I have been working on this Improved Sportsman on and off for a few months. It would be for HUO as it is a payout machine. It payouts free play tokens at this time that are separated by the coin mech for the tokens to fall into the payout tube while nickels go into the coin box. The tokens are magnetic and are attracted by the coin mech magnet to go into the payout tube.
I have the machine working but it suffers from contact problems on the playfield. The payout mech and coils are working along with the playfield coil release. The playfield contacts remain unreliable.
If anyone has hints about improving playfield switch reliability it would appreciate the advice.
The tilt uses a silver plated brass ball -- non-magnetic and sliver for making a good electrical contact when tilted. Some players would likely be tempted to use a magnet to hold the tilt ball in place if it was a magnetic ball.
It uses marbles currently, but perhaps heavier steel balls would work better. However, the shooter spring will likely have to be made stronger for steel balls.
Note that the bottom of the legs are not painted silver, but are polished aluminum cuffs. One leg is original to the machine, while the three others from a standard Sportsman have the polished aluminum cuffs added.
P1000587 (resized).JPGP1000588 (resized).JPGP1000589 (resized).JPGP1000590 (resized).JPG
