Quoted from pingod:Looks great, you can try one of those on mine
Thanks! I'll show you what it looks like when I've finished with the design...all the little marks are taking a while to do, but it should be worth it in the end.
Quoted from cjmezz:Picked up and installed this morning. Turned out pretty good for not much work![quoted image][quoted image][quoted image]
Why not gap your machines a bit more so you can enjoy the amazing sideart?
Quoted from FYMF:Why not gap your machines a bit more so you can enjoy the amazing sideart?
It looks like ACNC is up against an overhang that won't accommodate the topper.
Yes room is an issue and with the topper the duct hang down doesn’t allow enough room for the topper. I only have room for 4 total machines. Under the duct will have to be one with no topper
Mine are packed as close as possible to fit more in
Quoted from netman63129:I don't want to rain on anyone's parade but you may want to wait on that. Pro Artist Mark Jarman of M&M Customs is working on one. Here is the prototype...
Would love to purchase one when it's ready.
Quoted from Vitty:Just did the silent fan upgrade to the power supply. Much better
Did you get the Pinmonk kit or do it yourself? I've been waiting for Pinmonk's spooky kit to become available but Covid seems to have jacked that all up. Just asking in case his came out and I somehow missed it?
I did it myself. Cost was 9.00 for the silent fan off Amazon plus a few pennies of solder and shrink tube and about 45 minutes of time to pull the power supply out, open it up, disconnect the fan inside it, resolder the original fan wire onto the new fan, and put it back together.
Shooting the left orbit on mine returns the ball sdtm too often, or it will hit the left flipper. Can we clear this up, is the left orbit supposed to feed to the left flipper or to the right flipper? Shooting the right orbit feeds fine to the left flipper, as you expect orbits to. My left orbit is Never close to returning to the right flipper. It seems this only happens on some peoples games. Has anybody actually fixed there game to feed properly? If your left orbit feeds to your right flipper Send me photos of your metal ball guide that spooky has said on here might need adjusting. Bonus if you remove the castle wall so i can inspect the entire ball guide. Or is the left orbit in fact supposed to feed across to the left flipper?
Quoted from KingHebes:Shooting the left orbit on mine returns the ball sdtm too often, or it will hit the left flipper. Can we clear this up, is the left orbit supposed to feed to the left flipper or to the right flipper? Shooting the right orbit feeds fine to the left flipper, as you expect orbits to. My left orbit is Never close to returning to the right flipper. It seems this only happens on some peoples games. Has anybody actually fixed there game to feed properly? If your left orbit feeds to your right flipper Send me photos of your metal ball guide that spooky has said on here might need adjusting. Bonus if you remove the castle wall so i can inspect the entire ball guide. Or is the left orbit in fact supposed to feed across to the left flipper?
My left orbit feeds my right flipper. I'm at a 6.8 degree pitch. Will try to grab a photo today.
I bent the top of the lane guide in just a bit.
Goes to the right flipper every time now.
I think it was just clipping the post rubber before.
Quoted from pingod:I bent the top of the lane guide in just a bit.
This- also I’ve had to mess with the lane guide on the left and spinner position as well. Pretty finnicky
I haven't been following this thread very closely. Have there been any new software updates since the bug fix release?
Quoted from gweempose:I haven't been following this thread very closely. Have there been any new software updates since the bug fix release?
If it's not on their website, then no.
It’s coming very soon, by all accounts.
Having several issues with my game lately.
First one is pretty odd could have sworn this was working before, but when I go into any of the menu test options I can only use the start button to enter the section menu, but then it is completely non-functional.
For instance I can enter coil test menu by pressing start, but the start button doesn't actually work to do any of the tests. I can enter the drop target test menu, but I can't select any of the tests..
Also having issues with Frankenstein mode. Lab lock 1 is caught and registers fine, but it looks like my lab lock 2 is always in down position, even after lab 1 is successfully locked. Lab lock 2 is lit, but since the drop target is always down, even if I hit a shot that should start frank mode the diverter doesn't shift to lock ball 2.
Guessing for this issue the drop target is just stuck, but I'm totally baffled about the start button abruptly not working to initiate tests in the test menu when it works everywhere else.
The game is on latest code
Quoted from Obed_Marsh:Having several issues with my game lately.
