1500 plays, no cliffy, no wear.
My secret, i put tiny piece of mylar over scoop edge about a week into ownership.
#9683 24 days ago
If it ain't broke, don't break it.
#9684 24 days ago
Easy answer: Just keep an eye on the scoop, if you ever start to see some wear, then install it. Eric's answer about installing some mylar is good - I did that on my AS.
The shooter lane Cliffy's - if you got those, that's an easier install.
#9685 24 days ago
Install the cliffy.
Its not a big deal. But yields excellent results
#9686 24 days ago
... which might be said about making any sort of changes to any machine ever bought ever. If you like it enough to buy a Cliffy, install it!
#9687 23 days ago
I've only put light play on my game... have the cliffy set but decided not to mess with the scoop until a sign of wear.
#9688 23 days ago
Quoted from pinballinreno:
Install the cliffy.
Depends....In a home use only setting they are not needed generally speaking. Also, in some cases it makes the shot more difficult to hit. Noticed a lot tighter shot on my Creature scoop with a cliffy vs without as an example. Ended up removing it and am happy as the shot is way more consistent. Installing some of them can be super difficult with a ton of stuff to remove. Now in the wild I would for sure install the protectors no question. It's all about the number of plays without doubt. It's unfortunate that we have a steel ball on wood and plastic. Eventually steel wins no matter what you do.
#9689 22 days ago
Quoted from riggy469:
Good to know, thanks!
#9690 22 days ago
There is a little abrasion on one wire of the flipper coil. Not sure if that could cause multiflips on a held flip button. No issues with the replacement installed.
#9691 22 days ago
Yes. You could separate the two wires and coat with something non conductive to shield them. Repair the top one if it's cracked through. Use the coil as a spare.
#9692 22 days ago
Quoted from LTG:
Will try, thanks. Gotta see what caused that wear so it doesnt happen again.
#9693 22 days ago
If you have a female 'better half'...some nail polish will do in a pinch.
#9694 21 days ago
Quoted from mbwalker:
Phant-O's game will look great with pink coils!
But go ahead and give it a go. I suggest first checking resistance on that coil and comparing with a new good one, carefully remove the coil wrapper and examine the windings for wear or broken strands. You may need only to isolate the two strands (leads) You can unwind one wrap, scrape it clean and re solder if broken.
I generally dissect anything that breaks to determine the fault even if I have a replacement. Nothing to loose and plenty to learn.
#9695 21 days ago
Well, I was thinking of the clear, but pink would work too!
#9696 19 days ago
Had a really good game the othernite and progressed thru a number of modes..However on one of the modes, forget which one the lights on the playfield went out and then some flickered on in places.. Sure I have seen this happen before..
Think the code still needs work.. Overall this pin could really be improved with a better lightshow.. It's good but could be top 20..
#9697 19 days ago
Quoted from Kenz:
The man from beyond? If so the game is working as designed. This is one of my favorite modes.
#9698 19 days ago
Quoted from MMP:
I love that mode!
#9699 19 days ago
Quoted from Kenz:
Prob Man from Beyond - lots of people have gotten confused about that since that's the only mode the entire playfield shuts off. awesome mode!
#9700 19 days ago
Quoted from Rdoyle1978:
Had to add - indeed an awesome mode, my favorite. Even more awesome when stacked with other multi-ball modes.
$ 625.00
$ 39.95
Little Shop Of Games
