(Topic ID: 106728)
ALIEN PINBALL - Game Over, Man, Game Over
By HeighwayPinball
9 years ago
  • 30,191 posts
  • 1,096 Pinsiders participating
  • Latest reply 2 days ago by Roostking
  • Topic is favorited by 291 Pinsiders
Averell's Stasis Chamber Mod Kit - Extract.pdf (PDF preview)
53 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 30,191 posts in this topic. You are on page 239 of 604.
#11901 7 years ago
Quoted from Wickerman2:
It shakes the shit out of the game. Way too violent. I unplugged it until I get around to adjusting the weights and tweaking it.
Wickerman2, Thank you! I'm happy to hear the shaker can be manually adjusted as we've seen with past shaker motors.
Now I will add the shaker to my order.
26
#11902 7 years ago
Speaking as the programmer on Full Throttle, and as someone who also disconnected his shaker...
Soon we'll be finalizing the shaker code for Alien. I plan to backport all fixes to Full Throttle, and add adjustments to tune it to your liking.
So, in a future Full Throttle code update, you'll have a better shaker experience.
#11903 7 years ago
Quoted from chucksmith:
FYI: It's a cointaker shaker on FTh and I'm assuming I can adjust it similar to other shakers via the arms/weights...I have NOT taken the cover off yet to confirm that but I can't imagine it's much different.
I figure it would be nice to have for future titles anyway depending how they implement on each...you can always turn if off depending which playfield kit you have in.
#11904 7 years ago
Quoted from bcd:
GREAT! That's good news.
#11905 7 years ago
So it's just a Cointaker Shaker and we could add one later if we wanted to?
Also....how hard would it be to just your own EL lighting to the side blades on Alien? I can't imagine it would be that difficult.
#11906 7 years ago
Quoted from Astropin:
Did wicker buy his FT through Cointaker? That might explain why he has a CT shaker in his game? I can't imagine Heighway would ship over CT shakers to put in games sold in Europe, so maybe shakers depend on local suppliers in that games region?
#11907 7 years ago
Quoted from bcd:
This is great! A request to Heighway design team.
If making it all software adjustable proves to be problem, then making it easy to change the weight offset manually would be nice.
If you are making your own shaker motor assy, what people need is an easy way to set the weights-offset.
2 weights with one side having detentes (flats) on the shaft without the screw glued in.
The weight could be moved out of sync by 0, 45, 90, 135 degrees.
180 degrees is the same as being 'off' so we don't need that.
If that's too many settings, then simply settings of 0 and 90 degrees offset is good.
#11908 7 years ago
Quoted from Jgaltr56:
Or just the cabinet sides shipped flat. I believe the cabinet is screwed together like a piece of Ikea furniture?
I think that won't work. We are talking about the inner shell. The outside shell should be easily replaceable.
#11909 7 years ago
Quoted from J85M:
No, CT shaker also in Europe. The red tremor one.
42
#11910 7 years ago
ENADA show, Rimini, Italy.
All set up and ready to go for tomorrow with our Italian distributors
#11911 7 years ago
Quoted from HeighwayPinball:
Nice lineup
#11912 7 years ago
I just replaced my red trimmer on Ghostbusters with a coin taker regular Shaker motor as the red tremor was too violent and there's no adjustments in Ghostbusters that will change it although they are in the Diagnostics but unable to change the vibration from Full to minimal in software the new shaker from coin taker shakes 30% last and works perfect
#11913 7 years ago
I've followed this thread closely for last few months. Not ready to pull the trigger, but very close to getting in touch with Andrew to get in on an LE before they're all gone. Not exactly losing sleep over the decision, because by all accounts it is and will continue to be a great pin and a "safe" purchase. However, since I only have room for 5 pins, one of my current collection has to go, so it's not a no-brainer for me either.
Anyway... on the point of my post. Had to drop the truck off today for a little work this afternoon... waiting in their customer lounge for a few minutes for a ride from a friend. Look over at the small TV they had in the corner and AMC channel was on.... looked a bit closer and saw Parker getting speared by the Alien's inner jaws (edited for TV). Seriously can't make this sh%t up... What are the odds of seeing this scene on this particular 5 minutes of my day where I was looking at a TV. Maybe someone is trying to tell me to shut up and put my money down??
