(Topic ID: 183206)
American Pinball Houdini thread
By lllvjr
2 years ago
  • 9,980 posts
  • 572 Pinsiders participating
  • Latest reply 8 hours ago by pinballinreno
  • Topic is favorited by 150 Pinsiders
There have been 1,328 images uploaded to this topic. (View topic image gallery).
33 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 9980 posts in this topic. You are on page 123 of 200.
#6101 1 year ago
Quoted from Ericpinballfan:
Congrats to American Pinball again!
Isnt the big show in a few weeks Wayne?
That kinda looks like Barry hiding back there?
Magical for all the owners in Oz!
Well I am working the D Man to go over in December.
#6102 1 year ago
Quoted from Ballypinball:
Hope Not is Dec 1st and 2nd
But time flies, Its October soon so maybe a Fest will Head over
Well I am working the D Man for a December visit...
#6103 1 year ago
Magnet settings. Have they been removed?
#6104 1 year ago
How have you guys gone in installing the carbon fiber cliffy protector for the upper catapult? What is the best practice for the getting that sucker in its place? It seems a bit intimidating to install that one! Thanks for any info!
#6105 1 year ago
I had 6 H letters, and was going for the 7th, which would come from my third escape mode. I started the 3rd escape, but didnt successfully complete it. And I didnt get my 7th letter! Do the escapes only count toward a letter if successfully completed? I assumed not because the stage modes dont need to be successful to award a letter. Whine whine whine...
#6106 1 year ago
Quoted from PhantomO:
You have to complete the escapes for bonuses and letters.
As in life (or the way it used to be...), you get little or nothing for trying.
I just had an amazing game with over 800k in bonuses on one ball.
To celebrate this, I quickly bricked every shot thereafter, drained all extra balls on dumb mistakes and any self respect I thought I was getting.
#6107 1 year ago
Quoted from Nepi23:
I'm interested in this too. Ordered the Cliffy's but they haven't showed up yet. And looking at some pictures, I'm trying to figure out how a ball would damage some of those areas (like the lower and upper catapult). I'm probably wrong - but part of me says this more cosmetic than anything. No problem if I'm mistaken, just don't want to install if not needed. One thing I need to do is actually watch a ball when it's headed in those two areas and see how it lands.
#6108 1 year ago
Quoted from mbwalker:
Mike how thick is the felt dot? While I'm at it...what diameter?
Quoted from Rdoyle1978:
That looks perfect Mike - I couldn’t understand where you put the felt dot though, and got a little vertigo from your video! Haha . But it looks like you nailed that scoop issue
Sorry about the video. I should have mounted on the tripod I bought. I was just excited it worked.
I added a photo that shows where I added the felt dot. I moved the coil setting to 6 and just watched as the ball hit the right guide and bounced to the drain or left flipper. Your dot location could be different.
Now that I have played it many times, that dot has really solved the problem. Once in a while (like when two balls were in the scoop), the ball would come out slightly different and go to the middle or left, so I could just add another dot above and below if it ends up bothering me. Right now I will stick with one dot.
The dot is removable. The sticky stuff usually comes right off with the dot. However, if any residue is left on the guide, alcohol and a rag quickly get it cleaned up.
The felt dot is 1/2" diameter and about 1/16" thick. I buy them from Home Depot I believe.
#6109 1 year ago
Quoted from pinballinreno:
This leads me to believe something mechanical has changed or power is up due to the fall season.
Must be power. I played yesterday and after reset to 28 from 30, ball always goes in!
#6110 1 year ago
Quoted from mbelofsky:...I moved the coil setting to 6 and just watched as the ball hit the right guide and bounced to the drain or left flipper. Your dot location could be different...
Thanks! That makes a lot of sense...just see where the ball hits it and put the dot there. I got my VUK turned down right now to help prevent any damage until I put a Cliffy on it, it just barely kicks it out now and is very gentle. I think I even have some of those felt protectors from HD or Wallymart.
No need for apologies!
#6111 1 year ago
Ahh, thanks for clarifying. Wow, you must be getting a big bump from consecutive ramp and loop shots. Ever notice when you are TRYING to hit the seance letters, you magically make all the lanes and loops?
