(Topic ID: 180047)
Alternate tool to re-pin system 1 connectors?
By kobayashimaru
7 years ago
  • 16 posts
  • 14 Pinsiders participating
  • Latest reply 7 years ago by NicToria
#1 7 years ago
Greetings!
I'm currently working on getting a Charlie's Angels up and running. I was in the process of rebuilding the MPU to driver board harness and I snapped the tip off of the Molex pin extractor tool trying to remove a stuck contact. Has anyone here used something else successfully to do the job? I'd rather not have to pay another $15 and wait three days to get going again.
Joe
#2 7 years ago
I've seen a couple folks grind down some spring steel.
#3 7 years ago
Hammer down a paperclip to get it thinner. Grind the sides if it's too wide.
#4 7 years ago
I've used a jewelers screw driver in a pinch. I think I may have gotten it out of a watch repair kit from Harbor Freight.
#5 7 years ago
Jewelers screwdrivers work perfectly. I prefer them over the Molex extraction tool to be honest. Those can be pesky connectors to remove.
#6 7 years ago
I ground down an allen wrench to work. Problem is you have to be careful about not putting the tool in too far or you can damage the housing clip.
#8 7 years ago
Quoted from kobayashimaru:
Greetings!
Joe
Same thing happened to me. I thought since the tool is now "junk", why not try to regrind it back to same point/shape? A few minutes on the grinder and I had a shorter tool that still worked. Actually, it has lasted longer in its current form then it did from the factory
#9 7 years ago
Wow! Everyone has these laying around. I cut an old leaf switch down with a pair of metal cutters and file the edges. Takes a couple minutes to make.
#10 7 years ago
What I can't figure out is why Molex thinks these things are worth that much. These should be a couple bucks - tops.
Tried to get some custom made by a local tool and die shop. I thought a generic handle with replaceable tips would be a great idea. They promptly spaced me off...
#11 7 years ago
Thanks for the input everyone! I ended up going to Harbor Freight and found an electrical probe kit, which basically look like dental tools. There are 5 different types in the package, 3 of which fit in the housing to disengage the retainer. Considering the kit was $3.49 and considering the questionable quality of HF tools, I bought several sets, considering I have at least 100 more contacts to replace. I also ended up splurging on completely new MPU to driver board and power supply to MPU harnesses. Hopefully this will go a bit faster now.
Thanks again for your help!
Joe
#12 7 years ago
I second Ed, Molex way overcharges for this tool.
#13 7 years ago
I make pics out of windshield wiper blade inserts. The metal piece that is in the wiper blade. A piece of round wood dowell. Still hole, insert metal in there. Gorilla glue and you can grind it into any shape you need to pick.
#14 7 years ago
Still is drill.
#15 7 years ago
That molex pin extractor tool is a flimsy piece of crap that doesn't even work very well because it's so flimsy. Hated it. I went to Menards and bought the smallest regular screw driver they had. It's a billion times more sturdy and works great!
#16 7 years ago
We are doing the same thing... Is there a great crimp tool to re-pin the Edge Connectors.. ?? THX> For all the responses so far on getting the pins out ..
$ 89.00
That Old Pinball
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/alternate-tool-to-re-pin-system-1-connectors and we tried optimising it for printing. Some page elements may have been deliberately hidden.
