You guys inspired me to order a second machine and start taking mine apart. I got a little further and managed to get the playfield out and the glass off of the playfield. It wasn't too bad. Once you have the plastic casing off of the bottom of the playfield, there are plastic snap tabs that hold the clear 'glass' piece down. You can just pop it out using a screwdriver and then remove it from the top side. I went and partially re-assembled the machine with the glass still off to test and tweak. It seems the glass can just be snapped back in at any time, even with the machine back together.
I did correct the issue I had with the scoop kickout requiring a hard slap to the flipper button. There is plastic actuator rod that goes to the scoop from the flipper button. I stuck a small foam piece to the rod where the ball rests. Now it kicks it right out with any left flipper press.
20191230_172734 (resized).jpg20191230_172929 (resized).jpg20191230_173412 (resized).jpg20191230_183930 (resized).jpg
