(Topic ID: 183206)
American Pinball Houdini thread
By lllvjr
2 years ago
  • 9,125 posts
  • 538 Pinsiders participating
  • Latest reply 2 days ago by wesman
  • Topic is favorited by 146 Pinsiders
There have been 1,256 images uploaded to this topic. (View topic image gallery).
33 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 9125 posts in this topic. You are on page 182 of 183.
#9051 12 days ago
Quoted from TomDK:
Hi all
I am owner of a Houdini for some weeks now. I bought it used. The first owner was tired of all the technical problems and sold his problems to me
So far I like the theme and the pin but I am also unhyppy with the technique.There is a new power supply in the game. Issues are the very bad flipperfingers. They are on highest setting but still feel week. But all shots are possible expect the ramp with the rigt flipper. The slingshots and bumpers feel slow and powerless. The right scoop is not able to pop the ball out after some hours. It needs 10 times until the ball get kicked out. I bend the scoop a little more open and it works a little better.
The new power supply is strange. It is very loud and noisy and if I open the coindoor it starts to become louder .. this makes no sense to me.
So , a very nice machine I like to play. But with the new Stern BK right next to it, it feels as the whole powerunit is not well calculated or planned.
That a knocker and a EOS (!!) is a extra to buy is a whole other story. Please stop that with all upcoming pinballmachines ....
The flippers definitely should not be weak, especially at the highest settings. The ramp from the right is tough but should be doable even without the flippers maxed out. The power supply sounds louder when you open the coin door just because you are removing a physical barrier to the sound traveling to you, that's very normal. A few questions:
1: How many games are on it and have you made sure the flipper don't just need a rebuild?
2: What pitch do you have the game setup to? It is designed for under 6.5 which would be the back levelers screwed all the way in. I have mine about 6.75 as I prefer that but all the shots are still easily makeable without flippers maxed out.
3: What is your line voltage at the game?
3: Not a question but thoroughly clean the switches for the pop bumpers then adjust the coil setting to make them hit a little harder, I've done this on mine and they are quite active.
4: For the scoop, have you tried turning down the power to see if it improves? Is the problem always with ejecting the ball or is it also / only the release of the locked ball in the scoop? There is a physical (height) and pulse length (electrical) adjustment for the lock release in the scoop.
5: Again, not a question but physical knockers have been removed from Stern games for a very long time (even CV didn't have an actual knocker) and Houdini was definitely not the first game to eliminate EOS switches, though I agree they should be included and I believe they now are at least on Oktoberfest.
Good luck getting it sorted out, I love the game even after a year of ownership and tweaks.
#9052 12 days ago
Quoted from TomDK:
Hi all
Check the output from the supplemental power supply. It may not be up to spec (and it can be adjusted with a potentiometer). Also, check the work of upgrading the power supply. The kit used wall nuts to gang the wiring together, and that item is not recommended for the gauge of wiring used. You might have a tenuous connection.
#9053 12 days ago
I hate those wall nuts. I used a molex connector with jumpers where I can add future loads
#9054 12 days ago
Quoted from Platypus:
I hate those wall nuts. I used a molex connector with jumpers where I can add future loads[quoted image]
I agree, the wall nuts were crap. I wound up soldering the wires together and shrink wrapping them. Didn't want any issues with the main power to the game.
#9055 12 days ago
Quoted from GSones:
Yeah, I hate those things too and did the same as you. I had a ceiling can light that was just installed in a newly remodeled home quit working recently, climbed up in the attic and when I opened up the back of the light the exact same type of shitty wall nut was used and the wire had popped out. I ended up replacing them in every single can light while I was up there.
#9056 12 days ago
Quoted from HOOKED:
Original tapped back strip light. Now there is a dedicated driver in the code to turn it on and off with game play.
Do I need to do anything to take advantage of this? Or is this in upcoming code?
#9057 12 days ago
Quoted from pinballinreno:
Start a game, dont launch the ball, press a flipper button.
Hold the flipper button.
Knock down a flipper manually.
It should come back up on own.
Do a real world test.
Yup, did all that. The flippers do not go back up until I release the flipper button and press it again.
#9058 11 days ago
Quoted from bobukcat:
Electrician tip for you here in case you don’t want to tromp around in the attic, or you need to get into recessed fixtures where there’s no access from above.....the junction box is accessed by removing the trim, then removing a few screws and pulling the guts of the light down.
#9059 11 days ago
Quoted from MattElder:
Normally yes, and that is what I expected here but I tried that and did not see anyway to access it from below. I'm not unfamiliar with these types of things and had a friend of mine that is even more familiar with me.
