American Pinball Houdini thread
(Topic ID: 183206)
By lllvjr
2 years ago
  • 8,541 posts
  • 526 Pinsiders participating
  • Latest reply 1 hour ago by wolftownjeff
  • Topic is favorited by 144 Pinsiders
There have been 1,182 images uploaded to this topic. (View topic image gallery).
32 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 8541 posts in this topic. You are on page 129 of 171.
#6401 5 months ago
Quoted from PersonX99:
I plan on ordering the upgrade power supply, but I have been working on another issue I am hoping some folks can chime in on:
Direct shots to the stage usually bounce out. Some ricochet shots from the pops to the stage bounce out (not often, but sometimes).
I have adjusted the flipper strength down to where it feels good and can make all the shots. Same result for stage shots.
I go under the assumption that most direct shots to the stage should NOT bounce out.
I was going to try some deadening foam strips on the sides and back of the stage. My thought was that it will absorb some of the energy of the ball, perhaps enough to keep it in the stage.
Any thoughts on how I can make this shot more reliable?
Thanks.
Lower the pitch, lower the flipper power.
Or, raise the pitch and leave the flipper power where it is.
Pitch at 6.2 or 6.3 and flippers at 25 to 27 seems to work well enough..
#6402 5 months ago
Thanks.
What's the number of your flipper strength. It can "feel good" and still be too strong. Usually bounce outs are because flippers are too strong.
#6403 5 months ago
Quoted from pinballinreno:
27 is a LOT. I think ours are at 23.
#6404 5 months ago
Thanks.
Mine bounced out a lot more When I had flippers up a setting or two, 22 or 23, whatever the value is
#6405 5 months ago
Quoted from vireland:
I had my pitch up a bit at 6.5
Recently lowered it to 6.2.
Flippers now at 25-26. I might lower them 1 more notch due to some air balls.
Factory pitch at 5.9-6.0 seemed too floaty to me.
I'm dialing it in for the new power supply. It plays differently, way better in a lot of areas.
I'm trying to find a happy medium between ramp rejects and bounce outs.
I really want the ramp shots to be strong. I can deal with a few bounce outs.
I hate weak ramp shots.
#6406 5 months ago
Holy crap, 26! Mine are at 22, and I dialed them WAY down when pitch was at 6.0 so I could get those delicate shots.
Changed out my flipper rubbers to traditional red rubber. Huge move; I couldn’t get control of the ball before, now it’s pretty easy
#6407 5 months ago
Thanks.
I've seen this discussed prior. I think it was mentioned the Stage Alley is what was intended to actually send it to the Stage. I also try to ricochet off the ESCAPE letters which tends to get it at the proper angle to stay in the stage.
#6408 5 months ago
Location Houdini at Marvin's in farmington MI has a few wear and tear issues that we may expect on home machines eventually. Both flipper toppers are broken. Blue lens missing from one spotlight lamp, and planchette is twisted around. Trunk shot is aligned but misses short. There are red rubbers on the flippers instead of the purple silicones, which seems to make backhands easier. Software seems to be two versions old. Ball save is generous but other settings are standard hard. I also enjoyed Iron Maiden premium...great animations, callouts and tricky shots. JJP Pirates was stuck in perpetual ball search, sadly. Deadpool premium was interesting and funny.
#6409 5 months ago
Quoted from Hogey:
Just installed the new power supply. Went in easily even with these strange looking “wood” screws. No biggie, just surprised when I opened the small envelope.
Mine had the same 'wood' screws. Anyone know the correct size of wood screw that should be in there?
#6410 5 months ago
Quoted from Rdoyle1978:
Still making adjustments with the new power supply installed.
Catapult is rock solid and NEVER misses.
I lowered my pitch to 6.15 tonight and lowered my flipper power to 25L and 24R less air balls.
Stage alley shot is solid, no bounce outs.
It does not seem floaty at this pitch.
Ramp shots were doable but not as thrilling.
Orbits still fast and very repeatable.
I think something should be added in the code if you make consecutive orbits or ramps etc. Like a callout or something.
I increased the pops up 1 each.
Scoop is at +1, was getting a few retries at default but no SDTM's.
Scoop shot is pretty erratic. I'll see if I can tighten it up a bit.
Increased slings +1
Milk can much easier at lower flipper power and 2mn drop in the flipper angle.
Everything plays really well, still dialing it in with the new power supply.
I'm still adjusting to the new feel of the game. It definitely plays differently.
All in all I think it's a lot better and more powerful.
I'm getting used to it pretty quickly.
I have to put a few dozen games on it now and wax it with P21S.
The game is amazing!
#6411 5 months ago
Increased slings +1
Can you take a photo of the way you have your flippers set? I tried dropping them and the game just performed horribly - lots of drains SDTM. I'm wondering if I did too much.
