(Topic ID: 208341)
Alice Cooper's Nightmare Castle Club: Enter at own risk!
By Sarge
  • 7,624 posts
  • 393 Pinsiders participating
  • Latest reply 7 minutes ago by Coyote
  • Topic is favorited by 151 Pinsiders
12 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 7,624 posts in this topic. You are on page 152 of 153.
#7551 17 days ago
Is Spooky. Is Quirky.
ForgetAboutItPunkin
#7552 17 days ago
Quoted from Morgoth00:
Also would freeze and stutter when it shows the comic book flipping.
I would suspect the pin is on old code.
The freezing was an issue early on if the pin had been running for a long time or played a lot. It was down to memory issues with how the game used images.
Haven’t had an issue on the newer codes.
rd
#7553 17 days ago
Quoted from rotordave:
rd
Ah makes sense. Was on location with many other pins
#7554 17 days ago
Or that.
#7555 13 days ago
So I'm having real rotten luck these days with my pins - I've had HW and ACNC both go down, and one of my Stern toppers going fubar all within the space of a few weeks.
Anyway Spooky sent me a new CPU unit for my ACNC which has indeed fixed an issue I had with the machine not booting up. After installing the new computer, imaging it with the software and then updating to the latest code - I played 2 games and all looked good again. However, now (next day) when i start up the machine, one of a few scenarios may happen:
1. The game will get half way through starting up, then everything will will go blank and it will cycle back to the beginning of the start up routine, then this will keep happening (at different stages of the start up).
2. The game starts up fully, then hangs (screen will freeze - all playfield lights will freeze), this can happen before I've even hit the start button, just leaving it in attract mode.
3. I start a game, get through maybe ball one, and the game crashes and attempts to restart.
4. I actually play a game with no issues.
A similar thing would happen sometimes before I replaced the CPU - it would just hang on startup, and usually I would have to give it 2 or 3 attempts, but then it would be fine and it would never crash during a game. It's beginning to drive me nuts - it really does appear to be a bad connection or something, but I have triple and quadruple checked all the plugs/connectors they all appear to be good. Anyone have any ideas? I've obviously contacted Spooky, but just seeing if anyone has had similar problems and can advise on anything else to check.
I think this is perhaps one of my favourite games ever, but holy hell it's had the glass off more than the rest of my pins put together. Really do love it, but I just wish I could get it working more reliably.
#7556 13 days ago
Quoted from Ceemunkey:
Flakey power supply?
Just an idea - Follow the power lead from the computer down to the power supply, see where it’s screwed in. Maybe move the lugs to a different output, see if there’s any change …
Worth a shot.
rd
#7557 7 days ago
I'll try that rotordave... This is a really infuriating problem though. If I do manage to get the game powered up, started and not frozen after 15 minutes. It'll play quite perfectly with absolutely no issues. Last night I played for 30-40 minutes with no problems whatsoever. This morning when I go to start it up, I can't get it to boot up fully, it just keeps restarting over and over before it can get to the attract screen. Rarely, but sometimes when it is starting I'll hear a quick burst of static, then the display will freeze up like in this pic. Really odd...
#7558 7 days ago
I'll try that rotordave... This is a really infuriating problem though. If I do manage to get the game powered up, started and not frozen after 15 minutes. It'll play quite perfectly with absolutely no issues. Last night I played for 30-40 minutes with no problems whatsoever. This morning when I go to start it up, I can't get it to boot up fully, it just keeps restarting over and over before it can get to the attract screen. Rarely, but sometimes when it is starting I'll hear a quick burst of static, then the display will freeze up like in this pic. Really odd...[quoted image]
Yeah sounds like cable or power issues to me.
The computer obviously works cause it works half the time.
So I would very carefully and methodically do over every connection from the wall power socket to the computer. Look for flakey molexes, crappy crimps, stuff like that.
Wiggle all the crimps (via the wire) on the connectors while they’re going … see if anything goes on/off.
rd
#7559 7 days ago
It would certainly seem that way - but I just don't get why once it has started up and has been active for 15 mins, it will be pretty damn solid. This morning it took several attempts to try starting it before I gave up, but I tried again later and once it had started (took a few tries), it's been ok - and I have literally played it for 2 hours and left it on all night so far with zero issues.
If it was a cable/power problem I would expect it to cut out again at some point - especially during play with all the vibrations and movement. Maybe its such a fine line, that starting it "cold" is the issue? I can certainly try giving the connectors a wiggle while its on (yes, via the wire)...