#6112 1 year ago
Aha! I’m glad you showed that - I thought you had added the dot IN the scoop somewhere
#6113 1 year ago
Just had an AWESOME game, got 6 letters and finally started a mini mode! I got great jail escape, which was really fun. I still can’t start the film mini mode, which is frustrating!!
Just as I was finishing the great escape, I must have Earned that last letter, and ... BLUE SCREEN. Game resets. Please fix this Rosh...
Actually I think I earned the letter and still played for another minute or two and then it reset ... GRRRRRRRR...
#6114 1 year ago
Quoted from CoPinfan:
I'm sorry, this is my first NIB game. How do we open a ticket for this? What information do we need to provide? Don't they already have a service bulletin to fix this? Also, does anyone know how we go about getting the speaker grill light blockers? Is that through API or the distributor?
If you dont see light coming through the perforated areas of the metal grill, then you dont need the foam. My game, #294, came with the foam already installed. If you have a later serial number, you probably have the foam too. Light coming thru at the far edges of the grill is normal.
#6115 1 year ago
Quoted from drummermike:
Maybe get a little plug in voltmeter to check the wall power if something changes dramatically.
#6116 1 year ago
Yes, EVERY TIME!
#6117 1 year ago
You can have quite long games. I made it to the Binge for the first time. What a great machine. Just wish the Wizard Mode would have some new, more thrilling music and a better lightshow.
#6118 1 year ago
Quoted from tatapolus:
#6119 1 year ago
It might. If the Master Magician mode is resetting on people, it's clearly still raw and unfinished.
#6120 1 year ago
Just got the notice from AP. New power supplies are available from them for people having issues with coil fade. $150 out of pocket, but they'll let existing customers have a $150 credit for their store to offset this:
September 26, 2018
Our goal at American Pinball is to provide quality games at affordable prices.
As many of you know, some Houdini owners are experiencing weak coils when the incoming AC voltage drops because of external loads placed on the service line. We have incorporated a new 48 Volt Power Supply to offset the effect of low incoming AC voltage on the coils.
We are selling the new Low Voltage Offset Power Supply for $150.00 which includes a switch mode 750-48 power supply, retrofit wire harness, hardware and shipping.
We greatly appreciate our customers and to show this, American Pinball will provide a $150.00 credit* with the purchase of the “Low Voltage Offset Power Supply” to be used either at our online store or towards the purchase of an Oktoberfest “Pinball On Tap” machine.
Purchase the power supply online at
https://store.american-pinball.com/products/houdini-power-supply-upgrade
Your Houdini machine needs to be registered prior to the power supply shipping, register your game at
https://www.american-pinball.com/support/register/
Regards,
American Pinball Inc.
Phone: 847 893 6800
American-Pinball.com
Facebook.com/americanpinball
#6121 1 year ago
Need a little help here guys - I installed the playfield protector and noticed that one connector is loose. Should I connect this to the left or right connector in the picture? I will attach two pictures, one is close-up and the other taken a bit further away, so you will know which board's connectors I am referring to. Thank you for any help!
#6122 1 year ago
Quoted from Nepi23:
UMMMM....RIGHT Connector
#6123 1 year ago
Quoted from BarryJ:
Thanks! Putting it there then
#6124 1 year ago
Quoted from vireland:
September 26, 2018
Regards,
Phone: 847 893 6800
I didn't get that email. But Thank You for posting.
Also trying to figure out if I'm registered. Should be.
#6125 1 year ago
AP... will these new power supplies be in the future games?
I've been on the fence with this purchase, primarily because of the power issues discussed.
Kerry
#6126 1 year ago
Quoted from Nepi23:
It goes on the outside connector closest to the board edge.
#6127 1 year ago
Quoted from Kerry_Richard:
Kerry
Pretty sure that will be the case.
#6128 1 year ago
September 26, 2018
Regards,
Phone: 847 893 6800
That is an outstanding offer. This is definitely in the “they didn’t have to do that” department. $150 isn’t bad either for all the work that goes into it, the harness, shipping, etc. AND BY THE WAY ROLL $150 INTO SOME MAGIC GLASS! (at least that’s what I’ll be doing)
#6129 1 year ago
Haha! Exactly the thought I had...Magic Glass credit!