#11914 7 years ago
Quoted from Pinzap:
Hmmmm... seems like the only morally correct decision is to buy an Alien pinball machine.
#11915 7 years ago
Quoted from Pinzap:
It's an omen!
#11916 7 years ago
Quoted from PinballRulez:
Thanks PinballRulez for the info. I have heard they are the HULK of the shaker world and shake your game around pretty hard
#11917 7 years ago
Any further update on LE approvals?!
#11918 7 years ago
Quoted from J85M:
Thanks pinballrulez for the info. I have heard they are the HULK of the shaker world and shake your game around pretty hard
True. I hope and bcd already pointed out that the shaker gets a better integration in Alien. When I turned the shaker on in my Full Throttle for the first time people evacuated their houses because they thought there was an earthquake going on
#11919 7 years ago
Quoted from sed6:
Here you go.
Thank you! Just what I needed.
#11920 7 years ago
Quoted from pindan3:
just jumped to the last thread........will this game be in Dallas?
Maybe, but Dallas won't make it out of the game.
#11921 7 years ago
For those who want to tame the shaker, this image shows a great way to do it.
#11922 7 years ago
I think you have a shaker fetish chuck
#11923 7 years ago
Quoted from J85M:
I know .. Its a real problem
#11924 7 years ago
Probably not too hard, but might be expensive. I just researched EL panels after thinking the exact same thing. Seems the cost of EL panels goes up exponentially the bigger they get. Add to that their long tapered shape and the power supply to run it and the $240 they are charging isn't really an outrageous price.
Now the "fiber optic" lighting for $800, someone explain THAT one to me...
#11925 7 years ago
Quoted from sed6:
not sure about build costs on anything but fiber optic ramps add another board I believe...$600 at the factory instead of 800 for what it's worth
#11926 7 years ago
Quoted from sed6:
At a guess there is the hardware:
Fiber optics themselves
Additional power supply maybe?
Driver blocks/emitters to run them
Additional board/s
Additional wiring/harness/connectors and misc hardware
And then maybe some behind the scenes costs incurred:
Additional code to make them interactive
Additional install time on the assembly line.
For a really good price comparison the Tron Pro Ramp kit was what $400/$450 and as amazing as the kit was (possibly one of the best mods ever) I would like to think Heighway is offering a superior product.
#11927 7 years ago
I wonder where the fiber optic ramp lighting will run on Alien. Will it only be on the plastic return areas or can we expect it to extended along the entire ramp, including the metal ramp itself?
#11928 7 years ago
Quoted from PanzerFreak:
I'd love to see something a little more creative with the fiber optics, we have seen solid colours and flashes back on TRON
Apart from on the Nostromo I can't remember many fully functional lights in either Alien or Aliens, it would be awesome if you start out and they function 100% and as you progress into the game if the ramps could pulse and flicker - almost as if the game is deteriorating as the environments do in the films once shit hits the fan.
Then again I wouldn't mind this feature on the entire games lighting. And we need red GI (can't remember if Aline has RGB GI) during ambush just finished watching Aliens again and the lighting during the ambush and Hudsons last scene pure adrenaline inducing!
#11929 7 years ago
Can the sideblades changed with Full Throttle blades if you change the kit or are the sideblades decals?
#11930 7 years ago
Quoted from J85M:
I think this is a great suggestion! Nice shiny ship slowly goes dark and dirty..
#11931 7 years ago
Quoted from Roostking:
The thought popped into my head watching Aliens tonight.
In Alien the Nostromo is super clean and bright everything is crisp by the third act the things falling apart, flickering lights, steam vents blowing off, power outages in corridors etc
Aliens follows a similar pattern except the Marine team replaces the Nostromo they start out fully loaded suited up by mid way they are in tatters and lost half the team not to mention the environments begin to get messed up from Alien ambushes and gun fights.
