(Topic ID: 190156)
Allied Leisure Star Shooter
By Muttertag
2 years ago
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 2 years ago by Muttertag
#1 2 years ago
When starting the game the ball doesn't kick out from the out hole. I went threw the tests and all seems to be working OK. There isn't any stuck switches or coils firing. The kicker for the out hole fires during testing no problem. Just doesn't kick ball out to start the game? EVERYTHING during testing is OK. What am I missing?
Thanks for any help with this.
#2 2 years ago
Test the switch in the trough with a multimeter. I had a similar problem with the Allied Leisure Hearts and Spades I used to own.
#3 2 years ago
What did you do to fix this issue?
#4 2 years ago
Quoted from Muttertag:
I tested the switch with a multimeter. When it was determined using said multimeter that the switch was inoperable, I replaced the switch.
Did you test the switch with a multimeter? Does that switch work? If yes... move on to other possibilities. If no, replace switch.
#5 2 years ago
Hey, Thank you for your help. The switches were fine. What I found is the main board wasn't seated fully. I lifted it out and plugged it snug and everything is OK.
$ 279.95
$ 279.95
$ 279.95
$ 399.95
$ 279.95
$ 159.99
$ 69.99
$ 18,500.00
www.retroarcade.se
$ 69.99
Great American Pinball
$ 49.00
Pinball Photos
