Quoted from flynnibus:Probably more like 'use same parts everywhere' - and hadn't really considered these parts high failure. This is where their inexperience haunted them prior, and looks like some problems persist. Good news is, it's at least a stand-alone component that maybe could be retrofitted in the future.
Why couldn't "use same parts everywhere" be more suitable leaf blade type setup on the lit standups? . 9 in total now they have. . Robust, tried, and true. Some of the targets they have now lit take More of a pounding than the Xeno targets! . That green one to the left of the right ramp sure takes a solid pounding!
These tiny SMD buttons are for the front of your friken DVR or the old telly. Not meant for a heavy steel ball to pound on at velocity, repeatedly. Some of those been lucky to make a couple of hundred games. I'd even speculate this turns into a bit of a warranty/recall issue for Pb. The leaf setup may cost slightly more, but at least they will work for a reasonable time. False economy. I guess they only need them to work until warranty runs out.
They could have very efficiently just added leaf switches to the regular slingshot RGB PCB post, stack in front and connect to it's header, done. All the same around the board, works better, more reliable, more durable, cost effective. Happy customer.
Sure smells a bit like the pantyhose principle to me.
I have a collection here in a box with blown out switches from getting smashed. I'll be trying some things out with those. The RGB's were all still working fine. The lit standups switch choice, by heighway and Pb, would have to be one of the stand out worst things about these games. S#itty fu@#en switches?!?!. :3
