(Topic ID: 271272)
All high power coils not firing
By Daximus
2 years ago
  • 11 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by PinMonk
#1 2 years ago
Just picked up a Goldeneye yesterday as a project (got it for $1000). In pretty good shape overall with a lot of things functional. One of the main things that it has an issue with is that it appears all the high power coils aren't firing. I'm fairly new to all this and have only worked on my Stargate in the past, but excited to dig into this! I just got it yesterday afternoon so just starting to troubleshoot and hoping that you guys can point me in the right direction. When I initially ran the diagnostics coils 1, 2, 4, 8, 9, 10, 11, 12, 13 and 14 weren't firing. All of which appear to be on the high power circuit (50v). No fuses are blown and everything else appears to function normally. No corrosion on initial inspection. Made sure the coin door was closed and nothing looked out of the ordinary on that switch. In a quick multimeter test I wasn't getting any voltage at the coils but the 50v board led is lit. I did find some random wires in the bottom of the cabinet that correspond to the high power circuit but no idea what they go to. The brown/blue wire had electrical tape loosely at the end and the yellow/violet was just laying there. There were a couple other terminated connections that are loose as well. Anyway, any and all assistance is greatly appreciated!
IMG_0739 (resized).jpgIMG_0739 (resized).jpgIMG_0732 (resized).jpgIMG_0732 (resized).jpgIMG_0734 (resized).jpgIMG_0734 (resized).jpgIMG_0741 (resized).jpgIMG_0741 (resized).jpg
#2 2 years ago
I can speak to the question you have about the yellow/violet wire. It was removed as part of Service Bulletin 84 to prevent overloading of the 50v fuses.
http://arcarc.xmission.com/Pinball/Stern%20Service%20Bulletins/sb/sb84.pdf
#3 2 years ago
Quoted from Lithium:
Thanks! That helps...I’ll verify the mag board is updated. Though the yellow/violet wire I found was running along the bottom of the cabinet right next to the sub...
#4 2 years ago
Can you post a high-res picture of the battery holder and area around it?
Take the f21 fuse out of the holder and check it for continuity outside the holder.
How about at the connector on the board? Is there 50v at the board connector the coils plug into?
#5 2 years ago
Quoted from Daximus:
Yup, that's where mine is as well. I have a hunch if the machine was built in the factory around March they performed the bulletin in-house before shipping it.
#6 2 years ago
So I know you said it looks fine but I’d look really hard at the interconnect switch on the coin door. If that’s not working properly the game should cut all high voltage power like your describing. On some games it even gives you a warning that high power is disabled when you open the door. Do you get a message when opening door or does it say nothing?
#7 2 years ago
Quoted from Jmckune:
If the 50v led is lit on the board, then the interconnect works, right? He said it was on...
#8 2 years ago
Sorry this is the best I have at the moment showing the battery compartment. Will take s better one as soon as I can.
Yes I get the power warning message when opening the coin door.
If I recall there are two high voltage connectors towards the bottom of the board. Pulled and reseated them but that’s the extent of it.
Will pull the fuse and check continuity on Sunday (shooting a wedding tomorrow so I’m out).
CADDBDA6-4A8A-4FE8-83EC-206C9746A253 (resized).jpegCADDBDA6-4A8A-4FE8-83EC-206C9746A253 (resized).jpeg
#9 2 years ago
With the coin door closed, check for 50v on the actual pins of the connectors to make sure it's not somewhere in the wiring after that.
#10 2 years ago
DING DING DING...we have a winner! Fuse 21 looked good but failed the continuity test! Swapped it with another 3A fuse and ta-da...working coils! Feel dumb that it was something so stupid! Thank you so very much!!!
17542F59-608C-42D4-B741-8A216E05F53F (resized).jpeg17542F59-608C-42D4-B741-8A216E05F53F (resized).jpeg
#11 2 years ago
Yeah, it's a really common issue, which is why I try to remember to ask people to take the fuses involved out and test them outside the holder.
Glad it's fixed and you're back in business!
$ 33.00
Nordic Pinball Supply
Decals
$ 76.00
Lighting - Backbox
Arcade Upkeep
Backbox
$ 17.50
Other
PinSound
$ 24.00
Pinhead mods
Protection
This page was printed from https://pinside.com/pinball/forum/topic/all-high-power-coils-not-firing and we tried optimising it for printing. Some page elements may have been deliberately hidden.
