Fantastic mod. I have PB LV. Am interested in this. Thank you,
Willis
Just installed the mod and looks great but after booting it constantly shows the "tracker mode".
The single wire is connected to the shooter lane switch as shown in one of the pictures of this thread. The power cable patched to board 1 power.
Videos shows it should be in "logo mode" and only in tracker mode when the ball is ready to launched, right?
It is a PB machine and the mod version is for PB.
Any idea why it jumps to "tracker mode" and stays there regardless of switch status?
Quoted from KenEberhardt:Just installed the mod and looks great but after booting it constantly shows the "tracker mode".
The connection on the two pin connector needs to be swapped.
Check the instruction PDF sent to you via email
Quoted from Vimtoman:The connection on the two pin connector needs to be swapped.
Thanks - works now swapping the cables
I have the tracker mod. See attached. Received a gift from a friend. I need detailed instructions on how to install with upgraded Apron mod on PB LV machine. Doni remove from the plastic? Where do i install the three plus? Any help is appreciated. Thanks
70926692258__AB03CEA5-1CAC-4D37-8BF4-FF7DB571696B (resized).jpeg70927074380__9EF76877-14B0-47B2-8B4D-060DB14D635A (resized).jpeg70927081318__6F35E367-A63B-4FE5-BB87-CE2BC1A271C8 (resized).jpegAt least on the original Alien the tracker is connected to the switch in the shooterlane. So check if there is a fitting plug in/on/at/area of the shooterlaneswitch and connect. The tracker has to screens: With no ball in shooterlane the Wayland logo, with a ball in the shooterlane the tracker ...
Quoted from calprog:I have the tracker mod. See attached. Received a gift from a friend. I need detailed instructions on how to install with upgraded Apron mod on PB LV machine. Doni remove from the plastic? Where do i install the three plus? Any help is appreciated. Thanks
PM'd you with instructions link
Was thinking of picking up one of these machines and came across this mod. Looks awesome.
Are they still for sale?
Quoted from LeMansFan:I’d take one as well. Assumed these were no longer available.
I still make them. Have PM'd
Quoted from Vimtoman:I still make them. Have PM'd
I was also surprised that the Alien Tracker Mod was still available. Andrew's mod was an easy install on my office machine last week. The mod looks great, and I am certain it resulted in a new high score later that day!
Thank you, Andrew!
IMG_2156 (resized).pngIMG_2157 (resized).pngQuoted from PinstarNOLA:You have any of these left?
Thanks,
Tom
Quoted from BallyKISS1978:PM sent mate. Cheers!
Yep still make them. PM me
Quoted from jellikit:I would like to thank Vimtoman for his generous donation of an Alien Motion Tracker mod for our charity auction at Expo. Thanks again Andrew!
Brad
Project Pinball
Good luck with the auction Brad
Quoted from Hershmeister:My trackers is showing “static” on the too half of the screen. Any tips on why/how to fix?
Thanks![quoted image]
Try reseating the SD card.
You may need to take the back off.
You have my email just email me if that does not sort it.
Hi Vimtoman,
I ordered the Alien LE from PBB a week ago and am now eagerly awaiting this pinball machine.
I would love to order this great mod as well.
Is it still available?
If so, how can I order it from you?
Kind regards from germany
Marco
Recently received and installed this mod on my LV. It looks incredible and adds so much to the shooter lane. Super fast shipping and awesome support. I received mine in under 2 weeks (in Brisbane AU) and even with a slight wiring issue that was not in the install instructions, he was extremely helpful and got things in working order asap at no extra cost.
Cannot recommend this mod or Vimtoman's customer support highly enough!
Can I order an install kit from you? Posts and screws? When I swapped from an SV to an LV I removed the mod and mistakes were made.
Added 79 days ago:Edit: sent email.
This page was printed from https://pinside.com/pinball/forum/topic/alien-motion-tracker-mod-pbb/page/5 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
