(Topic ID: 106728)
ALIEN PINBALL - Game Over, Man, Game Over
By HeighwayPinball
5 years ago
  • 26,945 posts
  • 1,035 Pinsiders participating
  • Latest reply 2 hours ago by gabegabegabe
  • Topic is favorited by 273 Pinsiders
  • Alien Heighway Pinball, 2017
There have been 3,390 images uploaded to this topic. (View topic image gallery).
53 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 26945 posts in this topic. You are on page 320 of 539.
#15951 2 years ago
Well this showed up last Monday. But the glass broke in transit.
Working on cleaning out and getting a new glass.
#15952 2 years ago
Quoted from onedeath:
Should be okay once you clean/vacuum right? Or is broken glass more problematic?
#15953 2 years ago
Glassburster!
sorry this happened.
#15954 2 years ago
Quoted from jonesjb:
No should be OK once cleaned out. Just taking my time not to miss the one piece of glass that would inevitably get dragged over the playfield screen.
#15955 2 years ago
Fitting name. http://www.urbandictionary.com/define.php?term=Alieu
#15956 2 years ago
This is the 2nd one reported here with glass broken in shipment out of how many? 20 shipped so far? I wonder if something has changed with the glass magazine.
#15957 2 years ago
Did it come from Cointaker?
#15958 2 years ago
Quoted from Jgaltr56:
A Full Throttle Andrew brought to RMPS had the glass broken in transit as well...so maybe nothing has changed but maybe should! Might need some specialized padding against it or something. Some foam under the glass that would at least keep all the glass out of the game if it does shatter.
#15959 2 years ago
It's wild to me that this can happen with the magazine holding the glass. You would think it would handle impact of travel better than a traditional piece of glass slid into a cabinet. The magazine uses sandwiched weather stripping to hold the glass.
#15960 2 years ago
Quoted from Wickerman2:
Tempered glass does not usually break by forces against it. Perhaps the glass is too tight in the frame. (Or too loose?)
#15961 2 years ago
that would be the only logical answer if it is somehow getting jarred in the frame and catching an edge
#15962 2 years ago
A contracting frame would not also cause breakage? Seems I've read that before somewhere. Any glass guys here?
#15963 2 years ago
Quoted from sed6:
Yes it did and everything is being taken care of as always.
#15964 2 years ago
Did you vacuum it out yet?
#15965 2 years ago
Quoted from jeffspinballpalace:
Started to should have the playfield done and out tomorrow hopefully.
#15966 2 years ago
Just use that new garden hose, it will wash that glass right out
Sorry, that sucks to wait that long and get one broken.
#15967 2 years ago
Sucks that the glass broke. Luckily you can easily remove the whole playfield, that should make it easier.
#15968 2 years ago
Quoted from Axl:
Got most of the easy to reach stuff sucked up. Going to have a friend help shake the playfield upside down to get any strays out.
10
#15969 2 years ago
Glass guy here, been in the window business literally my entire life.
1 - Tempered glass has a very "sensitive" edge, but without seeing the magazine it is hard to see if there is a pinch point or something pointy that the edge of the glass could hit the edge shattering it. A screw point is enough, in fact a brad nail is large enough to shatter the glass if it hits the edge.
2 - Tempered glass can self shatter if there is a flaw in the glass when it is heat treated. Pretty rare but it does happen weeks or months after it is made.
3 - Thermal breaks can occur but unlikely in a pinball machine, not likely to get a rapid enough temperature change for that to happen.
4 - It could break from a hit to the middle of the panel but you need a pretty heavy strike. Unlikely during transport.
At a GUESS I would say point 1 or 2.
#15970 2 years ago
credit towards FullTh or any future kit
I sort of got the impression that they are salvaging alien and thats about it. Have they really committed to keeping heighway going ?
#15971 2 years ago
Quoted from sd_tom:
I think they are going to continue the company, I'd be hesitant to buy alien otherwise with lack of support
12
#15972 2 years ago
Quoted from sd_tom:
I've never had that impression. All the investors were previously invested in the company, obviously they had an interest in it and saw potential for it. Dave Sanders is spending his days doing something there, and it isn't attaching plastics in the factory for Alien.
