(Topic ID: 183206)
American Pinball Houdini thread
By lllvjr
7 years ago
  • 14,818 posts
  • 755 Pinsiders participating
  • Latest reply 12 days ago by bobukcat
  • Topic is favorited by 204 Pinsiders
41 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 14,818 posts in this topic. You are on page 133 of 297.
#6601 5 years ago
Quoted from PhantomO:
My scoop has been pesky in the same way since installing the upgrade. Wonder if it is work widening the hole on the steel ball guide to push the ball out more toward the flipper?
The issue is the random bounce out of the scoop.
Sometimes the ball follows the lane guide, sometimes it bounces off the lane guide, sometimes it just dead drops.
Angling the scoop either by bending the upper scoop or by adjusting the mounting position may help.
It also can make it worse.
I have been dead dropping the ball in the lane from in front of the scoop to check the lane behavior.
I haven't figured out anything that makes it consistant yet.
I have had some promising results from adding a thin washer under the upper left mounting hole.
#6602 5 years ago
One other concern is bounce outs from a strong hit to the scoop.
The ball hits the rear ledge of the scoop and rebounds out instead of dropping inside.
This started when I lowered the playfield pitch to 6.15 degrees.
This is probably from adding the cliffy. It firms up the rear ledge and makes it springy instead of the plywood edge absorbing the shock.
I'll have to see if bending the scoop forward or adding washers to the rear helps.
#6603 5 years ago
Quoted from pinballinreno:
Let me know what you find out. I have the cliffy and havent had many bounces, but the inconsistency seemed worse after installing it. At pintastic in june, Joe Balcer said that Api was going to provide a scoop modification, to deal with the inconsistency, which was an issue then. But I havent heard more about it.
#6604 5 years ago
Has it been raised that there’s no indication of where the ball is going to be released from after it being staged either on the left, or the scoop or being flung from the trunk. I find that a little frustrating.
#6605 5 years ago
And I find I’m getting rejects from the milk can shot more often than not. It bounces back from well within the shot too
#6606 5 years ago
Quoted from Audioenslaved:
I believe this is intentional - the ball is “disappearing” and “reappearing”. None of the shots catch you entirely off guard though. Are you getting a lot of drains ?
#6607 5 years ago
This was brought up a long time ago right after the game started shipping and rosh (who wrote the code for the game) has stated it is on purpose as he feels it fits the theme.
#6608 5 years ago
Mine too; you have to hit that shot very delicately and the weird angle requires precision. This shot is way harder than the inner loop everyone complains about
#6609 5 years ago
Yep, I get them too mainly with really fast shots, slower ones will go through no problem. This is very similar to the behavior I get from the Crystal Ball shot on WOZ which is very similar though CB does have a spinner as well.
#6610 5 years ago
That is how it is intended... Where will the ball appear from?...Magic!
#6611 5 years ago
Does anyone know if new Houdini machines are now equipped with the better power supply? Tnx
#6612 5 years ago
I had to adjust my wire form under milk can.
Prior to doing this I almost avoided the shot but now its 50/50 bounce out.
#6613 5 years ago
Quoted from HOOKED:
How did you adjust it?
#6614 5 years ago
Lower the flipper's angle 1/8"
I make the milkcan 80% of the time with no bounce outs.
#6615 5 years ago
Quoted from bobukcat:
I lowered my flipper angle on my WOZ also about 1/8" for this issue.
#6616 5 years ago
Quoted from Rdoyle1978:
I took Brass pliers and bent the exit side rail in slightly. I did not adjust flippers from factory positions but I would try that first.
#6617 5 years ago
Quoted from HOOKED:
Aah thx
#6618 5 years ago
Quoted from mcbPalisade:
I doubt it since not everyone is affected. However, even though the one here was pretty solid, we still ordered one to help with mushy flippers in multiball with the magnets and everything going at once.
#6619 5 years ago
I am curious about the power supply as well since I await the delivery of my machine any day now. Regarding the software issues, I just played the best game I have ever had on a distributor's demo model, which has the latest update, and it crashed after I finished [aka: "FAILED"] the Master mode - said mode being totally cool with inverted flippers and crossed arms and total chaos.
Prior to that, I was dealing with the Metamorphosis mode and completed it for the first time. As I progressed, it went into a very awesome strobe-dark-flashing multi-ball presentation that was great. Part of Metamorphosis?