#9060 11 days ago
Quoted from PhantomO:
You have it installed incorrectly.
Something is backwards.
If its correctly installed it must work.
#9061 11 days ago
Quoted from rosh:
It can, but various certifications are much, much tougher if you are running over 50V. It will also increase electronic damage in the case of a short.
But if its possible and the Power Driver 16 board accept DC power up to 80V why not give a try to more inputpower for the system. I found a powersupply with 60Vdc 20A 1200W. Why not give a try or is it not good for the coil, cause not the EOS "kill" the highpower?
Also found a "DC10-60V 30A 1500W To 12-90V Boost Converter Step Up Power Supply Module" and maybe it can be set up between the power supply and the PD16 board for increase perfomance.
Today I will setup the Voltage on the power supply to about 51V and intall new coils. Hope it works better then.
TomDK: If i think it's the houdini i know, then the power supply is way to loud. Mine is very silent... I can't hear it if I open the door
#9062 11 days ago
Thanks so far, here some answers
The power supply sound louder due the fan is faster on open door ! Please see, or better hear, the video:
https://www.dropbox.com/s/u3lgedxuz9dm0w6/houdini_power.MOV?dl=0
Since 09/05/18 there are 301 games in home use on the machine, so I think there is no need to rebuild anything.
The game is on 6.3 , checked with the pinguy app for IOS. All shots are makeable expect ramp from the right.
Flipperfingers are on 28 from possible 29.
Line voltage is 224 Volts, the output on the powersupply is 47 Volts.
The Popbumper are working , so the switches are fine. Will set them higher this days !!
I bend the scoop a little, will see. Bought also a full set of Cliffys. As you can see in this slow-motion video .. the ball gets on the corner, cracks the coat and fells down again:
https://www.dropbox.com/s/zktxe7niejfiytt/houdini_vuk.mp4?dl=0
Thank you for all the hints !
I will work and tweak on my game. I own all Alvin G.s and a Alien .. so I know what it means to have exotic pinball machines. At least API is still on the market.
With the knocker ... yes they are no longer standart but a friend of mine has a knocker on his Houdini and told me that it knocks on "Catching bullet with teeth-mode". Therefor it is integrated in the game and should be installed from factory.
This friend has also changed the power supply and told me that my changed powersupply is not working correct with the noise. Will see.
My game is strange .. it is a very late game from Septembre 2018 but with a Mirco-playfield .. normally this playfields were IMHO in the first games and later on the supplier changed ?!
Also strange: When I picked up the game the shooterrod was horrible ... I changed with a new one. never saw a shooterrod like this after only 275 games like on the pictures.
IMG_3319 (resized).JPGIMG_3320 (resized).JPGIMG_3323 (resized).JPGIMG_3399 (resized).JPGIMG_3400 (resized).JPGIMG_3401 (resized).JPG
EDIT:
mightygrave YES, its the famous machine you know. Still waiting on a new powersupply from the distribter but I have the bad feeling I have to buy a new one. maybe the one you are talking about ! Should be possible to use this and set in the gamesettings lower.
#9063 11 days ago
So i did following now:
Set new Power supply to 51V Output voltage.
Installed FL 11-629 coils and adjusted coil-settings.
Leveled pin at 6.2°
And boom works way better then before. Not perfect but better!!! During seance mb the flipper will not collapse and the ramp ist makeable. So will keep watching how it ist when the game get stressed.
tomdk maybe WE should Talk together for some Tips
Maybe it's possible and better to Bring the output Power voltage between 60 - 70v for much more constant coil power.
#9064 11 days ago
Quoted from MightyGrave:
Leveled pin at 6.2°
I would say 60v would be about right at 6.5 pitch or lower. It's not over the top and very manageable.
Too much power and you get too many stage rejects.
The 48v is just too weak with all of the other things running, flippers collapse too often.
#9065 11 days ago
So Made 10 Games in a row and it's better but during the game the flipperpower is Not constant. They feeling mushy then super strong and so on.
My Input voltage was fixed at 226 - 227v.
It's better then before but it needs more improvements and tweaks to get constant strong Flippers.
Also i noticed the new powersupply (with the cheap China crappy Fan) is very loud with 51v and when i Play more then 3 Games in a row.
I will thirst try a step Up boost converter and Hope i can increase the Performance of the coils. But i think its better to Install a new Power supply with 60v, 20A and a better fan.
Also i hope rosh can tweak Something via Code (See previous Posts) and maybe AP Had an Idea for an daughter Board.