Let's forgive them for NOT announcing the next game, and focusing on Alien. Do you really think it would be sound for them to trot out their next planned release?
#15973 2 years ago
Quoted from sd_tom:
I don't think that's the case at all...they will struggle to make a profit vs their investment on Alien so I'm sure they are going to try and make a go of it. Otherwise, what would be the point?
#15974 2 years ago
Quoted from PinPatch:
After looking at it again, I'm guessing the glass shifted on the rubber gasket and the edge hit a screw post. Glass lays on a gasket and is held against it with a bracket all the way around. If the bracket isn't tight enough or contracts or whatever, seems possible the glass could shift and the edge could hit any one of the screw posts. I couldn't get a good pic of it but they do also have a gasket between the glass edge and the screw posts but it doesn't look foolproof.
#15975 2 years ago
Thanks for the info.
#15976 2 years ago
Quoted from frolic:
I concur. Doesn't make much sense for them to just finish Alien and then bail. Doesn't mean they will be successful but I'm sure they are going to try. I'd say they off to a good start with everything they've done since taking over. They also appear to be very experienced businessmen so I'd expect they have a plan already in place on how to move forward. I also doubt we will be made aware of their plans. They come across to me as a group that would prefer to speak more with actions than with words.
If there is a game three my guess is we won't be privy to it until it's just a couple months from being ready to ship. (That would be my advice anyway).
#15977 2 years ago
#3 is Barry's design, right?
#15978 2 years ago
A few things to confirm.
Indeed they will be shipping to cointaker. I brought up the prepayment I made about already paying and they seemed agreeable about an arrangement for that.
If you have pdi/roman glass it won't ship out in this current container to CT as they wait for their roman glass shipment. After seeing the reports if glass DOA, trying to get a non roman switcheroo to speed up delivery.
#15979 2 years ago
Super! And that confirms my earlier.post that Heighway isn't shipping machines to individuals. Everyone going forward is going to get theirs from CT. Did you pay extra for shipping from CT or did you order from them? Melissa said the next container of games is coming in Sept, so no new unboxings until then I guess.
#15980 2 years ago
never mind
#15981 2 years ago
Really pissed about the fiber optic lights, shot off an email to Melissa and Morgan about getting a refund from that, especially given that I paid for what was advertised as standard on a LE, contractual obligation that Heighway Pin broke. But in the meantime, I am preparing all my MODs for this game for when it arrives end of the month. Got an insane amount of ideas and "fixes" from a insane Alien/Aliens film fanatic junkie. I feel a lot was left to be desired from this game from a fans point of view and I am aiming to fix that. I have new backglass art being drawn as well, as I am not a fan of the "custom Queen" that was done. No animosity or bad waves implied or given towards Brien, he did what he did in 4 days! That is impressive in itself. But given Andrews crap he pulled on Brien and him only having 4 days, that didnt give him a lot of time to design anything, pretty much just draw what came to mind. I just dont like his interpretation of the queen with the spikes on her crown and other features that she never had. I feel that just the 1 queen and egg is basic in terms of characters and tone. This is supposed to be Alien and Aliens, but the backglass only shows a Queen from Aliens and a egg and nothing else. I feel it needs more immersion and more depth as well as a nod to what made both films great as well as what is included in the gameplay. I commissioned a piece to be made based on a design I sketched up. This is MOD #1 lol, of easily 20, with 1 being a "you have to see it to believe it" lol. I am quite proud of it. Ive made numerous complaints to Heighway pin about some "inconsistencies" in the game for "authenticity" purposes lol, regarding sounds and inaccurate and mislabeled items. A couple that really bother me (being a Gunsmith especially lol) are the guns they got wrong. They labeled and pictured Vasquez's S&W M39 as a H&K VP70 (which is what LT. Gorman carried) as well as pictured a Remington 870 as Hick's backup Ithaca 37 shotgun (Ithaca 37's are bottom only ejecting and feeding whereas the picture clearly shows a side port). I can kinda sorta shrug the 870 one away, but the VP70 has to be changed in someway, either changing the sound to say M39 (doubtful), or just changing the picture to an actual VP70 (more likely....but still doubtful lol). Lots of bad audio clips heard, I am sure these will be easily corrected later so not real worried. Same goes for a couple video clips. I look foward to posting all these MODs and a unboxing of an "actual" LE for everyone finally here soon. I might stream it (it will be my first stream so still debating).
