New! Dark mode!
(Topic ID: 106728)
ALIEN PINBALL - Game Over, Man, Game Over
By HeighwayPinball
5 years ago
  • 27,623 posts
  • 1,042 Pinsiders participating
  • Latest reply 4 days ago by Toucanf16
  • Topic is favorited by 277 Pinsiders
  • Alien Heighway Pinball, 2017
There have been 3,549 images uploaded to this topic. (View topic image gallery).
53 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 27623 posts in this topic. You are on page 503 of 553.
#25101 1 year ago
Quoted from Averell:
Hello Guys,
the first shipment to the States leaves tomorrow.
Of course, all parcels are insured and tracked by an extra service.
1 x Alberta (Canada)
1 x Arizona
2 x California
1 x Indiana
1 x Michigan
1 x Missouri
1 x Pennsylvania
1 x Virgina
regards
Averell
Wait....No North Carolina??
#25102 1 year ago
Any ideas on why the balls keep launching in play? Like all 6?
#25103 1 year ago
Quoted from Nethawk86:
Launcher switch getting stuck ?
#25104 1 year ago
Hello Guys,
1 x Arizona
2 x California
1 x Indiana
1 x Michigan
1 x Missouri
1 x Pennsylvania
1 x Virgina
regards
Averell
F#ck yeah..... Alberta, Canada!!!!!
QSS
#25105 1 year ago
Quoted from QuickSilverShelby:
QSS
Now say sorry!
#25106 1 year ago
Quoted from Roostking:
Now say sorry!
No way!!!
Alberta, Canada....... f#ckin eh!!
QSS
#25107 1 year ago
North Carolina and all the rest will follow tomorrow, first I need more packing material.
Don't worry...
10
#25108 1 year ago
First of my many mods done. Still have to refine it a bit and find a tie in so that they will only activate in certain modes. I can control the speed and flash mode as well. As soon as I get the details nailed down, I may make more. Have lots more immersive mods planned. I think this adds much more depth to the pin, especially ambush!!
#25109 1 year ago
Really cool modification, do you plan a kit to sell it?
#25110 1 year ago
It's not working. Plugged in a USB hub to the pc with mouse and keyboard and USB with the iso attached and it still comes up with login. Tried USB directly and still requests login. USB is 2.0.
I found the timing of the usb plugging In was key in my reinstall. You have to take it out for a second and then put it back in when it’s booting. It doesn’t recognize the usb until you do that. Good luck. I’m running the original computer on my prototype machine.
#25111 1 year ago
Alien is my #1 "want to play" pin. Maybe someday.
#25112 1 year ago
Wow that’s awesome can u please sell a kit and is it easy to install ?
#25113 1 year ago
What am I looking at? The left and right beacons on the slingshot areas right? Happens so quickly....
#25114 1 year ago
Quoted from delt31:
I counted total 6 two sling shots two airlock and two on ramp to sleep chamber ball lock
#25115 1 year ago
Those mini warning lights are cool!
Most orange flashing lights I notice in the film are mounted to the celings and point downward.
How do you think it would look if they were mounted to something overhanging, so that they point downwards? ... I think if this shed the right amount of light onto the playfield features, in the right locations, it could create a really awesome effect! . Instead of flashing in your face they more splash the effect across the playfield?
I'd be in for a set!
#25116 1 year ago
I'd take a set.
QSS
#25117 1 year ago
I got a PM about the amp settings. I've attached it to this post. Andrew picked a speaker/amp combination which when adjusted correctly (see the PDF) is very good. Not sure that this was by calculated design, I think he got lucky.
I've purchased a couple of these Chinese amps for my private use. It is what I use for my game room audio (when I play Borderlands 2).
David
Heighway Pinball Amplifier Settings.pdf
#25118 1 year ago
Hello Guys,
the last shipment to the States leaves tomorrow.
