(Topic ID: 273336)
Alternative to isopropyl alcohol?
By JohnBillerman
  • 17 posts
  • 15 Pinsiders participating
  • Latest reply 3 years ago by yancy
    #1 3 years ago
    What is a good alternative to isopropyl alcohol for cleaning steppers, switches and the like? I can't find any in stores yet since it's all, apparently, being used for hand sanitizer
    #2 3 years ago
    Try your dollar store. Ours had full shelf this week
    #3 3 years ago
    100 proof vodka , the good stuff . Not the cheap brands .
    #4 3 years ago
    At a ratio of 5 to 1 . 5 oz for you , 1 oz for the machine
    #5 3 years ago
    Probably naphtha. Just ventilate the working area and don't smoke/burn anything near it.
    I thought all our Walgreens here in Chicago would have iso again by now as we've had real hand sanitizer readily available for a good two months.
    #6 3 years ago
    I use lighter fluid (or Naptha). It gets the grease/gunk off quickly. Just be careful, it's flammable.
    #7 3 years ago
    Naptha, or lighter fluid, or acetone.
    #8 3 years ago
    Alcohol is good for cleaning grit, grime, soot, etc. but struggles with grease and other lubricants because it doesn't really dissolve them. Petroleum based solvents are much better at dissolving and cleaning away grease. I like mineral spirits for cleaning greasy things because it's less volatile and has a longer working time so you end up breathing in less. It's also not as hazardous or flammable as some of the others.
    /Mark
    #9 3 years ago
    I'd second Mark's suggestion of mineral spirits - I've used it several times recently on gunked-up steppers, and it gets rid of the old dirty grease quickly.
    #10 3 years ago
    Everclear if you can get the 190 proof.
    #11 3 years ago
    If you have an Ace Hardware near you, check their paint department. Ours got the 99% isopropyl back in stock a week or so ago.
    #12 3 years ago
    Struck out at Dollar General and Ace Hardware, but lo and behold our local Sam's had it in stock finally!
    #13 3 years ago
    The guy at the hardware store recommended “denatured alcohol” for cleaning a Playfield. I thought it made sense since I thought I remembered someone saying that other products had diamatecious earth which gets rubbed into the cracks. I figured “denatured” probably meant it did not have any of the “earth” in it. Not sure if that matters though for cleaning the electronics.
    #14 3 years ago
    Quoted from tyking:
    Denature alcohol is ethanol that has additives so it can't be ingested. Many poisonous solvents can be added but usually methanol. I wouldn't use this on a playfield (or at all). The vapors from methanol are extremely dangerous and also can be readily absorbed through the skin.
    #15 3 years ago
    Just use hand sanitizer!
    #16 3 years ago
    Quoted from radium:
    You know, our company has actually been selling 80% alcohol sanitizer, think we have like 1000 gallons still. I'm going to try it on my next project!
    #17 3 years ago
    Quoted from timtim:
    Or if the liquor store is sold out of Everclear (mine was in the early pandemic days) look for Spirytus Rektyfikowany, aka Polish rectified spirits, which I've seen in both 190 and 192 proof (95 or 96 percent ethanol).
    This page was printed from https://pinside.com/pinball/forum/topic/alternative-to-isopropyl-alcohol and we tried optimising it for printing. Some page elements may have been deliberately hidden.
