Hi Hole
welcome back - holidays are over - back to the problems ...
I would like to have a "sum-up / where are we NOW" kind of "We start again by having a description of actual problems":
"Jumper-Wire(s)":
I refer to the two JPG's in post-33. You have JY clipped-on at JY-6. You have JF clipped-on at JF2. Does the snippet I show here "shows Your Jumpering ? If NOT: Please write.
OK, the snippet shows:
"P-GO Problem is in the Switch on Game-Over-Relay", "P-TT Problem is in the Switch on Tilt-Relay", "P-CW Problem is in the connecting Wire (in between).
We might have ONLY ONE problem or we might have TWO problems or we might have THREE problems.
For P-GO we have 3 blades on a Make-and-Brake-Switch. For P-TT we have 3 blades on a Make-and-Brake-Switch.
Game-Over-Relay has MANY switches - have You clipped-on the JY-Jumper-wire on the "right / interesting, correct" blade (?) - the middle blade having soldered-on a wire "Color-76-1-Orange-Brown. (Another blade of that switch has wire-color-58-White-Black, the third blade might have a blank (no insulation) wire - might have a wire with plastic insulation. That third wire must run to the Make-and-Brake-switch on TILT-RELAY -> THERE that wire is soldered-on onto the middle Blade.
Tilt-Relas has MANY switches (?) - have You clipped-on the JF-Jumper-wire on the "right / interesting, correct" blade (?) - an OUTER-BLADE - wire-color-10-RED ? This switch has the middle blade (I wrote about) and another outer-blade-wire-color-85-Black-White.
Do the test again -> unplug the pin and take away JF-Jumper and clip it onto "JF3" -> plug-in and start a game -> WHAT happens ? please report.
(((If the pin shows "other / new / faulty" reaction: The FAULT MUST be "in the Switch on Tilt-Relay")))
Greetings Rolf