There is a bug on the latest code in the test section that doesn't allow you to test the coils. There should be a new code coming out very soon and hopefully fixed by then. As far as your drop target, yep, sounds like it's stuck down.
Not sure if this is what you’re looking for problem 1 but you need to use the flipper buttons to scroll the menus after you use the coin door menu buttons. That was new with the last code drop.
Quoted from Chisox:Not sure if this is what you’re looking for problem 1 but you need to use the flipper buttons to scroll the menus after you use the coin door menu buttons. That was new with the last code drop.
Think it was what drizzt76 mentioned about in current release code can't initiate tests.
Thanks though
Yup, but Fawzma said to me that it is only temporary. It will be fixed to work with coin door service buttons.
Quoted from Obed_Marsh:Lab lock 2 is lit, but since the drop target is always down, even if I hit a shot that should start frank mode the diverter doesn't shift to lock ball 2.
Yes, this is the issue there. I had this issue back when I unboxed my game - took me forever to finally realize that I couldn't lock Ball 2 because my drop was broken.
Quoted from Coyote:Yes, this is the issue there. I had this issue back when I unboxed my game - took me forever to finally realize that I couldn't lock Ball 2 because my drop was broken.
Good to know I'm not the only one. Thanks. Did it end up being a pretty easy fix, small adjustment for you? Or something more time consuming and laborious?
Hope to have some time to try to fix this weekend, but I have very minimalistic repair experience
I had to replace the drop target because it broke. Simple fix. Check that the micro switches are working and wires aren't broken. It's self explanatory once you have a look at the underside.
Quoted from Obed_Marsh:Good to know I'm not the only one. Thanks. Did it end up being a pretty easy fix, small adjustment for you? Or something more time consuming and laborious?
For me, my Sol Driver board was bad. I swapped the two boards (since the output for the upper Drop Target Reset isn't used on the other board), and then eventually I got a replacement board from Spooky.
I would lift the PF up, and verify that the drop-target is free - not bound up. Check the wires leading to it - there should be two to each coil, and two to the switch. Make sure they're all secure.
Had a really annoying bug happen today
Was in crypt MB. Had the mystery lit to start a mode, and secret passage lit. Shot one ball into the scoop, and then the other into the secret passage while the mystery animation was playing. Mode started, then half way through the intro music, the mode started again. Finished the mode, and then I shot an orbit for the next mode, and no progress. I stayed in the first room, and both orbits remained lit. Couldn't manage to hit the mystery again to try to start the mode that way. Secret passage couldn't be lit since I hadn't locked in the monster yet. Finally drained both my balls. Next ball, hit skillshot to light secret passage. Hit secret passage, mode started, but my ball drained instantly, and there was no ball saver for some reason.
Hey guys, can somebody explain Cold Ethyl mode a bit perhaps? I lock the ball, she says release me, I hit the crypt shot again to release her and then when I hit the crypt shot again, nothing happens? Am I missing something?? Thanks guys!!
Quoted from WombatPinball:Hey guys, can somebody explain Cold Ethyl mode a bit perhaps? I lock the ball, she says release me, I hit the crypt shot again to release her and then when I hit the crypt shot again, nothing happens? Am I missing something?? Thanks guys!!
After you release her, you need to shoot back in the Crypt. (I am not sure if a lower shot will work, but I *KNOW* that a shot up to the Upper PF, and then letting it roll past the upper flipper WILL count.) Once the second ball is captured, you'll have a dropping sound-effect and a limited amount of time to release that ball - either by dropping it from above, or hitting the drop target. If you do't make the shot in time, the ball is released and you start over. If you DO, you've 'defeated' Ethyl.
(Edit to add: This is as of v1.1.0.0)
Quoted from Coyote:After you release her, you need to shoot back in the Crypt. (I am not sure if a lower shot will work, but I *KNOW* that a shot up to the Upper PF, and then letting it roll past the upper flipper WILL count.) Once the second ball is captured, you'll have a dropping sound-effect and a limited amount of time to release that ball - either by dropping it from above, or hitting the drop target. If you do't make the shot in time, the ball is released and you start over. If you DO, you've 'defeated' Ethyl.
Protip: Lock a ball in Ethyls crypt before starting the mode and you skip a step by being able to release her at the start of the monster mode.