Just thought it would be cool if the pin could somehow recreate those subtle but immersive trademark.
#11932 7 years ago
Quoted from J85M:
Yes to RGB GI.
#11933 7 years ago
Quoted from Whysnow:
you are correct. I should have been more clear. The light up side and back blade is an option.
The side blades themself are on the side like normal from what I can see. The difference between our Full T cab and our Aliens cab is that the Aliens cab has a spot routed out behind the side blade which accepts the el light to light the blades up.
Ah , gotcha , that clears it up for me , thanks . The el would obviously be cool , but not necessary for the blade to look cool .
#11934 7 years ago
Well my order for a Standard is in and I can not wait till it arrives.
Sounds like it will be only a few weeks.
#11935 7 years ago
Quoted from onedeath:
Awesome! Sounds like production should be ramping up soon if the wait will only be a few weeks.
#11936 7 years ago
Hi Andrew,
Do the games in Italy now have the planned flasher installed for the Alien head? Also, do you think we will see LE's revealed by or at the Texas Pinball Festival?
Thank you
#11937 7 years ago
Quoted from J85M:
Absolutely! It would be awesome to have a "Hudson Final Stand" stage to the ambush mode where everything is red expect green shots that kill aliens. Having it play along side video clips from that scene and audio from Hudson in full swearing glory sounds awesome.
#11938 7 years ago
I think the smiley face was a tip to the post being sarcastic. It doesn't seem like there are any 'true' production games out right now.
#11939 7 years ago
Quoted from Pale_Purple:
Nope was not sarcastic at all just happy. Games are shipping....will have it in a few weeks at my house.
Order was from Cointaker, still a few left in the coming shipment.
#11940 7 years ago
I'd like to believe that (had alien on order from cointaker since last summer) but in February cointaker said they would have standards shipping out by mid Feb and 15 LEs by mid March (right now). Neither of those happened.
No LE art shown yet and the few games that have shipped (direct from Heighway not cointaker) don't have production boards or final art in the flipper overlays.
I'm just hoping to get my game sometime this summer.
#11941 7 years ago
I'll can wait if needed. I have plenty of machines to play to keep be busy.
#11942 7 years ago
Has anybody looked into saving some money and buying directly from Highway?
#11943 7 years ago
Quoted from PappyBoyington:
I did, but I think you get hit either way. The website cost does not include shipping, so I believe all shipments have to come through the US distro
#11944 7 years ago
No US distrib if you're paying door-to-door air freight shipping, which I'm pretty sure most the people ordering from Heighway is doing. Once it ships via air from Heighway, it will be delivered in no time.
#11945 7 years ago
Quoted from HoakyPoaky:
Not to mention it's only $350.
#11946 7 years ago
Quoted from Manimal:
I just checked with Heighway and for the standard edition with the 27" LCD is a savings of around a couple hundred compared to Cointaker.
HEIGHWAY standard with 27" is $6,950 plus Shipping $350 to your door. Plus $30-$40 for other shipping fees that may or may not be added on. Total--- $7,340
COINTAKER standard with the 27" LCD for $7,495. This includes all shipping charges and extra fees.
What size is the standard size backbox LCD? Is the 27" really worth the extra $500? Give me your opinions please.
#11947 7 years ago
Yes. Here is why:
1. You are future proofing your pin for future Heighway releases that will leverage the screen. This split across these future pins reduces the cost.
2. $500 is very similar to the $399 for a color LCD, and much more impressive.
If that doesn't convince you, I don't know what will
#11948 7 years ago
100% Y E S!
Super awesome. Crisp image, you will love it.
As others have said, a colorDMD is $400 upgrade. Makes this a bargain in comparison.
#11949 7 years ago
Oh, so the standard does not come with any LCD screen in the backbox? It's just a backglass?
#11950 7 years ago
As a fellow person who has ordered from CT, I will back this with 100% certainty.
$ 19.95
8,995 (OBO)
Burnaby, BC
Precision Pinball prod.
$ 699.00
Hi-Rez Pinball Mods
Playfield - Plastics
The Pinball Scientist
$ 810.00
