Just putting this out there because I'd never had all the GI die at the same time on a modern Stern with LED lighting and wanted to put the solution here in case someone else runs across this to save them time.
The Metallica Premium I maintain on route lost all GI. It wasn't a fuse, but seemed to be oxidation on the power connector under the playfield where the LED control board in the middle of the PF underside is, or a loose connection. Removing and re-inserting the 2-wire red/black power cable next to the RJ-11 connector (phone-looking cable) on that under playfield board brought back the GI.
EDIT: This happened again, and removing and re-installing the 2-wire red/black power cable by itself brought the GI back again, so that's most-likely the only point of failure here.