#9066 11 days ago
So Made 10 Games in a row and it's better but during the game the flipperpower is mit constant. They Feeling mushy then super strong and so on.
I agree the replacement upgrade supply is still weak. It should have been 1200 watts or better. That would give us a better more even power at high loads. Or add big capacitors lol.
Other that getting another supply, it seems more efficient to patch in 12v 6a in series to the 48v circuit towards the flippers.
Power it from the service outlet.
Something like this:
https://www.12vadapters.com/adapter/power-supply/12v/6-amp-6a.html?_vsrefdom=googleads&gclid=CjwKEAjwue3nBRCCyrqY0c7bw2wSJACSlmGZjyxMQdHsRx2Zt_SVT4ZFBb9DRSqBQ75pRoZM89RXxBoCtivw_wcB
#9067 11 days ago
The newer power supplies are adjustable to some degree, and taking it up into the low 50s will likely have benefit. At some point just having a longer pulse times will do nothing since the flipper will be fully extended in 30ms or less.
Keep in mind if you increase the power supply voltage, you will need to lower down some of the coils. This does not apply to the lock releases, which are really time adjustments not power adjustments. But VUKs, Scoop, slings, pops, catapults, etc. could end up being too strong after changing the voltage.
Installed FL 11-629
Current flipper coils are equivalent. Keep in mind our coils have no lugs, which I think is safer in that there is less high voltage exposed under the playfield.
Quoted from TomDK:
We used two playfield suppliers, while the early ones were all Mirco, after that they were a mix as we would get them in batches from each supplier. Towards the end of the run there were more of the Bader being used. There are pros and cons to each playfield version.
#9068 11 days ago
Quoted from rosh:
Thank you for your Input and explanation. And yes i Had to lower the coils. Also Yes your coils are safer and with the plugs its better. And yes you're right less High voltage is less dangerous. But something is responsible for the behavior of the mushy flippers.
STERN had a similar "problem" with LOTR coils and in the last Code ist was possible to change some Parameters of the coils:
The adjustments are described as follows:
53 FLIPPER ADJ 1: Set between 05 to 40. Default is 10. This adjustment sets the minimum fire time for a flipper coil in milliseconds.
54 FLIPPER ADJ 2: Set between 40 to 60. Default is 50. This adjustment sets the maximum fire time for a flipper coil in milliseconds.
55 FLIPPER ADJ 3: Set between 0 to 10. Default is 3. This adjustment sets the amount of time to fire the coil after the EOS switch is seen in milliseconds.
I only want to give some Input for new Things to Check and test cause i like this game so much and
I hope WE all find a solution together.
#9069 10 days ago
mightygrave
Great work and input !
I am compeletly "with you". Same for me .. I like the game but the coils are a nightmare and no fun to play on this level. As I stated , the former owner sold it to me and was happy to have it out of the house due to the problems. He "lost" several hundred Euros in 6 month with the game.
To the powersupply: Please listen to my video .. than you can hear that it is the powersupply fan working faster when the door is open .. this makes no sense ! The voltage is not changing with door open or closed , only the fans noise is changing.
If I can play the game with more fun I would be willing to buy an other powersupply. The "official" one in my machine is not labeled , looks like china stuff and I can not see a screw/potiometer to change the output.
Today i will bring in Cliffys to protect the playfield ...
#9070 10 days ago
Quoted from TomDK:
mightygrave
I heard the noise your powersupply made. And its Not normal. I found a powersupply for about 75€ at Amazon. But its not really quite, maybe its possible to Change the Fans. I think it would be a good attemp.
But i'm Not shure If it will help.
It would be good to know how much ampere will needed on the "highvoltage Input" for coils and Magnets / powerconsumation is.
Also still interested why the coils Flip between beeing mushy and Strong during a one Ball game.
#9071 10 days ago
Hi everyone, new to Houdini ownership but having lots of fun. Took a while to dial in the game but I feel things are set up pretty well at this point.
A lingering issue relates to the plunger having quite a bit of friction when pulled back to launch ball into the playfield. Although I haven't played any other Houdini pins for comparison it seems very rough and I'd love to have a smoother feel.
Does this sound normal? Any advice?
Cullen
#9072 10 days ago
Quoted from CullenT:
Cullen
Check to see if there is a washer installed on the rod to the inside of the game (between the shooter spring and inside of housing), if there is remove it and it should resolve your issue.
#9073 10 days ago
Ok thank you will try that for sure. Might be a week or so before I can check back as I can't get to the game before then.
-Cullen
#9074 9 days ago
Pull the plunger back and rub a little bit of wax on it.
