(Topic ID: 183206)
American Pinball Houdini thread
By lllvjr
2 years ago
  • 9,471 posts
  • 549 Pinsiders participating
  • Latest reply 3 hours ago by mbwalker
  • Topic is favorited by 145 Pinsiders
There have been 1,293 images uploaded to this topic. (View topic image gallery).
33 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 9471 posts in this topic. You are on page 186 of 190.
#9251 38 days ago
Quoted from pinballer3:
Has anyone experienced a 'dead' Houdini? Was going to do a code update as previous games were looping. I left the machine for a couple of days then went to turn it on and it was 'dead', no power at all. All I've got at the moment is a very nice looking and large paper weight !!!
Are the main fuses intact?
Power cord tightly inserted?
#9252 38 days ago
If you need assistance, try contacting Barry at API Customer Support: call or text (224) 422-3191‬.
#9253 38 days ago
I'd start by plugging something into the service outlet. See if you have power that far. If not then check wall outlet, power cord into game, main fuse type stuff.
#9254 38 days ago
Quoted from pinballinreno:
And the breaker in the electrical panel too...
#9255 38 days ago
Quoted from LTG:
Quoted from mbwalker:
And you have to pay the edison bill.
And feed the hamster on the wheel.
#9256 38 days ago
......not mains or outlet or breaker related, checked all of that straight away.
#9257 38 days ago
Power at the service outlet in the game if you plug something else into it ?
#9258 37 days ago
Service outlet ??? There isn't one.
#9259 37 days ago
Of course there is. Inside the coin door, extreme right side on the power relay box (where the switch under the game is housed). My topper is plugged in to mine.
#9260 37 days ago
Left out of export games ? AP games I recall at shows in the USA have one.
#9261 37 days ago
Yep - it's not on an 'export' game. I'm investigation the power relay box, I'll take it apart an see what's going on.
#9262 37 days ago
Post a photo, something is off here
#9263 35 days ago
More glitches - Oh my! I reloaded the latest and it was playing fine the last couple of weeks, and then tonight, say a dozen games after reload, I failed to jail escape, and lights go red and ball ends in the middle of play. Then I rebound, have a great game, finish the stage acts, get the Houdini chant and hit that. I go on to get trunk multi-ball during a movie, hit seance, and then the game crashes. Is this overwhelming of the game what Josh is working on? Hope so.
#9264 35 days ago
Quoted from zahner:
More glitches - Oh my! I reloaded the latest and it was playing fine the last couple of weeks, and then tonight, say a dozen games after reload, I failed to jail escape, and lights go red and ball ends in the middle of play. Then I rebound, have a great game, finish the stage acts, get the Houdini chant and hit that. I go on to get trunk multi-ball during a movie, hit seance, and then the game crashes. Is this overwhelming of the game what Josh is working on? Hope so.[quoted image]
Send me the log
#9265 33 days ago
Hello,
I received the new power supply and I connected it.
I hear a little wind noise (as on the sterns) is normal?
Another point, my catapult, in test, works perfectly.
By cons, in game mode, the success rate goes to 75%, even with the new power supply, is this normal?
Thank you
seb
#9266 33 days ago
Quoted from sebseb12:
Hello,
Thank you
seb
Make slight adjustments until perfect.
See my posts on this.
#9267 33 days ago
...I hear a little wind noise (as on the sterns) is normal?
Yes, it's just the power supply fan.
#9268 32 days ago
I read your post. So, your catapult works perfectly in game?
I moved like you the targets C, E, A. This makes shooting easier.
#9269 32 days ago
thank you,
#9270 32 days ago
I’m trading my HUO Monster Bash for a Houdini + cash next weekend. Super pumped about picking one of these beauties up, can someone tell me if the March 2018 production date is later in the run and are there any know issues I should address? The seller already did the American Pinball power supply upgrade.
#9271 32 days ago
Quoted from darkryder:
Thanks[quoted image]
A bit earlier in the run, from what I know.
Definitely better informed folks here, but for the most part, you should be aces!
#9272 32 days ago
That is game #89.....I have game #90.
You will be fine. If it doesnt have the knocker buy one.
#9273 32 days ago
The arm must be perfectly aligned in the slot.
Ball should hit the center of the trunk, or slightly to the right.
If power is low, or many things are running in the game, its normal for the ball to bounce of the front edge of the trunk.
But it should always go in the trunk.
I have it working 99.5%
#9274 32 days ago
Quoted from Ericpinballfan:
Thank you very much for that info! Do you know how many Houdini games were produced in total? Can't wait to get my hands on this beauty!
#9275 31 days ago
Best guess is somewhere around 600 but they could still make more, especially when they get moved to the new larger manufacturing plant. No guarantee they will but they could.
#9276 31 days ago
Le bras doit être parfaitement aligné dans la fente.
La balle doit toucher le centre du tronc ou légèrement vers la droite.
Si la puissance est faible ou si de nombreux objets tournent dans le jeu, il est normal que la balle rebondisse sur le bord avant du tronc.
Mais il faut toujours aller dans le coffre.
Je le fais travailler 99,5%
275/5000
New power supply installed, EOS installed.
Catapult slightly moved.
Targets A, C, E : slightly moved.
Everything is working fine now.
My game is not set to 6 degrees but more between 6.3 and 6.5
Catapult works very well.
The drummers seem stronger.
#9277 30 days ago
hello josh,
is it possible to predict in the next code:
-a progressive difficulty to trigger Seance Multille and Trunk Multiball ? (for example, for a second time trunk multibill, pull 2 times the lock to turn on the lock 1 .....)
