Quoted from Platypus:You will get more proficient over time, mostly you are only dealing with screws and nuts. just be observant where parts came from and go back. I would let heavy things dangle by their wires, support it somehow by string, scrap wire or something. The switch on that VUK has fragile connections. Eventually you may need to adjust switches, replace mosfets and coils, hopefully not for a while.
I believe you were advised to get magnetic nut drivers. I have multiple sets of non mag drivers ( use them for my work) and still bought magnetic ones just for pin work. I also have a magnitizer for my Philips drivers, That is a savior at times. I hate loosing a screw in the under playfield mechanics /switches and such. I have resorted to taping a screw to a driver is certain instances but then you have to contend with the tape if it doesn't release right once the screw is started.
Where did that chip come from? what might of caused it? did it happen with your playfield accedent? I doubt it was a ball. I would't be that concerned about those micro cracks under fasteners, you can't see them. be careful about over tightening
All very sound advice!
I definitely wasn't comfortable letting the VUK dangle, and I think I only let that happen once, during the constant raise, lower, raise lowering of the playfield. I am paranoid if that maybe created an issue with the VUK firing half of the time now, but as I mentioned, I'm not sure if that was already occuring, and I just didn't notice....
The chip, I really have no clue. I know the piece slid out when I raised the playfield that first night, and I certainly didn't have any equipment fall on or scratch the table. I've forgotten to eject the balls a few times, but other than that, nothing else entirely boneheaded. Raising and lowering the playfield is definitely far, far more comfortable, as I now understand how the cabinet rails work. I really had zero prior experience with a pinball table mechanically prior to this.
That said, I returned the Klein magnetic nut drivers, due to reading some reviews where they said the bits turned into power and crumbled, and as well as the price, and I really figured I'd use them just once or twice for a few minutes. Weeks later, I now find myself removing multiple table parts, placing them on a sheet of paper with notes for screw and nut placement, all just to get one tiny protector in. I truly never imagined delving this deep. It's been an experience, that is for sure!