#9075 9 days ago
Cullen
The washer on the plunger isn’t filed down as it should be. Either remove it, or pull it and file it down/replace it. Then yer good
#9076 9 days ago
Cullen
Had the same .. buy a new handle. The original is very cheap material and looks like galvanized. The one I got from Marcos is stainless stell, no galvanik I guess. Also change the nylon tube and your skillshots will fit !!
Right side the original after 250 games, left side the new one.
#9077 8 days ago
The Hooked on Pinball water torture mod now runs factory programming from Josh. I posted a video of this. According to TWIP, this is the first after-market pinball mod to receive custom programming from the manufacturer. Watch how on Magician's Choice, the GI lighting turns dark and dramatically shows the blue tank illumination flashing when the water torture stage mode is showing or selected. The mod flashes again on completing the mode. When you get the mode without Magicians Choice, the mod flashes for the first shot and on completion. All other times it is lit solid.
#9078 8 days ago
Maybe I misunderstand something. When I push the button, the two eos blades are pressed together, making contact. I then force the flipper back to a resting position, while still pressing button. Doing so causes the eos blades to break contact. So why would the coil fire again and raise the flipper on its own, with the blades not in contact? If I manually press the blades together so the make contact again, then the coil fires and the flipper pops back up - left flipper does this faster than right flipper, for whatever reason. So based on this, what is not working right? I double checked the wiring and the left vs right, etc. Looks fine.
#9079 8 days ago
Very cool! Is this in the upcoming code update?
#9080 8 days ago
Quoted from Rdoyle1978:
It is in the current version, and can be turned on or off. It is last on the features setting list. I didn't look yet at what happens when it is turned off. Probably just stays lit.
#9081 8 days ago
It's my understanding that if you are cradling a ball and the flipper bat gets knocked down the EOS sw opens and signals the coil to fire and return the bat to the erect position. This is a software thing not electrical connection. yours seems to work opposite, strange.
#9082 8 days ago
A normally open EOS switch should be checked by the software and if flipper button is pushed in but the EOS is not closed the system should send another long pulse to raise the flipper. That's the whole point of them.
On my game if you really force the flipper down with the button held it will stay down but if you just kind of slap it down like a ball most likely would it snaps back up. I assume (Josh can confirm or deny if willing) that this is because it only sends one long pulse after it sees the EOS break and then goes back to the hold pulses, most likely to protect the game in case the EOS fails.
#9083 8 days ago
Quoted from TomDK:
Right side the original after 250 games, left side the new one.[quoted image][quoted image]
Ok wow thanks for sharing your experience and for the pics. Very good to know. I'll look at making this upgrade.
Cullen
#9084 8 days ago
Does anybody else get rejects from their milkcan chute? I swear that 70% of my shots get completely into the chute and hit the guide at the 10:00 position and then kick out. I am about to reshape that guide but I wonder if there is any wiggle room. I might elongate the screw holes on the middle mount.
I'm curious if anyone else has this experience.
#9085 8 days ago
Oh Ya, its normal. Im a year plus into my game. Id figure i would get to this fix to. However, its part of the challenge. Soft milk can shot is the key.
#9086 8 days ago
I drooped my flippers to angle down 1/8" from the factory setting.
Milkcan shot is much easier.
#9087 8 days ago
I bent the rail a bit and used some velcrostuff, also dropped the flippers like pinballnero. Now the shot is buttersmooth with zero rejects.
#9088 8 days ago
I did this some time ago. I can hit the hole just get lots of kickouts.
Quoted from Ericpinballfan:
soft shot is easier said than done, especially at the end of the bat.
That's what I am talking about, will give it a try. My wife just left the house, good time to fiddle on the machine, she prefers that I do domestic tasks....
#9089 8 days ago
You may have posted this before, but do you have any pictures that would show what you did? Thanks...
#9090 8 days ago
Pinbits Foam works well too
#9091 8 days ago
Quoted from zahner:
Several pages back. Think vireland mentioned just some black sticky felt from any craft store. Line turnaround with felt after cutting to fit.
#9092 8 days ago
There you go!
#9093 8 days ago
Quoted from zahner:
Sorry Didn't make any pictures cause it was a easy 10 minutes job. You have to unscrew the milkcanrail (one Nut). For the Long plastic you have to unsrew both nuts and two screws from the plastic with the stand offs and both screws where the plastic sits in the woodrail.
I bent the "feets" on the laneguide a bit up. So that the laneguide is leaning backwards a bit. Fits perfect.
Also ordered a new 60V 20a 1200W powersupply from Amazon today. Want to test how it works. Will give a Feedback ob friday.