1 x Arizona
1 x California
1 x Indiana
1 x Massachusetts
2 x Michigan
1 x North Carolina
1 x Pennsylvania
regards
Averell
#25119 1 year ago
Quoted from razorsedge:
When I was first building these in 2016 while I was waiting for my LE#426 preorder, that was my initial plan. But this was when noone saw one and the designs were still making their way out, so I could not get any dimensions other than what I saw in proto pictures. So after I got screwed on the whole thing, I shelved these. Now that I picked one up, I dusted them off and was going through the pin physically and seeing where I could. Keeping these out of the balls way while also in an area that hides the wires and that keeps them accessible in the event of a replacement is needed, was where I saw the current setup. This isnt to say you cant play around with it. It took me almost 5 months sourcing these as the smaller "sirens" you go, the more fake they look. I was originally trying to go smaller to play it safe and that way I can mount them in more constrictive spaces, but I would have to go really small and those equate to just "flashers" and not sirens which is fine in a way since certain movie sequences, they just had flashers in the corridors. So when I finally found these that I could build around, I stuck with them as the board I made, the siren speed can be controlled as well as switched over to flashing as well. I am still toying around with them as id like some flashers by the alien or in the back corners. Each board can handle up to 6 lights and can be adjusted from 5v up to 60v, although at 5v it acts finicky since whatever you tap into on the board isnt a steady 5v besides the PS directly. But many of the function setups that I wanted to do are controlled by the 5v so I am still working on making that work as I can tap into that LED on the board like "ambush" so whenever thats on for the mode, it activates the sirens then instead of all the time. I do plan on making a limited run of these in the near future once I lock everything down tight. I am currently coming up with a 3D printed mount for these over the airlock LCD and left/right lanes. This way no tape is needed, and the less we mess with these plastics and playfield, the better. Currently there are only 4 I have on mine as shown in the video, 2 at the LCD and 2 at the lanes. I planned on 6 as anymore than that on the playfield and it kinda overtakes everything. Also, they dont really annoy or blind you as they are far enough apart where your eyes dont fixate on them, but the ambience they put off on the rest of the field makes it more immersive for sure in person.
#25120 1 year ago
I'm sure this has been discussed many times on this thread, but where have you SE owners find your beacon lights? Simple installation?
#25121 1 year ago
Quoted from Oneangrymo:
Currently I am playing around with it and am plugging into lines, but when I refine it, I hope to have it drop in plug and play simple for everyone.
#25122 1 year ago
Quoted from adamross:
https://pinside.com/pinball/forum/topic/get-away-from-her-you-bitch-alien-club-all-members-expendable#post-3812255
I like these because they are belt driven (absolutely silent, if I am sending you the correct link! )
ebay.com link » Emergency Light Rotator Warning Light Strobe Light For Factory Workshop Lte 1101
Yellow /12v DC)
I wouldn't say simple. Simpler if you go loose wire/magnet route. I drilled the metal like Libtech
#25123 1 year ago
Awesome mod. If you ever have a pinball party, or want to meet a complete stranger who would love to play Alien, let me know lol.
#25124 1 year ago
Quoted from budroosker:
Yellow /12v DC)
Thanks for the links!
16
#25125 1 year ago
I am so happy to officially join the group! What an ultimately badass game...I can't get over how incredible it is. This is the LE that High End Pinball repaired after it was damaged in a previous shipment. Everything currently works. Thankfully I have a lot of spare parts for repairs, and if that time comes, I'm glad that there are so many knowledgeable people here that can help!
#25126 1 year ago
Awesome!
Welcome to the best Pinball game out there
#25127 1 year ago
Quoted from delt31:
Awesome!
Alien is an awesome game indeed but I'm not sure it's "the best pinball game out there". It is an amazing immersion into the Alien universe via a pinball experience and the production of the game is top notch. I find the game really incredible but I don't think I can rank it as the "best ever". It is way up there in my opinion.
However,.... the game has some incredibly tight shots which are feakin hard to make consistently and some of the modes are nearly impossible to beat when set on factory settings. I checked my audits a while back and a couple of the modes only had one successful completion out of 70 attempts. Yeah, I'm no Keith Elwin on the game but I don't suck ass either. It's a tough game but it's a cool game.
That's just my opinion of the game and I understand your opinion. We both agree that it is a great game.
QSS
#25128 1 year ago
Quoted from delt31:
Awesome!
I wonder what Jurassic Park premium will have to say about that?
#25129 1 year ago
QSS
Immersion factor (audio clips, light show, video clips, music) is through the roof. Definitely not the best game out there.
Quoted from PinDoctor82:
I am so happy to officially join the group! What an ultimately badass game...I can't get over how incredible it is. This is the LE that High End Pinball repaired after it was damaged in a previous shipment. Everything currently works. Thankfully I have a lot of spare parts for repairs, and if that time comes, I'm glad that there are so many knowledgeable people here that can help![quoted image]
I hope you're good at tinkering on pins, because Alien is definitely a "fixing/tinkering on it is more than half of owning it" kind of game.
#25130 1 year ago
Me : “ you alien pinball machine is good.. real good”
Alien pinball machine: “the best”
#25131 1 year ago
Quoted from delt31:
Well.......second best!
#25132 1 year ago
Hey guys I finally got to self destruct in Alien modes. Of course I failed, but there was no cutscene when the timer ended, it just went to aliens modes. Maybe because I had rescue going on at the same time, is there a "failed" cut scene if you fail self destruct?
Just curious.
#25133 1 year ago
I didn't like the large black bases on the beacons that I saw, so did some searching and came up with these, to me they are an improvement.