Can't wait for mine to arrive. Such a great game. Hoping the software issue is resolved. Also eager to see how Oktoberfest is in person to compare American's efforts.
#6620 5 years ago
If so, will you be buying one?
#6621 5 years ago
Quoted from zahner:
The dark mode with the roving white inserts is actually a FILM mode called Man From Beyond, it's awesome. I haven't made it to Master Magician mode yet but it's a known fact that it crashes after that mode and the developers are working on that. The inverted and reversed flippers are an option you can choose to play in Straight Jacket Mode too (you choose either reversed or reversed and inverted).
#6622 5 years ago
Ah, The Man From Beyond, good to know. Sometimes it’s hard to know where you are in the game, probably because it is set on “easy,” and I get multiple things going all at once.
Being set on “easy” is no doubt the only reason I dumbed into the Master mode in the first place.
Thanks for the info.
-1
#6623 5 years ago
Quoted from BarryJ:
No. Not my cup of tea. Didn't even play the one in Banning. I heard from others that it wasn't adjusted right (the total content of this thread now, eh?). I didn't have a coin door key to try to tweak it to play "right". So I played the other 536 pins & Battlezone of course.
#6624 5 years ago
Quoted from BarryJ:
We were selling it at expo. I believe the price is $235.00 Comes with mounting hardware and external 12V power supply. We should have it on our web site today.
This API topper is pretty cool. It's not easy to see in Barry's photo but there are two layers; the Houdini logo in front and the Metamorphosis trunk behind. So you get a little 3D effect as you approach the machine. I do like the API topper over the Laserrific topper. I'm still leaning towards the Houdini topper by Modfather.
houdini_topper4_1024x1024 (resized).jpghoudini_topper4_1024x1024 (resized).jpg
#6625 5 years ago
Quoted from BarryJ:
Barry,
Is the topper switched on when the pin is turned on?
#6626 5 years ago
Looks light I need to replace the second switch for the left lock. Even though I have tried bending the metal arm of the switch, the switch stays closed and also the metal arm is very stiff and blocks the ball. Is the switch available as a general part from pinball parts shops or is this something I need to get specifically from American Pinball? If this part is available from pinball parts shops, what is the part number?
Thanks for any info!
#6627 5 years ago
Quoted from Nepi23:
Pretty sure it's just a standard trough switch with the roller. Like this:
https://www.marcospecialties.com/pinball-parts/180-5119-02
#6628 5 years ago
Quoted from PinMonk:
Thanks - can you Barry please confirm?
#6629 5 years ago
My Distibutor will contact AP soon, to send me the powersupplyfix.
The wait is over and there is light at the end of the tunnel
#6630 5 years ago
Quoted from Nepi23:
You mean upper playfield lock, correct?
Mine did the same thing. Have you tried loosing it up with the 2 small screws? Once loose, but still attached, see if it works now, if so, now tighten back up slowly. Worked for me.
#6631 5 years ago
I know it's not "your cup of tea", just trying to figure out why you are so interested in bashing Houdini at every turn, eh?
As for the adjustment factor, Houdini is a total package game, deep rules and a "total" customizable playfield via solenoid adjustments, now throw in the 22" catapult shot (longest ever on a pin) and yes you need to give the table some attention.
#6632 5 years ago
Quoted from mbwalker:
Barry,
No the Houdini topper uses a separate 12 volt supply.
Oktoberfest will have an integrated Topper that will switch on and off with the game and maybe turn on and off in game play (we have that ability).
#6633 5 years ago
Quoted from Nepi23:
That is correct... This is the switch.
-4
#6634 5 years ago
Quoted from BarryJ:
There are people here who love this machine in spite of all the time they spend tweaking it, I'm just in the other camp. Fair, yes?
Also the ball throw was previously listed as 20" but has grown to 22". Feature inflation - maybe you measure diagonally now like TVs
#6635 5 years ago
Quoted from Ericpinballfan:
Its the left lock. I can try it, but I had removed the switch altogether yesterday and fastened it again with the 2 screws and I tried to fasten it tightly and and also by keeping it loose - still the metal arm kept binding the ball. I think its best to change to switch altogether. Its only a 4 EUR part
14
#6636 5 years ago
Perhaps it was cold out during the first measurement.
#6637 5 years ago
Quoted from BarryJ:
Ok thats Dam funny there!!! lol Volley, serve, Home run Barry!
-1
#6638 5 years ago
From your web page. Your marketing guys and gals must have thin scrotums!