#9094 7 days ago
REALLY BIG shout out to API customer support and Barry!
15 month owner of game and the customer support is amazing. Contacted Barry and he was able to help me out very quickly.
Top Notch service as always and a very dedicated team at that factory!
Over on the oktoberfest thread I see the same dedication and looking forward to many, many years of American pinball unique games.
#9095 7 days ago
Ditto - AP Support is TOP NOTCH! Hope they will produce more fun games over the next years. And one game per year is a perfect turn
#9096 7 days ago
I made my milkcan lane adjustment yesterday. I pulled the lane guide and bent the curve to be a little deeper. Tolerances are tight here and I enlarged the mounting holes slightly to get it to fit back in.
I searched my shop for some Velcro stuff, couldn’t find it although I know I have some. I found some adhesive backed felt but they were small dots for use on cabinet doors. I also have some felt strips but much too thick.
Then I came across some thin textured rubber material, a 3M product intended for adding to stair treads. It’s very grippy and works great almost stopping the ball in the chute followed by a slow drop to the inlane.
After several shots into the milkcan chute I didn’t have a single reject. Now I just have to master the ramp.
#9097 7 days ago
Sometime back I set out to make a subwoofer for my Houdini. This lead me to reading up on speaker design which was much more involved than I wish.
I decided upon an 8” speaker which I ordered along with other parts from parts express for around $35.
The driver specs recommend a box volume of 1 cu ft. I built the box out of some scrap particle board I have laying around.
#9098 7 days ago
The driver specs recommend a box volume of 1 cu ft. I built the box out of some scrap particle board I have laying around. Cabinet design calls for internal bracing which I made sure to include. I didn't like the grill mounts they shipped so I made my own.
They also recommend adding some dampening material inside the box, poly fiber like pillow stuffing is common but I just used some ugly stocking caps that I don't wear anymore. winter was over anyway.
AE4B6A20-66B3-43D1-9153-D52309786FCA (resized).jpegBDE9FFF9-7E24-4C7A-BC83-A6C3D3CB09FA (resized).jpegE57F0AA8-106F-4F60-AE79-60F1182195DF (resized).jpeg
Instead of having the speaker wire dangling out the the machine I installed a phono plug on the bottom of the cabinet with internal wiring going to the amplifier in the back box. The plug is recessed so as not to catch on anything.
45443B9F-45C0-4C56-B809-37648FD7FF51 (resized).jpeg8603B3EF-8B1B-4CF5-9412-8530446D86A8 (resized).jpeg
#9099 7 days ago
Instead of having the speaker wire hanging out the the machine I installed a phono plug on the bottom of the machine with internal wireing going to the amplifier in the back box.
Nicely Done!! The whole project, speaker and mount inside cabinet for wire.
Brings me back to an idea I've toyed with for a Year.....
Start drilling holes in my cabinet??!!
#9100 6 days ago
Let me clarify some things on EOS and how you need to test it to see if it is working.
If the Flipper button is held in, when the EOS switch opens, the game will re-fire the main power on the flipper coil. The best way to test that this is working is go into game play, hold in the flipper button and then throw the ball at the tip of the flipper and see if it fires back off. It will be pretty clear that it is not just a bounce off, but has some power behind it.
If you use your hands to push the flipper down, it is NOT going to fire back up. The re-fire is taking place after the flipper comes down just a little bit, but your hand pushing on it is going to be so much stronger, you will not even feel the re-fire. It will only attempt the re-fire the one time that the EOS opens (with flipper button depressed), so once it is pushed past the EOS and the re-fire happens it is not going to attempt it again.
If you just try to flick it down with a couple of fingers, you might be able to test it, but using the ball is the best way to do it.
You can only test the EOS re-fire is working, when in game play, not when in the service mode.
Flashinstinct
$ 50.00
$ 279.95
5,999
Fargo, ND
Mods for your pinballs
$ 6,995.00
Operation Pinball
$ 119.95
Hookedonpinball.com
$ 6,995.00
Flip N Out Pinball
$ 32.25
The MOD Couple
$ 27.50
The MOD Couple
$ 6,995.00
Flip N Out Pinball
$ 6,999.00
Classic Game Rooms
$ 6,995.00
Great American Pinball
$ 60.00
$ 6,995.00
Nitro Pinball Shop
6,995 (OBO)
St. Clair Shores, MI
$ 279.95
$ 39.95
Little Shop Of Games
$ 68.00
The MOD Couple
6,100 (OBO)
Albany, NY
$ 399.95