-in the menu, the possibility to do the 10 modes to light a letter houdini (for the moment the maximum is 5)
Thank you
I played a part, and the lighting of the board diminished progressively, who can tell me what mission I played?
Thank you
seb
#9278 30 days ago
I've attached images of the 'power box' for the 'export' machines and the connections inside, which have no burns and all seem intact.
#9279 30 days ago
hello josh,
Thank you
Thank you
seb
Also if possible, leave the houdini inserts off as long as the letters have not been won.
#9280 30 days ago
Ditto^^.
#9281 30 days ago
On the next update I think the lightshow needs more work. It has the theme and modes just needs the code tidied up..
#9282 30 days ago
Quoted from Kenz:
Tough crowd here, we can only hope for improvements but they have other games in development.
I haven't any issues with Houdini.
It is nice though, that we can talk to the designer and he is present.
#9283 30 days ago
Quoted from Platypus:
It is very nice indeed. Looking forward to the update. Josh always seems to take good care of us.
#9284 29 days ago
People are not rough with the houdini pinball machine.
It's a very good pinball machine.
But if by some options, it can be excellent, it's even better.
What is the purpose of the flipper hold boost option?
salut josh,
est-il possible de prédire dans le prochain code:
-une difficulté progressive à déclencher Seance Multille et Trunk Multiball? (par exemple, pour une deuxième fois, multi-facture , tirez 2 fois le verrou pour activer le verrou 1 .....)
-dans le menu, possibilité de faire les 10 modes pour allumer une lettre houdini (pour le moment le maximum est 5)
Merci
j'ai joué un rôle, et l'éclairage du tableau a diminué progressivement, qui peut me dire quelle mission j'ai jouée?
Merci
seb
For more readability, is it possible that the inserts of missions are off and only light when a mission is played?
#9285 29 days ago
Hello, what is the "flipper hold boost" option in the menu?
I have the mod mini wizard after doing the 5 movies, is it a mission without a stopwatch?
#9286 28 days ago
Bought my NIB Houdini #1077 March 14, 2018. Haven't had any real operating issues or breakdowns ...other than the power issues many have referred to on here if too many pins are on on one circuit, the catapult ball launch may fall short and the flippers feel a tad weaker. I have the optional P/S but haven't put it in yet.
#9287 28 days ago
Quoted from CUJO:
Put it in.
It's pretty easy.
Fixes many things.
#9288 27 days ago
Hello, I installed the new power supply.
Everything works well but I find that the black cables connected to the wall nuts are not very strong.
Is it possible to do without the wall and solder all black cables together?
#9289 27 days ago
That's what I did. The wall nuts were crap.
BTW, if you are going to add the knocker, do it before soldering the wires together as this is where it gets it's power from.
#9290 27 days ago
Quoted from GSones:
C'est ce que j'ai fait. Les noix du mur étaient de la merde.
BTW, si vous allez ajouter le heurtoir, faites-le avant de souder les fils ensemble car c'est là que ça tire son énergie.
you also soldered the brown cables between them?
#9291 27 days ago
See post from last week where I provide a solution to the crappy wall nut issue. The key is a terminal block with at least 5 channels. You only need 2 but I got 5 for $12 on Amazon. Much safer and clean solution and WAY, WAY easier to attach the wires. No solder required.
https://pinside.com/pinball/forum/topic/american-pinball-houdini-thread/page/185#post-5084657
#9292 27 days ago
thank you
#9293 27 days ago
Quoted from konjurer:
https://pinside.com/pinball/forum/topic/american-pinball-houdini-thread/page/185#post-5084657[quoted image]
I think your better off with molex connectors.
Terminal blocks are slightly dangerous, but its low voltage...
#9294 27 days ago
I can't recall offhand and I don't have any pics handy but essentially I eliminated the wall nuts and soldered any of the wires together that would have been connected at the wall nuts. I shrink wrapped each group of wires after soldering them.
:-)I didn't realize I was so fluent in French! (I didn't know that Pinside would translate posts)
#9295 26 days ago
Geordi enjoys following the ball, but the new knocker makes him jump.
#9296 26 days ago
Quoted from PhantomO:
Very cool. We have a Blue & Gold and Scarlet Macaws. The Scarlet loves to hang out on his T stand and watch us play. The Blue & Gold however is not a fan.
#9297 26 days ago
How are people adjusting the catapult? Mine is missing more often then not!
#9298 26 days ago
Quoted from Only_Pinball:
Those are beauties. I was always a Scarlet fan.
#9299 26 days ago
Quoted from meSz:
The main thing that has worked for most people is to add the optional power supply and to widen the screw holes in the bracket that attaches catapult coil to the bottom of the playfield.The wider holes give you room to shift the mechanism slightly left or right to get it centered properly on the middle of the trunk. The holes in the metal bracket can be widened carefully with a dremel tool. There are posts that show this in this thread. Search the thread for the word dremel. I readjusted mine yesterday, coincidentally. First time since last summer, because the shot started missing to the right. It is now ok. Fingers Xed.
#9300 26 days ago
Quoted from meSz:
Mine was rock solid when I got it. After about 30 plays it was missing short and found out it was related to my AC running all the time lowering my house voltage a bit. I bumped it up from a 26 to a 27 on coil strength and it would miss left. Pretty sad I have to make sure my AC is not running for it to play right but there is no setting between 26 and 27 to find a happy medium.
Mods for your pinballs
$ 60.00
$ 625.00
