(Topic ID: 106728)
ALIEN PINBALL - Game Over, Man, Game Over
By HeighwayPinball
5 years ago
  • 27,348 posts
  • 1,040 Pinsiders participating
  • Latest reply 5 minutes ago by Oneangrymo
  • Topic is favorited by 277 Pinsiders
  • Alien Heighway Pinball, 2017
There have been 3,475 images uploaded to this topic. (View topic image gallery).
53 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 27348 posts in this topic. You are on page 509 of 547.
#25401 10 months ago
Quoted from megaladon:
So I listed my alien f/s trade and I was checking everything and bam shit happens. I had a little red feedback in the back box display so I took s look and lightly with pressure the feedback went away. Then it cracked on the edge killing 10% of the image. I either take a bath on the game and sell it or find a replacement. Anyone know if it has to be the same M270HV02.1 screen impossible to find? Please help.
Correct part # is M270HVN02.1 - you can probably confirm this on yours, it's labeled somewhere on the back. Be very careful with the LVDS cable and connector inside that backbox monitor housing when you remove the panel. It's delicate, and there's a special way it removes from the connector. (Google it)
There's several panels on eBay, they're available for around $200-$300.
http://www.apollodisplays.com/m270hvn02-1/
Also, the red in the display is probably loose LVDS cable or the cable going into the monitor board from the computer, and not as likely the display itself. You shouldn't push on LCD displays, but I guess you found that out.
#25402 10 months ago
Quoted from mavantix:
LOL. Thanks, yea figured that one out in slow motion...nooooooooo!
#25403 10 months ago
I connected the playfield lights here, the white cable...
#25404 10 months ago
Then connect the 4 lights... that’s all..
0D8C1541-ADDE-4914-B411-2950A3146BA8 (resized).jpeg3BA0BB41-ADC0-48FF-B103-320F86D2D7F5 (resized).jpegED2D1BB3-8C94-4C66-A34A-A91F33BE18C3 (resized).jpegF68847A6-1C0B-441D-ADAE-1401F3F75F3D (resized).jpeg
#25405 10 months ago
That's easy, but I have doubts at the position of the beacon left next to the ramp and on the right in opposite to the upper flipper finger.
One airball could destroy the beacons, so we have to consider about another place or a protection in that area?
If I install the beacons, I will decouple the bases additionally with rubber washers.
I remember some issues with the opto electronics of the ball trough, that later was solved due to use rubber grommets between assy and circuit boards.
#25406 10 months ago
Quoted from Averell:
You need a Cliffy all around
#25407 10 months ago
That's it!
#25408 10 months ago
I think I am only going to do the lower 2. Besides at 82 shipped for the pair these are not exactly cheap for a pair of lights. Don't wanna put them somewhere your average ball will hit.
#25409 10 months ago
How often during gameplay do the beacons on top of the cabinet turn on?! As amazing as those mini beacons are.. if they spun the whole time it would be too much.
#25410 10 months ago
loader battle, queens nest, self destruct (I think?) and in attract mode for a brief period. Get the belt driven ones otherwise they are loud.
It is not overwhelming and totally is worth it.
#25411 10 months ago
I don’t own Alien, although I’d love to one day. The beacon light mod on the playfield looks awesome!
The beacons originally mentioned look so good, but on the very high end side of price.
I was looking around and found these, no info on size but they look small and say they are for RC cars.
Thought they might be worth looking into, simply cause they are cheap.
https://www.walmart.com/ip/Gotoamei-RC-Car-LED-Rotating-Beacon-Light-Flashing-For-Trucks-Crawlers-Model-Toy-Accs-New/118090254?selected=true
#25412 10 months ago
It's just a matter of quality.
The beacons we use are high-end German handmade parts and proofed for long life in heavy terrain for off-road model trucks and stuff like that.
I'm not sure if these "Chinese" thing will work properly?
#25413 10 months ago
Handmade lights that are .5 inches tall. Impressive!
#25414 10 months ago
I was intrigued by the beacon lights from Walmart, but after a little checking, looks like they are 6V, If I'm not mistaken they need to be wired into the 12V circuit to go off at the same time as the head beacons. So unless there is a way to wire them into the lower voltage light circuit I don't think they are going to work, and as cool as they look, I don't think you would want them going all the time.
#25415 10 months ago
Quoted from dgpinball:
A resisitor and we are on 6 volts ??
I saw the expensive german ones in natura ! Awesome work !! Yes, high priced but looking like real surroundlights !
#25416 10 months ago
Quoted from TomDK:
Can also connect two in series, this would be efficient.
