Alien pinball - Poor quality clear coat!
(Topic ID: 206661)
By libtech
1 year ago
  • 48 posts
  • 28 Pinsiders participating
  • Latest reply 1 year ago by jonesjb
  • Alien Heighway Pinball, 2017
There have been 6 images uploaded to this topic. (View topic image gallery).
#1 1 year ago
Not sure who is producing the playfields for Heighway, however recently I just had a major issue with my Alien. A small piece was chipping around the magnet, which wasnt a huge deal, it happens, so I ordered a cliffy ring to cover and prevent more damage. Upon removing the mylar around the magnet to install the cliffy, to my surprise more than just the mylar came up, a 2 to 3 square inch section of the clear peeled right off! Came off super easy like peeling sunburnt skin.. Obviously the clear has very poor adhesion, not sure if I'm just 'lucky' or if it is common on all playfields produced. Just wanted to warn guys not to apply or remove any mylar on these!
Happily the art is intact, now I'll have the treat of having to get it re-cleared
#2 1 year ago
I wonder what causes this? Is this a case of it not being fully dry?
#3 1 year ago
I was under the impression that Heighway playfields all come via Mirco?
#4 1 year ago
just write to highway, they will replace your pf like stern
#5 1 year ago
Quoted from Whysnow:
I heard Mirco was producing them as well. They make very nice playfields overall but some of the JJP games have had similar issues and many have art missing around magnets, saucers, or scoops.
Spooky seems to be the only ones really getting playfields right at the moment. No one will be perfect though.
#6 1 year ago
That really sucks, was the mylar around the magnet from the factory or did you apply it yourself?
#7 1 year ago
did you wax before putting the mylar down. I do that normally which makes removal much easier
#8 1 year ago
Well, shit. One more thing to add to the QC issue list.
#9 1 year ago
Quoted from nman:
Slow down. This is the first instance of this happening AFAIK. Not a huge deal and this happens from time to time with all manufacturers as was stated earlier.
And yes, the playfields are made by Mirco, no one better IMO.
This really isn't a Heighway issue, that would be impossible to catch before sending out.
#10 1 year ago
Good to hear. With all the apparent funding issues they've had, i was a bit concerned maybe they had changed to a different playfield manufacturer to save some cash. Guess I'm just getting progressively more paranoid the closer we get to mass LE shipments
#11 1 year ago
Quoted from bobukcat:
Only piece of factory mylar lol
#12 1 year ago
Quoted from jonesjb:
My guess would be something to do with surface prep before clearing
Quoted from DEN:
So far no response to emails...
#13 1 year ago
Bummer man. I'd be pretty upset.
#14 1 year ago
Quoted from pinlink:
I wouldnt say this isnt a big deal, for my game it is. However, your right its not Heighways fault, if mirco made them, then it would be a mirco issue.
Also since they make playfields in batches, there are probably others just they havent found out yet.
However it is still Heighways responsibility, so we'll see if I hear anything back.
#15 1 year ago
Removing mylar is something that you need to be really careful with. Did you freeze it? Use goo gone?
#16 1 year ago
Quoted from kermit24:
Yes, supposedly you need to freeze it.
#17 1 year ago
Yes did, still came right up. I was being very slow and careful, it looked like glue residue was there at first, but after wiping it off you could tell.
The only positive thing I can say, is because the adheasion was so bad the art didnt get ruined.
#18 1 year ago
Just to understand this 100%
The problem first came when you removed the mylar?
#19 1 year ago
Quoted from tezting:
No, if you look at the first post, there was a little bit of chipping at the mag, in a different spot unrelated to the peeling.
Looking at it before, you couldnt tell anything was wrong, but reguardless clear should not simply lift off like this.
#20 1 year ago
That stinks. I thought the clear on my Alien looked a little better than the couple CPRs I've had hands on. (Taxi and fish tales)
#21 1 year ago
#22 1 year ago
Quoted from libtech:
I understand and of course the clear should not lift. Just wanted to know.
#23 1 year ago
Yikes. That's painful to look at. Seems as though it would just flake right off.
#24 1 year ago
Mylar should come up VERY easy on a new game, and if it's lifting art, that's bonkers. That are should be sealed under the clearcoat, so if art lifted, you're pulling up however many layers of clearcoat AND art at the same time. If the clearcoat is that flaky, I'd be worried about the long-term viability of the playfield.
#25 1 year ago
I very well hope for Heighway that these are isolated incidents. If not, this could be the beginning of the end.
#26 1 year ago
At least you got a game. It's been 3 years and still no game. lol
#27 1 year ago
That makes me a sad panda
#28 1 year ago
That sucks too...
#29 1 year ago
Vivid - How many plays do you have on that? I'm curious about some of the games that have been to shows or have possibly many more plays...how they are holding up? There really should be some protection on scoops anyway, but typically you would get some clear chipping or dented wood that slowly grows making the hole more round than square. This appears to be a case of the art just flaking off in chunks early on. Not good.
#30 1 year ago
Quoted from bigdaddy07:
The airlock scoop is not built properly in the production game, they know about it and in future games at some point it will be changed and a cliffy will be sent from factory. It caused this in 10 games once the ball began shooting out improperly due to the welded mech being too loose and not hugging the ball enough to continue to make the ball follow the scoop curve. It shoots up and hits the metal curve and comes back down and slams the pf. It began to do this after about 50 games of it working normally.
#31 1 year ago
Quoted from VividPsychosis:
Even so the clearcoat sldnt do what its doing.....
#32 1 year ago
Quoted from bigd1979:
I agree. Hopefully they get future playfields fixed and this will just be the first run that has this issue. The cliffy will no doubt help the scoop but I worry about other areas over the long term. I do recall early WOZ playfields having similar problems. They obviously corrected it.
#33 1 year ago
#34 1 year ago
#35 1 year ago
Anybody else having PF issues?
#36 1 year ago
Quoted from PACMAN:
Both of my games here have issues at the magnet.
One has the art lifting under the factory mylar.
The other has no factory mylar and a chip missing around the magnet.
#37 1 year ago
A few months of ownership and no scoop issues however it's imperative to get cliffy otherwise it will chip.
#38 1 year ago
Looks like that ramp sharted itself.
#39 1 year ago
Quoted from nephasth:
haha - yeah the ramps have done that after use.
#40 1 year ago
Quoted from PACMAN:
So far so good. I have Cliffys on the scoop and magnet.
#41 1 year ago
Quoted from delt31:
Maybe just take the ramps off and remove whatever that coating is and get them totally black?
#42 1 year ago
Quoted from PoMC:
I don't like the black look as much (pref the look of it now). Unless I put my nose into the ramps, I don't even notice. I'm very happy with the entire package.
#43 1 year ago
It sounds like you were pulling up the Mylar and some cc came off the playfield.
I don't think any manufacturer would recommend us taking the factory Mylar off.
Is that what happened or am I missing something. Did the Mylar come off somehow and than you removed the mylar?
I'm confused.
#44 1 year ago
Quoted from kklank:
I'm confused.
Mylar sld not pull up a proper clearcoat......
#45 1 year ago
I never had Mylar on my machine from factory
#46 1 year ago
Quoted from kklank:
I'm confused.
There is no factory Mylar.
#47 1 year ago
I have seen factory mylar pull up clear and art on all era of games if not properly applied and/or frozen off with freeze spray.
1 month later
#48 1 year ago
Any updates on this?
$ 45.00
16,050 (Firm)
Nidderau, HE
11,500 (OBO)
Cincinnati, OH
Gweem's Mods
$ 750.00
St Louis, MO
Pinball Photos
