(Topic ID: 236954)
Alien Poker delayed response
By CUJO
4 months ago
  • 12 posts
  • 5 Pinsiders participating
  • Latest reply 3 months ago by CUJO
#1 4 months ago
Read somewhere that resistors should be pulled off the cpu/driver board and jumper wires put in place to speed up response, esp when trying to use right flipper button to roll rollover lanes?
I have put up with this slowness long enough and remembered seeing something somewhere on this problem?
If someone would be so kind to post a link if they know what I am talking about...
Thank you...
#3 4 months ago
You will also see ToddTuckey in his youtube videos showing you that he does this update to all his machines and that a staple from a regular old paper stapler is a perfect fit.
-Mike
#4 4 months ago
Quoted from Grizlyrig:
-Mike
Exactly what I was looking for.
Thanks Mike.
#6 4 months ago
Read through that other thread. What exactly is the benefit? Faster response from the switches? Anything else?
#7 4 months ago
@ryanwanger - nothing else beyond faster switch responses that I have kind of noticed and ability to use in a system 7 machine.
-Mike
#8 4 months ago
The problem I am having is slow switch responses. If a ball rolls thru one of the top 4 rollovers too fast, it won't register. If it's slower it does. This is the first Williams game that used the right flipper button to roll the top 4 lanes. It will roll much faster if the game is not registering other actions.
The right flipper works as it should when flipper button pressed so not a flipper switch contact issue.
Drop target will always drop when hit of course but if I hit a lit JOKER standup, it's hit or miss. Doesn't always register.
Pin switches are so unresponsive now for some reason.
Am I having a different issue than the one I'm trying to remedy?
#9 4 months ago
Quoted from ryanwanger:
I think what happens is with the series resistors in place you can get situations where say a set of drop targets are all closed in one strobe which pulls down the voltage. Then the return may not be seen reliably.
The black knight manual has a little blurb in it about the resistors (after BK at some point all the resistors in strobes and returns went to zero ohm). Info is probably on pinwiki too. Basically change the series resistors in the switch drives and returns to zero ohm. Top right corner of driver board near the switch plugs.
#10 4 months ago
My boards have the "newer" zero ohm resistor on them (brown with the single black stripe in the middle).
So does this mean if I remove these resistors and replace with staples or jumper wires nothing will change response wise on my game with the switch
detection speed?
#11 4 months ago
Quoted from CUJO:
detection speed?
correct. They are already jumpers, not really resistors.
Check to see that your switches aren't installed with one of the switch blades reversed. Almost all solid state Williams pins up to system 9 had the leaf switches assembled backwards with one gold contact facing the correct direction and the other one with gold contact facing outwards and the non plated rivet facing the other gold contact instead. Makes for a crummy connection. Flip the switch stacks (super PITA!!) or buy new switches. Might be easier to replace with micro switches.
1 month later
#12 3 months ago
Quoted from kbliznick:
Thanks. Will check that now. You have me curious!
$ 72.95
$ 79.95
$ 22.00
Siegecraft Electronics
$ 279.95
$ 14.00
Yorktown Parts and Equip
$ 17.00
1,975 (OBO)
Thousand Oaks, CA
$ 12.99
Medisinyl Mods
$ 90.00
Lighting - Under Cabinet