#7560 7 days ago
Have a ACNC mini playfield for sale. It’s brand new, I bought it to attach to my wall art playfield but never did. Main playfield looks nice without it
I also have the hardware to install it.
$150 shipped in the $US
Pm me if interested.
9035A245-CDA5-43F3-8F50-2BF323540D10 (resized).jpeg9DD0A07A-18F2-466F-8042-902FEEF08542 (resized).jpegC68BC79A-DB97-42ED-9D2F-1D5EB220135C (resized).jpeg
Added 5 days ago:
Thai is sold.
#7561 7 days ago
Also have this monster artwork by Brian Allen (autographed). Alice cooper is in there. Measures 11” x 17”
$45 shipped in the US
Added 5 days ago:
oops I priced this too high
reposting a lower price
Added 5 days ago:
Sold
#7562 7 days ago
Quoted from Pinball-Obsessed:
That's cool!!
#7564 6 days ago
Quoted from Daditude:What is everyone using for a topper?
Dust
#7565 6 days ago
Search the thread, there is the best topper ever made for any machine a couple months ago, there may be one left if you ask.
#7566 5 days ago
Looking for some Discontinued mods for Alice Cooper. With to pay cash, wire transfer, Venmo or PayPal. Whatever it takes.
Mods are done by medisinyl and lord of the game room. Thanks for your time. DM if you have anything and a price you want.
#7567 5 days ago
Quoted from WannabeWizard:
I contacted Lord of the Game Room about a month ago inquiring about mods for Alice and he assured me plans to offer them again in the future.
#7568 5 days ago
Added today: oops I priced this too high
Reposting this for sale.
$25 shipped.
#7569 5 days ago
Quoted from Merendino:
That would be great. Hopefully soon. I contacted him also. Maybe the more people that contact him the sooner they will be released
#7570 5 days ago
$25 shipped.
I will take this. Thanks
#7571 4 days ago
Trouble with chopper!
My ACNC started blowing the 3A fast blow fuse that controls Frank and the guillotine. The guillotine is stuck trying to lower itself - it bottoms out and keeps trying to get lower even tho its bottomed out and that pops the fuse pretty quickly on boot up. Since its stuck in the lowest position upon bootup, and it just keeps trying to lower itself, it just blows the fuse upon each fresh boot.
Ideas?
What device is supposed to be telling the guillotine its at the bottom of its range and to stop trying to go down?
#7572 4 days ago
Quoted from superhawk2300:
Ideas?
In the test menu, there are options to set the top, mid and lower for the guillotine. The motor will try to move it to those settings. There is no switch to stop it.
There is a great useful video from Spooky that will be in this thread somewhere that shows how to set up the motor and guillotine.
I do not have the link to hand but it should not be too hard to find or search YouTube for Alice Cooper Nightmare Castle motor adjustments.
My guillotine broke and my motor went bad to been through this a couple of times.
Skippy2904
#7573 4 days ago
I wondered what would make the setting change or for the chopper to just start acting this way. I went back out to reset the menu, reset it to 0 which did not work, then 35 which seems to be the default and now it just keep rebooting itself after it gets this far in its boot cycle. I did reload the software with the last update again once it started happening and it did not change anything - just keeps rebooting now...
#7574 4 days ago
I wondered what would make the setting change or for the chopper to just start acting this way. I went back out to reset the menu, reset it to 0 which did not work, then 35 which seems to be the default and now it just keep rebooting itself after it gets this far in its boot cycle. I did reload the software with the last update again once it started happening and it did not change anything - just keeps rebooting now...[quoted image]
Contact Spooky support. Something happened to your game's settings file (likely why it got corrupted in the first place) and now the game software can't read it.
#7575 4 days ago
Quoted from Coyote:
Doesn't sound too serious. That will help sleeping tonight. Thank man!
#7576 4 days ago
What do folks think of the green armour kit on this one?
#7578 3 days ago
Ooof a downvote - that's a bit harsh I was only asking opinions.
Yeah think I much prefer my blue, but I would like the side armour and speaker grills (again, in blue). I wonder if Spooky still make them...?
#7579 3 days ago
And you got it. Downvote = disagree/dislike. Not sure why that’s harsh.
#7580 3 days ago
Quoted from chuckwurt:
It was a question. Its like downvoting the question itself.
I do prefer the blue. Although I think the powder could be a bit better quality wise.