#6639 5 years ago
22 > 20, pretty basic math right there. I feel there is another scrotum joke I'm missing out on making here but I'm trying to be polite.
10
#6640 5 years ago
At this point you have made it clear you don't like Houdini, we all understand that. Just not sure why you spend so much time here. Which is basically owners and players learning and helping each other.
-4
#6641 5 years ago
Can't argue your math technique, but I think most readers here know that if advertising says 'Over 20"' it usually means 20.1" or in there somewhere.
If it measured 22.01" you would advertise 'Over 22"' Each reader here can be their own judge on this. In any event both different numbers come from the same company which I question.
As for anatomy look up "undescended testis"
11
#6642 5 years ago
Quick update on the code that has been in beta test. I am working on a couple of bugs that were identified in last few days, and an enhancement or two, that I want to get into this release. I hope to be done with the last bits shortly.
#6643 5 years ago
Quoted from rosh:
I am disappointed with what AP has done so far and hope they do better in the future. Houdini is nice in some ways and a failure in others.
This is a time where no one or no thing is held accountable. I guess we're supposed to ignore negative things nowadays.
#6644 5 years ago
I guess if we had said 22 on everything instead of 'over 20', we would have sold hundreds more. Wait, maybe we should calculate the distance the ball travels side it does move along an arc, so maybe we could go even higher! Also good thing we said over 20, since I'm sure if we said 19, half the guys here would not have bought! Show of hands, who would not have bought if we had used a number under 20"wondering if I really need to put a sarcasm emoji
#6645 5 years ago
Going forward I will address the length of the Catapult shot as "over 20 inches, exact length depends on the weather, your results may vary"
Think I covered it all..
-2
#6646 5 years ago
AP - do an excellent job on O.F. Don't release it before it is thoroughly tested and ready. Don't update the code 40 times after it is shipping.
All the above could have been worded in the positive sense for O.F. but I feel the above applies to your first machine.
#6647 5 years ago
So you rip on them for the 22" and "over 20" stuff and then throw the 40 code update thing out there?? My GOTG has had way more code updates than Houdini has and the initial code on Houdini was WAY more baked than GOTG or most Sterns initially ship with. Neither are even close to approaching 40 or even 20 though.
The A.P. crew has also been very good about listening to feedback from customers and addressing legitimate issues in a very professional way, in my experience. Nothing is ever perfect and if manufacturers (of nearly any product) waited for code to be completely bug-free you'd see one new product every 25 years (I can do hyperbole too, yay!).
The ax you have to grind with these guys should be really, really sharp by now.
#6648 5 years ago
Quoted from rosh:
I'm just upset it's not listed as "over 508mm" to make it sound even more impressive and to cause all us Americans to convert mm to inches!
#6649 5 years ago
Dude, we get it, now you’re just coming off like a D-bag. Nobody is trolling you, just flush it.
And I dare say we should all show Rosh and Barry a lot of respect for coming into this thread and for ALL the support they are constantly providing, on top of their regular jobs where they also have to monitor the standard support channels.
Thanks guys!!
#6650 5 years ago
I know you're being hyperbolic, but WOZ is on its 45th post-release update, and probably not its last.
It seems to have sold pretty well.
The more complex the game, and the earlier in the company's product line, the more code updates it's going to take to get somewhere near the finish line .... which is also why it's particularly inexcusable that Stern machines often launch with bare, bug ridden code, and take ages to get to either a good or acceptable state. They're relatively simple and lacking in features, and Stern have been using the same or very similar software frameworks for years and years. Houdini and WOZ are far more complicated, and were the first releases.
Rubber/Silicone
Maine Home Recreation
$ 69.95
Hookedonpinball.com
5,800 (OBO)
Festus, MO
$ 33.25
The MOD Couple
5,800
Albuquerque, NM
$ 48.00
The MOD Couple
$ 7,995.00
Classic Game Rooms
$ 685.00
$ 28.50
The MOD Couple
Precision Pinball prod.
Mod Magic!
5,400 (Firm)
Silver Spring, MD
Pinball Invasion
6,500 (OBO)
Fitchburg, WI
$ 7,395.00
Classic Game Rooms
$ 7,499.99
Pinball Pro
$ 7,395.00
PMP Amusements
$ 45.00
Playfield - Plastics
Mod Magic!
$ 7,995.00
$ 7,295.00
This page was printed from https://pinside.com/pinball/forum/topic/american-pinball-houdini-thread/page/133 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
