(Topic ID: 106728)
ALIEN PINBALL - Game Over, Man, Game Over
By HeighwayPinball
5 years ago
  • 26,933 posts
  • 1,035 Pinsiders participating
  • Latest reply 1 hour ago by Nethawk86
  • Topic is favorited by 272 Pinsiders
  • Alien Heighway Pinball, 2017
There have been 3,390 images uploaded to this topic. (View topic image gallery).
53 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 26933 posts in this topic. You are on page 491 of 539.
#24501 1 year ago
Quoted from Averell:
Can we get the instructions as download PDF?
Any one who wants them send me a PM with email address and I am happy to forward a PDF copy
This is for the Zotac Computer only for Alien
#24502 1 year ago
Quoted from megaladon:
Ugh, tried to boot from usb as instructed by weir websight but usb flashes and then nothing. Only thing I can get to is the bios setup utility. restore defaults? Anyone out there in alien land experienced this and can help?
Update: got the game up! Got the weir update to work. It’s running 1.02, how do I update the iO boards since some lights that were working b4 in .94 are not now?
#24503 1 year ago
Update got the game up! Got the weir update to work. It’s running 1.02, how do I update the iO boards since some lights that were working b4 in .94 are not now? Thanks
#24504 1 year ago
congrats!!!!....it's in the service menu...just go to "I/O" boards, and select "update"....(remember to do for all of them)
#24505 1 year ago
Quoted from MK6PIN:
Do I have to have the USB in the computer I’m just wondering where I find the updated code for it? Because the lights on the map don’t match at all for the lights on the flashing on the playfield.
65689DC8-F8F2-496A-9BAF-42E3EB45467B (resized).jpegB1599E99-68F0-4CFA-8DCD-A50A48A6A817 (resized).jpeg
#24506 1 year ago
Nope....you loaded the new I/O code when you updated the cpu......should be in there....when you go to the service menu, just choose the I/O boards, and it will ask if you want to update the boards....
#24507 1 year ago
Quoted from MK6PIN:
Well then there something wrong because the lights don’t match up at all to what’s on the play field? The only boards that match are the mode boards toward the bottom.
#24508 1 year ago
Did the I/O boards take the update?...Not quite sure what you mean by " not line up"? Guessing attract mode is good?
#24509 1 year ago
Quoted from MK6PIN:
I had to download the restore on the weir site:
http://weirpinball.com/alien/alien.html
But before I did the restore my software was .94 after the software update it upgraded it to 1.02. But now If I select individual lamps for example one of the eggs a light flashes somewhere else. When I did the restore from the website I had to do it twice and I wonder if maybe it didn’t update completely/correctly But now I’m worried if I tried again I might not be able to get the game playing again. It’s a risk but that’s the only thing I can think of to do. At least right now it’s playing.
#24510 1 year ago
Hey megaladon, glad you got out of your boot failure... you did that via weirpinball's instructions?
Howwwwever... you said you were moving from software 0.94 to 1.02. There are two major problems you may have with this:
1) I strongly suspect that the problem you're reporting with the lights is because your game has the 5-element GI "towers", which were not on the production machines and not supported by 1.x software. Your physical lights do not match the software mappings, which is why some lights are no longer working -- your GI lamps are gobbling up 4 more "places" than expected; the exact effect of this varies from one lamp chain to the next. There is no solution for this in the 1.x software... however, timebandit has reproduced lamps for the Heighway system, so your best solution may be to buy a bunch of those and replace all of your GI lamps with 1-element devices, and then the lights should work as expected.
2) You may find that your APC drop targets are not recognized correctly, because their polarity was reversed between prototype and production machines. Not quite sure of the best solution for this one.
#24511 1 year ago
Quoted from Ferret:
ferret would he have any issues upgrading to the Newer Computer since the Zotac is bound to fail again?
#24512 1 year ago
ferret and join_the_cirqus thanks for the help. Yea the only choice I had was to do the restore on weirpinball site and it upgraded this machine to 1.02. I do have the towers but thought it didn’t matter till 1.2. I don’t mind getting the new computer, I’ll check my drops when I get home to see if they’re reversed. I contacted timebandit. Sounds like the upgrade is inevitable lol. Do u think it’s worth another restore just in case something didn’t install right?