#6412 5 months ago
Quoted from PhantomO:
I believe both iron maden and dead pool are both pro models
#6413 5 months ago
I really like the "Most efficient" Highscore. It's a new way to play a pinball machine. You have to get as many point as possible in a very short time as your points per second are counting here. It's like a Speedrun. Here's my best example with just one mode startet and combined with the multiballs and multipliers. Wish other machines would have that as well.
#6414 5 months ago
Quoted from tatapolus:
I really like the "Most efficient" Highscore. It's a new way to play a pinball machine. You have to get as many point as possible in a very short time as your points per second are counting here. It's like a Speedrun. Here's my best example with just one mode startet and combined with the multiballs and multipliers. Wish other machines would have that as well.[quoted image]
Wow, you have really mastered the stacking and multiplier strategy!
#6415 5 months ago
Quoted from mbwalker:
They sent out regular #8 by 1/2" playfield hex screws with mine.
#6416 5 months ago
I posted a photo way earlier in this thread.
Basically I dropped the flipper angle about 1/8" using the hole near the tip of the flipper as a reference. About the thickness of the flipper rubber.
I'm not seeing any difference as far as SDTM's, the gap between the flipper tip and center post is the same, maybe a little tighter than default.
Too much drop and you can hit the slings though.
It's much easier to make the magic targets and milkcan shot now.
You will have to adjust your game play if you are used to the default.
It's a very minor change but has big impact as far as the tight edge shots.
#6417 5 months ago
Yes I can backhand the inner loop on my game and backhand the ramp from the right flipper
Really? Who else can do this on his game?
Did you adjust the flippers or not?
#6418 5 months ago
Quoted from colonel_caverne:
Mine are currently set as one would set up a B/W game (or I guess all games) using a toothpick in the little hole and the flipper bat resting against it. Or by eye, roughly straight with the lane guides
#6419 5 months ago
Sounds like I dropped mine way too much. I’ll try that again some time. Will have to look for that photo
#6420 5 months ago
my flipper is at 23 and i can make it almost every time.
#6421 5 months ago
Page 118 post 5889 in regards to the flipper adjustment pics
#6422 5 months ago
Quoted from Wmsfan:
Yes! That's it
#6423 5 months ago
Anyone who has installed the power supply upgrade...do the brown and black wires go into the wall nuts through one of the black circular holes or do they go through an opening on the clear plastic side? I haven't worked with this kind of connector before. Thanks. Off to dig up some wood screws now...
#6425 5 months ago
Anyone wo has installed the power supply upgrade...do the brown and black wires go into the wall nuts through one of the black circular holes or do they go through an opening on the clear plastic side? I haven't worked with this kind of connector before. Thanks. Off to dig up some wood screws now...
They go into the back of the connector that already has one brown or black wire going in. I want to say there are 6 openings on the correct side, with one colored wire already going in. They can go into any of the empty spots.
Just make sure to keep the black with black, and brown with brown.
#6426 5 months ago
Quoted from Wmsfan:
That makes sense, thanks!
#6427 5 months ago
It seems like the existing ends of the disconnected wires can fit into the wall nut without having to be cut off and stripping the wire. I will try it that way.
#6428 5 months ago
It seems like the existing ends of the disconnected wires can fit into the wall nut withouwt having to be cut off and stripping the wire. I will try it that way.
I tried as well, but I couldn't make it work. Just cut right below the existing connector, strip about a half inch, twist the wires and insert into connector.
#6429 5 months ago
Not working - too thick and slip out of the nut too easily. Gotta cut the puppies off...
#6430 5 months ago
Found this loose nut in the back of the cabinet. It matches the 4 that hold the coin door to the cabinet, but thay are all in place. Couldnt find a bolt that is missing this. I think it is for the cabinet rather than playfield because it is so large.
#6431 5 months ago
Since lowering my playfield pitch the ball lock is dragging when there is only a single ball.
Sometimes I have to shake the game while its pulsing to get it free.
I guess i will have to bend the actuator up a tiny bit?
If they become a problem i might have to replace the switches with original cherry switches. They are a much lighter force.
What do you think? I know it's been covered before.
#6432 5 months ago
According to Joe, the flipper bat should point to the hole, not sit above it.
Not following, are you talking about the left ball release? Are you saying when a ball enters the lock it does not go all thew ay to the first switch, or after a release when there are two balls it does not move down?
I strongly recommend against changing the switches, those are the correct ones to use. Also be very careful if you adjust them, very easy to make matters worse. You may want to try to adjust the coil 'strength' in coil settings to have it hold the plunger down slightly longer. For the lock release, it does not change strength but the duration of the pull.
Not sure, but check the lock down bar, the bolt in the middle goes through the coin door, but there might be one towards each end, don't recall if the cabinet is designed that way or not, but I know I have had that with other cabinets.
#6433 5 months ago
Quoted from rosh:
Thanks Josh that's what I needed to know!
It's all fixed! I increased the left ball release 1 increment in the service menu. Higher numbers, the post seems to dwell down longer, lower numbers raises the post earlier.
Nothing wrong with the lock release switches, I couldn't get the ball to hang on one at all.