#25134 1 year ago
Quoted from dgpinball:
I didn't like the large black bases on the beacons that I saw, so did some searching and came up with these, to me they are an improvement.[quoted image]
Looks great especially since it can be seen from "great distances"
#25135 1 year ago
QSS
Yeah - it was kind of tongue and cheek as it's hard to say what's truly the best ever. Here's the way I think about it. I've gone through a ton of games. There is only one I ever regretted selling and one I would sell absolutely last, if ever.
That game is Alien.
As for JP Prem, I'm getting one in October. I've played it though and it's fun but it's not special like Alien.
#25136 1 year ago
Quoted from delt31:
That game is Alien.
Totally agree I have 13-14 pins in my collection best is alien . No holds barred
#25137 1 year ago
Quoted from NPO:
I don't know about that as I haven't had to get under the hood in months and I play it every night...its like pirates once you get things worked thru it is a solid game..
#25138 1 year ago
Nope, still having the issue. switch is free and clear. Just starts launching all balls like a multiball mode is active during normal play but no multiball was triggered. I turn it off and back on and it fixes it until after a bit. Last night i had another issue where when I restarted it due to the ball launching issue, it would not boot and just said loading kernal and nothing. I had to turn it off twice and then leave it off for 5 minutes, then i fired it up and it worked again. Also having flickering light issues when I use the flippers. The ball launching doesnt seem like a opto issue either, I am thinking maybe its a I/O board. I have 1 black board on the middle playfield and I/O #1 will not update to version 9 either and is stuck on 8. Thinking the cause is in between one of those two. Still have to replace all the cables though. Having a vertical sync issue with tearing across the screen occasionally on the backbox.
#25139 1 year ago
New decal for the coindoor, exactly for the model that it is - Limited Edition.
I also designed a new FUSE MAP as decal.
If someone is interested, PDF attached below.
regards
Averell
ALIEN - Logo Kassentür - LIMITED EDITION full.pdfALIEN - Fuse List.pdf
#25140 1 year ago
Quoted from BladeFury:
Exactly.
Did you tweak yours or was it already done when you bought it...?
Cause trust me, if you search this thread it is NOT a "plug in and play" game if you're the first to bust it out of the box. This was about 1.5 years ago below:
Quoted from WeirPinball:
All I know is break out the tools after you unbox your games. Love the game, but holy sh!t - lots of tweaking right out of the box to get it to work correctly - I'm still not 100% there....There is absolutely no way they set this up and tested it...
If you are not comfortable fixing your own games - Then Alien in it's current state probably isn't for you.
#25141 1 year ago
regards
Averell[quoted image][quoted image]
awesome. Now we just need those LE plates that go on above the translight!
#25142 1 year ago
Quoted from delt31:
cool....then we just get the back stickers done as well and all of us can sell ours as "LE"s (*sarcasm*)
#25143 1 year ago
And inside stickers.... why would anyone want an LE plaque for a non LE game
#25144 1 year ago
Quoted from MK6PIN:
Its called upbadging in the car world and its happened forever. Makes for more $$$ when selling.
#25145 1 year ago
Yep
#25146 1 year ago
Of course the pinball world is much smaller, so they will be exposed..
#25147 1 year ago
Quoted from MK6PIN:
Kinda what I was thinking.....
#25148 1 year ago
I don't think of it as upsell at all. There is no true LE anymore bc everything is available. Folks who pay more for an LE doesn't make sense. I just wanted to have more alien merch. Mine isn't going anywhere!
#25149 1 year ago
Quoted from delt31:
Not true. There were less than 100 true, final run LE's made before everything went way south. Parts are out there to build many "LE" clones from different manufacturers. Doesn't mean one is "better" than the other...just the #'s match as it was built that way (Tron always comes to mind).
In Alienland, it's all about the build date for factory released machines...LE or standard. It's not hard to even sort the cobbled "standards" of the past, from later versions.
Easy to pick out a real LE when you pop the top (plaque helps as well).....
#25150 1 year ago
Quoted from MK6PIN:
Nah I'm talking about late built SEs like mine where I can tell parts are newer and it's exactly the same as LE. I agree earlier SEs are now being frankensteined but late run SEs with beacons and original side lights are exactly the same.
My point wasn't able this anyway. I don't care about LE nonsense. Totally overrated for all these games. Alien in itself is LE!
Gweem's Mods
Trade
Machine - For Trade
Paris, ÎLE-DE-FRANCE
Lynnwood, WASHINGTON
$ 499.95
Pin Stadium Pinball Mods
Back Alley Creations
14,000
Chichester, WEST SUSSEX
$ 399.95
$ 279.95
$ 750.00
$ 119.99
Cabinet - (Alt) Translites
FlyLand Designs
$ 7,899.00
Operation Pinball