#6130 1 year ago
Hoping for the Knocker kit soon too!!
#6131 1 year ago
Kerry
Oktoberfest will have a brand new redesigned power supply!
#6132 1 year ago
Quoted from BarryJ:
What about knockers? Seems like an excellent opportunity for synergy...
Oktoberfest...Two Knockers in every one!
#6133 1 year ago
September 26, 2018
Regards,
Phone: 847 893 6800
This is fantastic news, will be ordering mine tonight!
#6134 1 year ago
September 26, 2018
Regards,
Phone: 847 893 6800
Thanks vireland I'll be interested to see if this resolve the intermittent flipper weakness in Seance Multiballs. If it does I can use the $150 towards a shaker or/and knocker kit.
#6136 1 year ago
Quoted from Nirm:
https://store.american- :PS)pinball.com/products/houdini-knocker-kit
ericpinballfan Just for you!
-Nirm
Thank you Boss!
#6137 1 year ago
LOL
#6138 1 year ago
BarryJ,
The power supply upgrade: Will this also address the lower catapult inconsistencies related to line voltage?
#6139 1 year ago
I already posted this, but I will say it again. The glass is really amazing...I literally reached down thinking a show unit didn't have the glass installed. Whoops...there's glass there?! No kidding, I thought I was going to touch the PF - it's that good.
#6140 1 year ago
Ugh, I just had five trunk catapult misses in a row (left side). My bracket pivot didnt fully solve this issue. No clue what this is now.
#6141 1 year ago
BarryJ,
Yes I need to know this too. I never have flipper issues. Just a wandering catapult shot, and a falling short shot also.
#6142 1 year ago
Quoted from bobukcat:
Wouldnt the shaker and knocker put more strain on the power? Will the upgrade compensate for that?
#6143 1 year ago
Just upped my flipper coils by 1 from the stock (so I think they are at 23 now?). VERY different shooting game now, wow. The ball felt like it was rocketing all over the place! Definitely makes it more fun but I’d be concerned about breaking stuff in there!
Also confirmed that IMO the standard settings are far too hard for most players. You can have 20+ minute games and never hit one of the special miniwiz modes, which IMO seems long
#6144 1 year ago
I think the standard settings are too hard as well. I do appreciate that API has provided outstanding configurability in the settings. Mine are set with long ball save times and 1 hit to get into the theater. The defaults seem tough for casual players - especially if you are bricking shots.
#6145 1 year ago
I'm having the EXACT same issue - love to hear if anyone solves this.
My mech is perfectly centered but still having issues even running a dedicated Variac
Truly deflating cause I love this machine and am usually capable of fixing just about anything PB related ... this thing is a mystery
#6146 1 year ago
I went to 23 as well, and it was an improvement.But I notice a lot of dimples on the playfield now...
#6147 1 year ago
Quoted from MT45:
It's like there's a ghost in the machine...
#6148 1 year ago
Good move ditching that transformer supply.
#6149 1 year ago
I don’t feel like th game is any easier but WOW the flippers have some serious power now! I had originally dialed them back because it made it easier to hit some of the shots (inner loop) but I was having a little trouble with the ramp. Now I can hit the ramp fine and I can still backhand the inner loop.
I am thinking about going to regular red rubbers on the flipper though, we’ll see how that changes the game as well. Have not dropped the flipper bats yet.
#6150 1 year ago
Shaker maybe, knocker not really unless they use it in ways we've never seen before. I wouldn't expect it to be firing when I'm in a multiball except maybe one time if I hit a replay. I haven't played a Houdini with the shaker in it so I don't know what triggers it. Since the offer is so good (it's like getting the power supply free if you buy the shaker and knocker kit) I'm going to order all three and see if it makes a difference for me. I don't have the fluctuating line voltage like some others do and my lower catapult accuracy is 98%. The upper one shows it's only at like 75% but I have NEVER seen it miss so I don't know what's causing that number to be so low.
5,500
Sale Pending!
Lehigh Valley, PA
$ 399.95
Pin Stadium Pinball LEDs
5,500
Baltimore, MD