#25417 10 months ago
Quite possible I guess, need someone with more technical knowledge than me to chime in, but if there's a chance it would work, I will give it a try .
BTW, they are available on Amazon for even less, 2 pack for $12!!
#25418 10 months ago
Quoted from razorsedge:
Be careful, there are electronic circuits inside, not just two lights or LEDs. So that might not work.
It would be better to use a DC-DC converter from 12 V to 6 V (e.g. amazon.com link »)).
And there could be another problem: Since the last SW update, the power of the topper beacon has been reduced to limit the noise when rotating. This has been achieved with PWM - The 12V output is only turned on intermittently, resulting in an average lower voltage level. This in turn can also cause problems for the beacons or the DC-DC converter.
But for Franking1302 it has worked, so let's try it despite all theory - who volunteers?
#25419 10 months ago
Quoted from dung:
I went for it also and got 4!
#25420 10 months ago
I have four of them from Franking1302, he bought them in a German store.
Yes, they are really high-end in very good quality and the work like really beacons with a sourrounding effect made by 4 LED.
These one also work in a slow motion effect that is much more related to the reality like the beacons used in the movie. They fit perfect to the beacons on the backbox.
As mentioned by Per it would be better to switch the beacon on or off with a relais, connected to the 12 volt power supply and using the signal from the beacons on the backbox.
Unfortunately my ALIEN is still out of order due to servicing and it will take a while untill it's back in action again.
#25421 10 months ago
Probably one of my favorite modes in the game is Loader Battle. They did an amazing job emulating the beacons on the play field...May not get there often, but we'll worth it...
#25422 10 months ago
Thanks, yeah, I was really happy with how that GI beacon effect turned out.
Used in Self Destruct also BTW.
#25423 10 months ago
And BTW, I’d be remiss if I didn’t give a hat tip to bcd for his great platform lighting schemes that made that beacon effect pretty easy to implement. Cheers, Brian.
#25424 10 months ago
1:12 has 10 LED for make a real effect
#25425 10 months ago
Amazing, of course that makes the cost more comprehensible - this is no cheap china crap and worth the money.
#25426 10 months ago
Quoted from Franking1302:
1:12 has 10 LED for make a real effect[quoted image]
I wonder if the 1:12th would look right? I don't think they would work on the upper, but on the lower ramp plastics maybe?
#25427 10 months ago
Swear I'm getting my Xeno Xenon's in the game this weekend or next...keep turning it on for fun on my bench, continually blinding me..my lazy meter has been high as of late...
#25428 10 months ago
Anyone wanna do a trade towards a new out of box TBL? Let’s work it out. Has to be picked up in Richmond VA though.
#25429 10 months ago
Quoted from VividPsychosis:Anyone wanna do a trade towards a new out of box TBL? Let’s work it out. Has to be picked up in Richmond VA though.
Never
#25430 10 months ago
I would trade my Alien LE to a TBL + 20000 dol
(joke )
#25431 10 months ago
Meanwhile I developed a simpler version of the Xeno Flasher circuit: 2 comparators evaluate the tongue and direction signal of the Xeno Drive interface and enable a NE555 oscillator creating short pulses for the LEDs. The board is small enough to fit near the Xeno Drive connector under the playfield.
I sent the prototype to Franking1302 (because he has inspired me) and he did a great job adding LEDs at various places to his Alien:
Some other projects currently require my attention, but I will check if / how I can offer you this mod. Right now, I've attached my hand-drawn schematics for those of you who can do something with it.
Sorry for this pic, i can not delete it with my smartphone...
#25432 10 months ago
In the meantime, I have developed a simpler version of the Xeno Flasher circuit: 2 comparators evaluate the tongue and direction signal from the Xeno Drive interface and enable a NE555 oscillator that generates short pulses for the LEDs. The board is small enough to fit near the Xeno Drive connector under the playfield.
I gave the prototype to Franking1302 (because he inspired me) and he did a great job adding LEDs to his alien at different places:
Some other projects require my attention, but I will check if / how I can offer you this mod. Right now I've attached my hand-drawn schematics for those of you who can help yourself.
#25433 10 months ago
Hello Per,
this is a brillant modification.
I hope to get back to my ALIEN in the next weeks, but first I have to complete the T2 playfield.
Please let me know when you flasher-mod is ready for a short run.
regards
Averell
#25434 10 months ago
Quoted from Per_:
[quoted image][quoted image]
So simple but SO impressive how that looks. Just take my money now haha
#25435 10 months ago
Quoted from delt31:
Agreed! Let us know!
#25436 10 months ago
I want TBL bad but Alien isn’t going anywhere!