#15982 2 years ago
So after you complete all the modes, do they loop back and restart? Even if you haven't completed all the multiballs?
#15983 2 years ago
That is correct.
#15984 2 years ago
Quoted from bcd:
That is correct.
Any value in doing more than one round of modes before going into all out war, point wise?
#15985 2 years ago
BINGO! Glass probably has slid into these screw posts, during shipping. A simple solution would be to place some double sided glazing tape to stop the glass moving around.
#15986 2 years ago
I am getting very excited to be spending 3 days in the presence of Alien pinball at the Buffalo Pinball Summer Open this weekend. A lot of tough players will be putting it to the ultimate test.
#15987 2 years ago
Quoted from ezeltmann:
I would love to hear some feedback from some solid unbiased players that put some real time on it.
#15988 2 years ago
Well, yeah, All Out War's value increases depending on how you did in each mode and multiball played... but I doubt it's worth intentionally avoiding AOW for that. And once it's actually qualified, you can't avoid it, most other features disable when AOW is lit.
On a related note, you can't screw yourself by "lapping" any AOW requirements, the code does keep track of everything if you're having an epic game. (Said with unwarranted confidence, after a bug in 0.98 that prevented AOW from starting at all... doh!)
#15989 2 years ago
Quoted from Nethawk86:
Would love to check out your Alien some day!!
#15990 2 years ago
Following thread...
#15991 2 years ago
I think the games sounds is amazing based on what I've seen. If there wasn't so much drama I would buy one but not waiting on sidelines
#15992 2 years ago
Quoted from delt31:
Smart move.
I ordered an LE at Expo last October and hope it see it next month.
At this point there really is no reason to rush into an order.
You could wait until games are shipping and hopefully play one in the wild before you order (always the best idea if possible).
If one doesn't end up near you on location, at least there will be more reviews /videos out there to help you make an informed decision.
I was lucky enough to be able to play it at Expo, TPF, and now have a friend 20 min from my house with one. I absolutely love it and can't wait to get mine!
The sound package is on another level. daudioguy created an atmosphere that recreates the tension from the movies perfectly. It is by far the most imersive pin I have ever played.
#15993 2 years ago
I know for sure I want to buy based on the gameplay I've seen and that sound. Unbelievable. I'm just concerned about not getting one if I give them my money.
I also don't like buying new.
#15994 2 years ago
Quoted from delt31:
I don't think you can order direct from Heighway anymore.
#15995 2 years ago
Quoted from Hazoff:
Correct, I believe Cointaker is the only distributor and they are awesome to deal with.
#15996 2 years ago
Oh ok. What is standard price again and is that the one they were playing in Buffalo Pinball stream?
#15997 2 years ago
Quoted from delt31:
Check cointaker or nitro's website
#15999 2 years ago
EDIT - no need to reach out.
#16000 2 years ago
Quoted from delt31:
thanks guys. can someone with a standard on order from the states PM me. I have a question and would like to know the answer. Really had no intent on buying one but now I'm getting the bug.
Make sure to manage your expectations if you order now.
Check with Cointaker to confirm but I know there are a lot of people with paid orders waiting for games, it may be a few months before you actually get one even if you pay in full today.
Just hate to see you to get frustrated if it can be avoided.
Back Alley Creations
$ 259.95
Pin Stadium Pinball LEDs
14,500 (OBO)
Sale Pending!
Fort Lauderdale, FL
$ 14,900.00
www.retroarcade.se
Gweem's Mods
$ 279.95
$ 750.00
$ 199.99
PinballBulbs