#24513 1 year ago
Quoted from Join_The_Cirqus:
I believe that's a neutral proposition ... either computer should be fine, and if the Zotac is working, no particular reason to upgrade now.
For the lighting issue? No. The change from the 5-element to 1-element GI was part of the last production push, and was done in sync with the 0.x to 1.x code. You can even kinda verify it in single-lamp test mode in the operator menus... if you walk through the problematic lamp chains, you should see that each facet of a 5-element GI gets individually lit as you progress through the lamps in the test.
Sorry for the answer, I'm sure it's not what you were looking for. On the plus side, 1.2 is soooo much better than 0.9!
#24514 1 year ago
ferret the apc targets are working fine and it looks like you’re right bout the lights, they cycle to different spots on playfield map but only the diff colors on the multi leds (if that makes sense). I just bought the set from mavantix lol! Ordering the single led should fix that. Does it come with the clear domes or where do I get that? Would the 1.2 software work on the machine or is that when the new machine is required. Oh yea, 1.02 is a ton better!
#24515 1 year ago
ferret is it ok to change led brightness in the setting in the latest code? I know earlier code it could cause resets. Same question with the Shaker
#24516 1 year ago
Hallo guys,
early this morning at 08:00 am my ALIEN was delivered by freight forwarding.
Now the ALIEN must stay to Friday in the garage and then we start an unboxing party.
Nobody of the invited people know what's going on and even me does not know what's really in the box - of course an ALIEN but how is the condition?
Can hardly wait...
#24517 1 year ago
Congrats. Is your picture upside down or was your game delivered upside down?
Your gonna love it.
QSS
#24518 1 year ago
Quoted from delt31:
AFAIK this should all be OK. With the shaker, it's possible for that to stress your power supply, so if you find yourself getting system resets when you're expecting shaker effects, you might need to back off on that (or upgrade your power supply).
#24519 1 year ago
Has anyone heard from TimeBandit? I sent a question to him over a week ago asking about getting a 64 pack of leds, but not a word back.
#24520 1 year ago
You didn't check condition before you accepted delivery?
#24521 1 year ago
Quoted from Ferret:
thanks - I upgraded my power but still hesistant to put that shaker in (as my alien has been perfect). I believe it only goes off twice during gameplay right?
#24522 1 year ago
The shaker is used in several areas around the game... don't remember all of them. I wanna say Combat Drop, APC, Queen's Nest, Self Destruct, Loader Battle, and Sentry Guns?
#24523 1 year ago
Quoted from Ferret:
Do you have any idea what could cause reset randomly during the game?
I ll looking for any clue to help me analyze my issue. The log didn’t helped that much and everything seems to work fine... tks
#24524 1 year ago
Quoted from noitbe1:
Did you happen to notice if it corresponded with a replay? That was one weird situation that happened to us.
#24525 1 year ago
If you haven't already, I'd start with disabling the shaker and the beacon, if you have those add-ons. Resets often seem to be related to excessive power draw.
#24526 1 year ago
Quoted from Ferret:
was that added in 1.2? More shaker?
#24527 1 year ago
Quoted from Ferret:
I don’t have the shaker only the beacons. I’ ve already read that it could cause issue but playing without it is not the same but this could be a test for sure.
#24528 1 year ago
Quoted from knockerlover:
Could you please tell me more about the replay? In the log files it mentioned a bonus award which could have cause that. From the log file It caused a infinite loop with this bonus award and crashed.
Also it always happening when I have a lot of points (long game with 3 or 4 sequences acheived)
#24530 1 year ago
Could you please tell me more about the replay? In the log files it mentioned a bonus award which could have cause that. From the log file It caused a infinite loop with this onus award and crashed.
I think we just disabled the replay award..
#24531 1 year ago
Thanks. This might be really helpfull. I’ll share if it fixed my issue for others.
Really strange behavior due to maybe a software issue left in 1.2.
#24532 1 year ago
Well I guess I'm getting a Shaker now!
#24533 1 year ago
Quoted from dung:
He's baaack.
#24534 1 year ago
Hello all.
I have a strange behavior and i wanted to know if anyone share this or have any idea what s going on:
During game play when i pressed the flippers some if the leds bright when pressing the button, like this.
Any idea what could cause this?