#25437 10 months ago
Found this on the way to the bathroom at one of my local restaurants, I thought you guys would get a kick out of it lol
Coopers in Scranton.
F6EDF501-8119-424A-B55D-1BA15F1CA890 (resized).jpeg86FF1E68-67F5-4495-91B5-1B5D818681E2 (resized).jpeg
#25438 10 months ago
That's a great topper
#25439 10 months ago
Wish someone would get this game back in production
#25440 10 months ago
Quoted from J85M:
Pinball brothers. Alien, but in standard body. Supposedly.
#25441 10 months ago
How are the playfields holding up on these machines?
#25442 10 months ago
Quoted from spfxted:
Mine is perfect. Seems to be a solid playfield not like the recent drama on the other threads.
#25443 10 months ago
I had heard this on the grapevine but didn’t know if it had any truth to it, I would be interested in seeing how they would make it a standard body.
And if PBbros do come out of the woodwork first off the bat I’d like to see them make anyone who’s still out of pocket whole.
#25444 10 months ago
Quoted from J85M:
Heard the same...standard wide body... regardless, your last statement rings true... wouldn't mind my $1500.00 back, and know of many that lost more than that...Is Deeproot doing something like this ( are they doing anything)?
#25445 10 months ago
Question for the group.
I noticed during gameplay today that first the right, and then the left green inserts on either side of the airlock were out in random ways during gameplay today.
This game is somewhat new to me and from what I noticed, those two inserts by the airlock, the green insert in front of the xeno head and the closest pop bumper appear to run on the same solid green light during the game and attract, while all of the other lights will cycle variable colors. In that game, the green insert by the xeno head and the close pop bumper were still green. I checked out the boards housing the lights, they looked unremarkable.
So, I rebooted the game. When it does initial cycle through all lights upon start-up, both green inserts on either side of airlock show brief strong light. Started a game and on that game only the right green insert next to the airlock that was unlit. Tried to play a game with glass off. Left green insert stayed on, couldn't do any move/shot to make right insert turn on. Turned off and on. Next game the opposite, i.e. right green insert next to airlock on, but the left was off??? Otherwise, gameplay itself did not appear to be affected.
Maybe I'm missing something gameplay related? Thoughts/insights?
#25446 10 months ago
Quoted from ChipScott:
I'm not terribly familiar with these boards yet, but I noticed during gameplay today that first the right, and then the left green inserts on either side of the airlock went out today. Any suggestions on troubleshooting/fixing this?
This game is somewhat new to me and from what I noticed, those two inserts by the airlock, the green insert in front of the xeno head and the closest pop bumper appear to run on the same solid green light during the game and attract, while all of the other lights will cycle variable colors. The green insert by the xeno head and the close pop bumper are still green. The boards housing the lights look unremarkable. Could it be that just those two LEDs went out? If so, I suppose I would need to take the entire board down in order to fix this if thats the case. Any thoughts/recs?
Update: rebooted game. When it does initial cycle through all lights upon start-up, both green inserts on either side of airlock show brief strong light. Started a game and now it's only the right green insert next to the airlock that is unlit. Tried to play a game with glass off. Left green insert stayed on, couldn't do any move/shot to make right insert turn on. Maybe I'm missing something gameplay related? Thoughts/insights?
Try looking through the "Weland Yutani" thread on saving 3 aliens, and the "Heighway support thread"... alot less to wade through there..
Sounds like a few possibilities from my understanding:
I/o Board hardware version?
I/O Firmware version?
USB cable integrity/quality
...maybe some other possible causes too.
#25447 10 months ago
Damn it what a shame this died on the vine. I really wish someone would pick it up and continue but I think its over. At least there are some out there and maybe I'll even get to own one at some point but what a shame.. Watching gameplay vids hurts me deep down inside where I'm soft like a women. I...I gotta go.
#25448 10 months ago
Quoted from J85M:
Man, if this is true, I'd be in for sure, after they are built.
#25449 10 months ago
It's all nonsens, no more investors, no more copyright, no more ALIEN!
#25450 10 months ago
It's all nonsens, mo more investors, no more copyright, no more ALIEN!
.... but there are still machines for sale ... used and also NIB. Just a matter of money ... if you really really want an Alien you can grab one.
I also do not think that from the PinballBrothers a re-release will show up. Never throw good money behind bad money ...
$ 349.95
Pin Stadium Pinball LEDs
$ 750.00
Gweem's Mods
Trade
Machine - For Trade
Mt Vernon, WA
$ 279.95
Back Alley Creations
$ 154.00
Id Rather Play Pinball
€ 4.99
Multigame