#6434 5 months ago
Quoted from rosh:
Neither of these statements are accurate
This is my first game with joe and Jim was not yet at American pinball when the playfield was designed. But our names do start with J
Only can go by what I am told.....
#6435 5 months ago
Quoted from BarryJ:
Obviously talking to the wrong people
#6436 5 months ago
Quoted from rosh:
Thx for the clarification!
#6437 5 months ago
Quoted from beatmaster:
This is the coil power.
But did you keep the factory position of the flipper?
#6438 5 months ago
yes.
#6439 5 months ago
So did you need wood screws?
#6440 5 months ago
playfield screws are wood screws - but I think with some of the packs they sent out self-drilling screws (mine were)
#6441 5 months ago
Off to the hardware store I go!
#6442 5 months ago
Just got the notice from AP. New power supplies are available from them for people having issues with coil fade. $150 out of pocket, but they'll let existing customers have a $150 credit for their store to offset this:
September 26, 2018
Our goal at American Pinball is to provide quality games at affordable prices.
As many of you know, some Houdini owners are experiencing weak coils when the incoming AC voltage drops because of external loads placed on the service line. We have incorporated a new 48 Volt Power Supply to offset the effect of low incoming AC voltage on the coils.
We are selling the new Low Voltage Offset Power Supply for $150.00 which includes a switch mode 750-48 power supply, retrofit wire harness, hardware and shipping.
We greatly appreciate our customers and to show this, American Pinball will provide a $150.00 credit* with the purchase of the “Low Voltage Offset Power Supply” to be used either at our online store or towards the purchase of an Oktoberfest “Pinball On Tap” machine.
Purchase the power supply online at
https://store.american-pinball.com/products/houdini-power-supply-upgrade
Your Houdini machine needs to be registered prior to the power supply shipping, register your game at
https://www.american-pinball.com/support/register/
Regards,
American Pinball Inc.
Phone: 847 893 6800
American-Pinball.com
Facebook.com/americanpinball
Does this fix the weak flippers during multi ball?
#6444 5 months ago
The combo shots modes are really tough to do!
I would have liked to count other combos you succeed whatever the order. Maybe an EB to win or points for a number of combo or complete the level of secret mode you are playing.
#6445 5 months ago
Quoted from pinden007:
yes
#6446 5 months ago
Yes on mine as well
#6447 5 months ago
they are definitely hard to do if you try to flow them directly from one to the other; I can nail the first one from ramp-to-scoop very quickly. the others require some more stop-and-go handling
#6448 5 months ago
I succeed the first one quite easily...but the second is way harder for me. Never succeeded it yet! I think I get an issue with the right orbit. When I do this shot perfectly, the ball gets maximum speed and then at the end of the wireform guide (so left side) the ball path is like slightly deviated and goes SDTM. I really get the feeling that at the end of the wireform there is something wrong. However, my game is well leveled from side to side. I think I have 6,3-6,4° pitch
Otherwise the time between first and second shot is very very short. So no control on the left flipper and short ball time to succeed the second shot make this combo impossible to do right now for me.
I don’t know if you get this issue when the ball gets lot of speed in the right orbit?
#6449 5 months ago
I think that your pitch is a little steep.
I have lowered my pitch to 6.15 averaged from 3 locations, high, mid level and low just above the flippers.
This was after putting in the new power supply upgrade.
Along with this I have lowered the flipper power from 28L-27R to 25L-24R. I know a lot of guys have even lower flipper settings, but I wanted to add thrill and excitement. So having the flippers up at least 1 or 2 increments from defaults has accomplished this.
Lowering the pitch allowed me to lower the flipper power.
The game plays differently with the new power supply upgrade. It has tons more power yet it is more controlled.
With the flipper power lowered the left flipper can only make the ramp on a clean shot from a cradled position.
Rebound (on the fly) shots off of the left flipper have no problem making the ramp.
Higher flipper powers make the ramp easily even on a weak shot but, way less control in other areas and some air-balls.
However with lower flipper power, milkcan shots become repeatable and stage bounce outs are way less frequent.
#6450 5 months ago
I will try.
$ 27.50
The MOD Couple
Gweem's Mods
$ 9.00
Hdmike mods
Playfield - Plastics
Mod Magic!
$ 50.00
$ 47.00
The MOD Couple
5,900
Madison, WI
$ 6,995.00
Nitro Pinball Shop
$ 229.00
Tilttopper
6,050
Spruce Grove, ALBERTA
$ 129.95
$ 6,995.00
Little Shop Of Games
$ 129.95
Hookedonpinball.com
$ 6,995.00
Flip N Out Pinball
6,000 (Firm)
Fenton, MI
$ 119.95
Hookedonpinball.com
$ 6,995.00
Operation Pinball
6,995 (OBO)
St. Clair Shores, MI
$ 32.25
The MOD Couple
Flashinstinct
$ 6,995.00
Flip N Out Pinball