#7581 3 days ago
Quoted from insight75:
Yeah was just thinking this - anyway yeah, I guess it's just giving a thumbs down on the armour itself... all good.
#7582 3 days ago
What do folks think of the green armour kit on this one?[quoted image]
I really like it. The blue now doesn’t look right to me. Plus, if you have a black light…the armor will
glow.
-2
#7583 3 days ago
We had this out. You reckoned Robin said it but he didn't.
It's only you that think this.
Other people see it as a different thing chuck
#7584 3 days ago
For those of you interested: Lord of the Game room has his Alice mods back in stock as of today.
#7585 3 days ago
Quoted from punkin:
You’re right. It’s only used to disagree with a post. So the person that disliked their picture and used the downvote to voice their dislike, was in the wrong.
The rest of your post I disagree with, hence the downvote.
#7586 3 days ago
I liked my purple.
#7587 3 days ago
Quoted from kciaccio:
I liked my purple.
Love the options! Looks good.
#7588 3 days ago
I liked my purple.
That looks amazing mate - very nice.
Also, huge bonus points for HW and Alien - probably my 2 favorites this year.
#7589 3 days ago
Aahhhh but their exit tunnel mod isn't in stock. I already have Medisinyls centre tunnel, crypt, lab, volcano and secret entrance sign. This one would be the final piece in the puzzle.
https://lordofthegameroom.com/products/alice-coopers-nightmare-castle-exit-tunnel?variant=42735271051415
I would LOVE to add that - I wonder if they'll run that again?
#7590 3 days ago
Reached out to him on FB. He says he will have more in stock in a matter of days.
#7591 3 days ago
I'm highly considering this Laseriffic topper intended for Rob Zombie, actually.
#7592 2 days ago
YaY...just got my very own ACNC.
Couple of queries, if anyone could advise please.
1/ how do I know which No. machine I have?
2/ Ball seems to fly over the teardrop on guillotine. Best way to slow it down?
3/ (most important) how do I adjust the magnisave? It grabs the ball. Wobbles it a bit, then releases it. Shouldn't propel it on to the playfield? I know it has the plastic protector fitted, could this affect its workings? I read an earlier post (from SpookyLuke[?]) about adjusting the magnetic pole? Anyone any advice/experience?
D
#7593 2 days ago
Co
Quoted from Crazysurfkid:
D
Congrats! Such an awesome game I think I like it more now than when I bought it last year!
1. I think there's a sticker inside the cabinet with serial number etc on it. It does have "Model Number" written on there I'm not sure if that's the actual machine number?
2. You can lower the "lock" position of the guillotine in the servo settings - mine used to do the same, so I gradually lowered the lock position until it was deep enough to catch even fast ball. I'd give that a try first.
3. There are options to change the magnet pattern in the settings. Again, mine didn't really work consistently on the "original" setting, try changing it to one of the other patterns and give it a try. One of those options should yield better results.
#7594 2 days ago
Yes, unlike WMS, Spooky's serials are actually serialized. The last 3 digits of your serial number is your machine number.
#7595 2 days ago
Thanks, I'll have a look at serial No.
Re the guillotine- the trap is already low. I think the problem is the ball just is travelling too fast. Might try and put something to slow it down.
I've tried the different settings for the magnisave ( from what I read, it just changes how soon the magnet pulses. It seems as if the magnet isn't strong enough- wondered if it was because of the protector on it, or even if balls aren't attracted enough i.e. maybe 3rd party balls?
#7596 2 days ago
Read this entire thread, many troubleshooting ideas and fixes.
#7597 2 days ago
I did this. Easy job and magnasave never failed me since.
#7598 2 days ago
…a strip of black felt in the curve will help.
#7600 2 days ago
Legit just installed on my Alice Cooper last night. I love the ease of changing and testing out different flipper angles ESPECIALLY on this game. We all know how frustrating the shots can be on this title.
After a few different flipper positions I found one that works fantastic for my playstyle.
Also, 1956PINHEAD did you mean November 30th??
Pinhead mods
Protection
$ 69.95
Hookedonpinball.com
Toys/Add-ons
$ 649.95
Pin Stadium Pinball Mods
Led
7,100
Fort Worth, TX
$ 299.95
Led
$ 0.99
Daddio's 3D Printed Mods
Toys/Add-ons
Pinball Mod Co.
Other
Pin Monk
Other
$ 89.95
Hookedonpinball.com
Toys/Add-ons
Filament Printing
Other