Then keep trying to hit the ball back into crypt while in two ball MB and continue on as described above
Quoted from dnapac:Thanks cjmezz! Really looks awesome. Went on easy with the material you chose. Easy to reposition.[quoted image][quoted image]
Holy hell I need this.
cjmezz show me the way (price)
Quoted from FYMF:Holy hell I need this.
Me too! (UK)
Can you post a whole pic of those two machines lit up. They look really cool next to each other!
Better yet, you should post a video on YouTube. I never seen anyone do this yet!
Quoted from scruffypinball:I’m in on that panel mod too! Where can I buy?
Back of the line!
Quoted from Mr_Outlane:Can you post a whole pic of those two machines lit up. They look really cool next to each other!
Here’s a few pics of the 2 together. Almost 600 games on R&M and about 600 on ACNC. My other pins are getting neglected.
3965A309-6DEF-435C-A25E-3EC09E91F9F3 (resized).jpeg0569DDF4-59A4-4724-8844-642CC60B358D (resized).jpeg8C3237C7-4B41-4B9C-93C5-F46C63174265 (resized).jpegF8702BC3-F08E-4207-9748-A0F168EBC06D (resized).jpegQuoted from dnapac:Here’s a few pics of the 2 together. Almost 600 games on R&M and about 600 on ACNC. My other pins are getting neglected. [quoted image][quoted image][quoted image][quoted image]
Sweet! What a great trio!!
Thank!!!
Quoted from gliebig:Had a ball come to rest here for about a minute during crypt mb.
Yup, like every pin I have. Nudge or nudge not!
I'm having a consistent issue where I shoot a ball into the left Frank lock. The ball 'locks' but is stuck at some point prior to resting against the window of the castle. If I don't make the other lock before game over Frank adjusts and the ball falls through the playfield and into the cabinet. This has happened twice to me now in the last several games. I tried searching this thread and found some spotty info but nothing concrete on how to fix it. Any thoughts?
Quoted from Vitty:I'm having a consistent issue where I shoot a ball into the left Frank lock. The ball 'locks' but is stuck at some point prior to resting against the window of the castle. If I don't make the other lock before game over Frank adjusts and the ball falls through the playfield and into the cabinet. This has happened twice to me now in the last several games. I tried searching this thread and found some spotty info but nothing concrete on how to fix it. Any thoughts?
Adjust the frank height in the service menu. Just 1 or 2 at a time.
Seems my frank won’t go any lower than 6. At this position I can see why the ball is getting hung up. If it would go lower I would be ok. If I push gently on frank he does lower a bit more. Going to have to take him apart to see if I can adjust him a bit lower.
Fixed my Frank problem. At the lowest setting Franks 'scoop' that cradles the ball coming from the left ramp was sitting a bit higher than the metal ramp plate leading to it. I simply bent the metal ramp slightly back upwards to level it with that ball cradle. Problem appears to be solved and so far no more hangups.
Next up on the list of fixes is the ball save magnet. Mine works 0% of the time no matter the pattern. I ran across the PL magnet core plastic and installed it tonight. I then tried all settings including resistor on/off and they all behave the same. Pretty much every pattern will grab the ball, but it just hovers there then drains. The ball never makes upward movement no matter the setting. It is the same with the plastic cover as it was without. Am I missing something or is there anything else to check/adjust? It looks awesome from what I can see online here, however I've played several hundred games now and have yet to witness it work.
Quoted from Vitty:Next up on the list of fixes is the ball save magnet. Mine works 0% of the time no matter the pattern. I ran across the PL magnet core plastic and installed it tonight. I then tried all settings including resistor on/off and they all behave the same. Pretty much every pattern will grab the ball, but it just hovers there then drains. The ball never makes upward movement no matter the setting. It is the same with the plastic cover as it was without. Am I missing something or is there anything else to check/adjust? It looks awesome from what I can see online here, however I've played several hundred games now and have yet to witness it work.
What incline is your game set at?
Quoted from Coyote:What incline is your game set at?
Meant to include that above but missed it 7*
Quoted from Vitty:Meant to include that above but missed it 7*
Ah, okay then! Check that your balls aren't slightly magnetic.
This page was printed from https://pinside.com/pinball/forum/topic/alice-coopers-nightmare-castle-club-enter-at-own-risk/page/89 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