#24535 1 year ago
Hello all.
The “disco” effect.. helped some by replacing usb cables with better ones.. but mostly helped with latest code.
I believe it’s caused by cross chatter on the I/O board..
#24536 1 year ago
Correct, it is caused by crosstalk on the IO board. It has nothing to do with the USB cables.
You need to update the IO boards to the 14.09 firmware to minimize this.
#24537 1 year ago
Quoted from bcd:
Agreed. My original had this big time and the latter build I have now is very minimal with the updated boards
#24538 1 year ago
Since my last post:
I eventually removed the replay award and since then no more reset.
I was able to play long game first time for a while.
I also made a factory reset as well (before that)
I m running 1.2 and can’t say for others but it seems that there is something wrong with it.
Thanks knockerlover for his infos
#24539 1 year ago
And all is now well in Alienland again.....good to see you back!!
#24540 1 year ago
Upgraded my computer tonight, spent a bunch of time on cleaning up the cabling.
My drop target board is inverted. Does anyone know how to change it or where to source a new board from?
Board appears to be a copy of the williams system 11 drop target board. I can invert the outputs by running a bunch of jumper wires and cutting traces, but would be better if i could find a chip that would do it instead.
17
#24541 1 year ago
Here she is... what a beauty.
No damage, no scratches, it's out of the box like a brandnew pin.
#24542 1 year ago
So awesome!!!!
wonder if there are any limited edition emblems available for sale like everything else. The #XX out of XXX in those pics.
#24543 1 year ago
Beautiful congratulations. It seems to le that the black trim LE version is the rarest of those 3 LE and also the rarest with the one with no 27 lcd, probably because the standard was already black.
This is my personal favorite version.
Welcome to the club.
Great purschase.
#24544 1 year ago
Absolutely gorgeous!!! Game looks exceptional in black, and do believe it was the "rarest of the rare" color-wise, in the final run. congrats....enjoy it!!!
Quoted from delt31:
Suspect any print shop could generate a pretty accurate replica (like any other game's LE designation badge)...can't imagine the value in it, however. The LE's are marked as such at various areas of the game, along with receipt....would be easy for someone that wanted/ found an LE could easily find out if it was authentic or not.
#24545 1 year ago
Quoted from MK6PIN:
Thanks could care less about value. Like the way it looks
Was really looking for ones already printed similar to how they some the side art.
#24546 1 year ago
I have a prototype alien starting to upgrade it, love the game but someday upgrading/trading to a le would be nice! Get a cliffy on that magnet! Just curious, where do you get a NIB alien?! Do vendors even have them lol?
74D4BC05-58B7-4918-940B-37C99FAB6017 (resized).jpegEE867F13-8192-4B1F-BA97-B9F3A5869811 (resized).jpeg
#24547 1 year ago
No more avail NIB that I'm aware of from vendors
Speaking of magnet though, I can't confirm for sure but I feel like the cliffy doesn't allow the power of the magnet to work as well.
Ferret - could that be correct? I think the only thing to increase the magnet is in coils...
#24548 1 year ago
I have a prototype alien starting to upgrade it, love the game but someday upgrading/trading to a le would be nice! Get a cliffy on that magnet! Just curious, where do you get a NIB alien?! Do vendors even have them lol?[quoted image][quoted image]
You should replace or file down that magnet core.. and make it more level with the playfield.
Upgrading from an early run game to a production game.. you have a long road ahead of you buddy.
#24549 1 year ago
Sorry, no idea. That magnet should be just like any other similar playfield magnet. Yes, it can be strengthened through coil adjustment in the software.
#24550 1 year ago
Need some help here...when swapping out the USB cables, are you guys talking about the cables that connect from under the playfield boards to the CPU towards the back bottom of the cabinet? I noticed the connector to those boards under the playfield are quite different.
Can someone provide a link on amazon of the cables they used to replace what’s currently in the machine.
Thanks in advance!
Arthur
14,500 (OBO)
Sale Pending!
Fort Lauderdale, FL
$ 49.95
Pin Stadium Pinball LEDs
$ 750.00
$ 399.95
$ 14,900.00
www.retroarcade.se
Back Alley Creations
Gweem's Mods
$ 150.00
Republic Of Pinball
PinWorlds
